Question about Breville ESP8XL Espresso Machine
No coffee Water tank is full but no water/coffee is forthcoming when control is turned to coffee side. Machine was working OK but when moved to a new place the fault started. Appreciate your help
  • 1 more comment
  • Anonymous Jul 16, 2008
    steam builds up and no coffee comes thru the filtre making this very dangerous as it almost blows when the coffe attatchment is taken off.
  • johnroma Jul 21, 2008
    No steam from steamer. Suggests faulty pump (although can be heard working) or blocked pipe. Water is visable at water inlet on the base of the machine from water tank, so I guess probelm is in the body of the machine. I would gladly pay to have the item fixed but the nearest service agent is a long way distant.
  • johnroma Aug 16, 2008
    Its not a filter probelm as there is no water in the coffee container after switching on. There is steam when switched on. My guess is low pump pressure although appreciate any other ideas. Does any one clean the filter held in position by a single screw thats on top of the coffee container? Thanks john
  • 74 Answers
Does it come out water from the steamer?
if that is the case I would clean the filter on the machine.
Posted on Jul 16, 2008
  • KaffeSumpen Jul 16, 2008
    Ok take the filter that you put the grinded coffe in and hold it in front of a light.
    Do you see a very tiny hole in the center of the filter?
    if not the filter is blocked.
    What you can do to trie and clear the blockage if you dont see the small hole is to put the filter in descaling liquid, for 3 - 4 hours. and then clean it VERY CAREFUL to take away any residue of the descaling.
    If this does not help you need to buy a new filter.
Water light not going out, even when full. Not able to make coffee
the water tank has a float inside, the float has a magnet. the machine senses the position of the magnet and indicates water ok/not. sometimes the magnet rusts inside the plastic casing, renders it less magnetic so it wont work. or the float is missing- fell out while you were cleaning the tank. you will need a new magnetic float to fix the problem.
Feb 11, 2014 | Saeco Incanto Classic Espresso Machine
Machine says "fill water tank"
look at the magnet (left, closer to you side, inside the water tank). It might be stuck. try bumping it slightly or insert a toothpick in the hole and slightly move it up-down. It might help.
Jan 06, 2011 | Spidem Trevi Digital Plus Coffee Maker
Water light stays on....no water dispensed, even
My Machine will grind-tamp but will not add water to push through.It will send water out tap on the side.
Apr 14, 2010 | Starbucks Saeco Italia Digital Barista...
Doesn't drip through. Don't know where the coffee water went to?
When setting up a new machine, it requires 2 full decanters of water to be poured into the machine. After you have done this, then you plug the machine in and turn on the vacation switch on the side of the machine. After 15 min, then you will pour in 4-10 cups of water and it will force out the hot water from the tank in the back and brew the coffee. If this doesn't correct the problem, then please call customer service with the model and date code.
Sep 11, 2009 | Bunn NHB Coffee Maker
Fill Water Tank But Water Tank is Full
Check the little black rectangular box which is in a plastic channel at the back. To work properly, the rectangular box, with the narrower end facing downwards, needs to be floating at the top of that channel. Apparently it's a magnet which signals the circuitry that the water tank is full. Make sure it's floating to the cap of the channel. If not, you can get a replacement one from Gaggia.
May 29, 2009 | Gaggia Titanium Espresso Machine
Says "Fill water tank" and the tank is full
did you open the side valve to ventilate the air in the system in our water tank do you have a little magnet its in the water tank maybe it stuck downshake the water tank to move the magnet up pierre
Jan 09, 2009 | Saeco Magic Comfort Plus Espresso Machine
I Have a Krups Espresseria automatic coffee machine & my problem is the water indicator in the water tank does not rise when the water tank is full so the machines keeps telling me to take the water...
Inside the water tank there is a magnetic float which is causing the problem. This float is moving always on the top of the water tank as you fill it with water and in reverse as the water level goes down then the float is moving down to bottom also. So as the magnetic float is moving up and down is giving the signal for the water level if it is full or empty.
So possibly now the float is stuck in the bottom and even if you have refill the tank this is still on the bottom of the tank. This can happen from many reasons. First could be that the plastic column that the float is moving is full of scale and it can not move up and down freely any more so you can clean it from scale by decaling it and even clean it with a wire brush.
A second possibility could be that float have a tiny hole and some water enter in the float and this make it to stay on the bottom of the tank. You can visually inspect it and if possible you can dry out the water and weld with a super glue the hole if possible, if it can not be fixed then you need a new float.
If you wand to fix it temporary until you find a new float you can a plastic clip or similar to secure it always on the top however you when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid any other problems with the machine.
Good luck
Nov 17, 2008 | Krups Small Appliances Espresso Machine
Water tank level indicator sinks to the bottom when water tank is full.
I think the float is up and down, try to take it out and turn it.
Look at the float in the other tank to see if it is same position, the rounded side should be down.
Let me know if you get it to work.
Best regards
/Mirran
Sep 04, 2008 | Saeco Royal Cappuccino Espresso Machine
hello in the water tank they is a float it was probably out of water for a while and the float is stuck take the container in our hand and tap it gently by doing that the float gonna get loose move the container you gonna ear the float move put it back fill with water enjoy cheers
Jan 14, 2008 | Gaggia Titanium Espresso Machine
Breville ESP8XL Espresso Machine Logo
128 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
