Question about Canon Office Equipment & Supplies
Problems with printing pages on canonip90v
My printer is quite new but has had many problems. the latest is that at end of printing first page it makes a creaking gate noise and stops. I can turn it off and print another page when turned back on if reset everything but it is a pain. the noise sounds like paper is catching but I can't see inside the machine. can you help me. can't take it back to place where bought as canon are supposed to come here to sort out problems, they never managed to that i the past. sue
Posted on Oct 19, 2008
Only prints one page
Can you delete your printer from your pc and reload it? mine hangs up once in a while too. Just weird gremlins as sometimes it's perfect.
Jun 27, 2014 | Dell V313w AllInOne InkJet Printer
HL 4040CN is printing with a pink tint, it also says drum end soon and has said that for a while. What sould I do?
I have a similar problem now: magenta stain over the entire page when printing anything with any color (even just a hyperlink); B&W text is no problem.Not the PC; even the Demo Page from the 4040 menu does this. Updated the 4040 firmware tonight to latest (1.24, etc), but no better.Recently replaced the Magenta cartridge (official Brother cartridge), though saw this problem near end-of-life of the previous Magenta cartridge. Drum Unit status is 42%, so not expected to be near end-of-life.
Nov 28, 2011 | Brother HL-4040CN Laser Printer
How do i switch of align page when installing a new cartridge as it waste paper printing a test page everytime you switch it on. This is for a HP 1300 series
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=238320&taskId=110
Click on the 'Automatically check to see if your driver needs updating (MS Windows Only).' box in order to check for latest updates to your driver.
Unfortunately, I looked over the unexpected page output and it didn't list this problem as one of them.
Does it really print a test page every time you switch it on? Or does it only print a test page after installing a new cartridge?
Definitely, the alignment page should be printed everytime a new cartridge is installed due to variations in manufacturing of print cartridges will throw off the alignment everytime a new cartridge is installed.
I'm not sure about the test page, though.
Good luck on this modification of standard operating of hp printers.
Jan 17, 2011 | HP LaserJet 1300 Printer
Hi, We have an HP Laser Jet 3050. We keep
The problem is the driver for printing
Here you can get the latest version of drivers for the operating system you have. http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=1140778&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=1140783
Have deleted the old driver from Device Manager - Printer and Faxes (if using XP).
Then reinstall the version you get - the safest try PCL5e version. If you have drivers for printers you do not use them would be better to remove them and on them.
Jun 14, 2009 | HP LaserJet P2015 Printer
I need your help my printer quit printing, I was low on ink and it quit printing after I printed a page. I changed cartridges and it still would not print, so I swapped cartridges with a different printer...
So it prints the self test (test page) or not?
If nothing is printing from at all (printer moves likes it is printing when in operation, but no ink hitting paper) there may be a blockage on the jets or the information is not getting to the printer properly if these same cartridges work on another printer.
I would lift lid and carefully check each one and wipe with a thin cloth the remove any clotted ink and dirt.
You have already reinstalled the drivers, but I would get the latest ones you can from www.hp.com
Finally I would cold reset the printer - usually holding the go button pressed in while hitting the power button on and off - will reset rthe calibration and give you a better chance of fixing.
Also if you have the cartridges for the wrong model, they may physically fit in, but the chip on the cart will tell the printer theres a problem and won;t print.
Summary:
- Check cartridges - off the top of my head (please check!) you should be using HP 45 for Black and HP 68 for Colour (if using a different brand, fine but the numbers are thee same)
- Download latest drivers
- Cold reset printer and install again
Good Luck
Mar 14, 2009 | HP DeskJet 940c InkJet Printer
Printer will only print page 1 of multiple page documents
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
Nov 26, 2008 | Kyocera FS-C5030N Led Printer
New HP CM2320fxi printing solid black pages
The Black Toner it came with was faulty, apparently a known issue with HP - though HP Support in the UK has asked more about the computer software though the printing was with photocopying, internal reports etc.
Nov 17, 2008 | Office Equipment & Supplies
Printing blank page at the end of every printing job
Hi Keren,
1) Are you sure it is the printer, not the software application ?
Try printing a single "Hello World" message from "Notepad"
If there is no blank page at the end of it, the problem is in
the specific software app: Office, Word, Excel, etc...
2) What application are you printing from?
a) Check the page and print setup.
b) Make sure the application's "page size" and the printer's
paper size are consistent. Pay special attention to
metric paper sizes vs English:
E.g. A4 vs Letter
If the page with margins is bigger than the paper, it will
generate a new page, even though there are no visible
characters on it.
c) Check the print margins within the page setup:
In MS-Office: File ---> Page Setup --->
d) Add a single character to the very bottom of your
document, and see if it wraps around onto the last page.
Microsoft office applications are notorious for wrapping
the last PARAGRAPH character onto the next page if
it does not quite fit onto the paper.
e) if you are using MS WinWord, go into options and set it
to display all special characters:
Check to make sure that there are no page-breaks at
the end of the document.
Also look for extra paragraph marks/ carriage returns,
and check the format settings on the last paragraph
mark in the document:
Page brake before...
Keep lines together ....
Widow and orphan control ...
which can cause the last paragraph mark to generate a
new page. If the last paragraph mark is not formatted
the way you want it, make sure that you save the
TEMPLATE after you change it, since this is the
DEFAULT setting for all new documents.
Finally it is also possible for Windows applications to look
different on the screen than the final print due to small
(but cumulative) True Type Font (TTF) computation erros,
such that a 10 page document on the screen can actually
page-split in weird places printing as 11 pages.
I have the identical model of printer, and it does NOT seem
to have any settings for printing banners or adding separator
pages, at least not in my printer driver, but this is NOT to say
that the applications you are using are not causing this
problem.
I hope this gets you started.
Please rate my answers.
Martin
Jul 01, 2008 | Brother HL-2070N Laser Printer
Print stops after 2 pages !
Hi my tally printer 6218 giving Ribbon motion fault, what could be done to remedy this error message ?
Jan 19, 2008 | Tally T6218 Matrix Printer
32 people viewed this question
old marine
old marine
