Bob Mackie SR1530 System Logo
Posted on Jan 20, 2011
The mid driver is burnt out where can I get a replacment
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1864
Points
My background is live audio and was a tour manger and sound engineer for over 22 years
A couple of months ago I bought a pair of 1530's for $450. They were a bit dirty and had spider webs all over.
I cleaned them all up but was not happy with Mackie's open dust cover design on the mid. When I would slightly depress on the cone one could hear scratching. (it would later turn out to be debris, the coils were in good shape)
The mid speaker in part of the horn-mid flare and can not be reconed.
I my hunt to find a replacement I went as far as ordering a RCF recone kit from Legacy Sound Services but they went bankrupt before they could deliver my kit.
After another search I ended up buying two Eminence LA6-CBMR 6.5" speakers as their there specs and outside diameter of the frame seemed to be a good fit. (this was after I had removed one of the cones from it's hi-mid flare and measured the opening)
When the arrived they slide in perfectly leaving about a 1 mm gap. After removing the magnet from my old rear cover I purchased eight #8 x 3" screws.
I gently tightened down the screws and was ready for my test.
I was amazed side by side the eminence was much smoother around 1.5 khz
Note: the Mackie mid is 5.9 ohms and the eminence is 6.9 ohms and is 150w
One issue is that the new speaker sits about a 1/4" farther back than the original.
I don't have a realtime analyzer but over all the Eminence seems to be a great fit.
I did replace the rubber gasket at the base of the mid flare opening, there did not seem to be a noticeable change.
If you like you can contact me at [email protected] and I will send you pictures
Burners went out all at once-wont heat up-The oven, lights all are ok--Frididaire Gm Model RCDG-71P 40" double oven range circa mid 60's can you advise?
Open the fuse box (probably under the back-top) and replace the burnt fuse. Replace with the exact same rating/size fuse.
Dishwasher stops mid cycle
Do the foll. things:
1)Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so. 2)if ur dishwasher doesn't starts then: First, check the usual suspects: Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Asko dishwashers have had problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced. You can buy any replacement parts you need right here.
Goodluck,
Dont forget to rate me as fixya..
1helpful
Washer stopped mid cycle and now it will not even turn on. I can also smell a burnt odour. Is my motor shot?
Yes, the motor has definitely burnt out causing an overload protection to switch off the electrical supply inside the machine.
My mids and highs have cut off but my subs still work
are mids and highs amped? if so check fuse. many people forget about fuses. if running off head unit only, then the internal amp in the stereo in probably burnt up. if this happened you can run an external amp from the front rca outputs and problem solved with better sound than before!!
2answers
Your timer is off and should be tossed and replaced. It's burnt out and can be replaced. Sears and Lowes carry appliance parts, you can order it and install it yourself. It's relatively simple and can be replaced in little time.
No sound from tweeter bx5a
First of all, never connect the audio from your receiver directly to the tweeter. You can blow the tweeter instantly. The mid-bass driver can be damaged from a direct connection as well.
Since you get absolutely no sound from either driver, this seems to implicate the crossover. If the crossover has opened, no signal gets through, if it has opened early in the signal path.
But, it is also possible that a short exists, and that perhaps your amp cuts off the output having sensed a short. The short could be in the crossover or one of the drivers.
Here are some troubleshooting tips--
To prevent damage to your amp, turn it off while making or breaking any connections inside the speaker boxes.
Write down which wires get connected to which place on the drivers, so you can get them back where they belong.
With your amp turned off, connect the bad speaker to your amp. You've already verified that no sound is produced when both drivers are connected.
So, with your amp off, disconnect one wire from the tweeter in the bad box.
Briefly turn your amp on and listen for sound.
If you get sound, the tweeter is shorted.
If you get no sound, with the amp off, reconnect the tweeter in the bad box and disconnect one wire from the mid-bass driver.
Briefly turn the amp on and listen before turning the amp off.
If you get sound now, but not before, the mid-bass driver is shorted.
If you got no sound either way, check the DC resistance of the mid-bass driver (only, not the tweeter. Ohmmeters put out a small DC voltage to test resistance. That DC voltage might damage a tweeter, maybe. Don't risk it). Ohm the mid-bass driver while it is not connected to the crossover. If the driver is good, you should read some ohms--a little less than the stated impedance. An 8 ohm driver might read 6.5 ohms, for instance. If you get an open or a short (with the crossover disconnected from the mid-bass driver) you have a blown driver. Two actually, since neither the tweeter nor the mid-bass driver produced any sound in the previous tests.
If you can't get ahold of an ohmmeter, try this--
Open the good, working speaker and place the two side by side.
Connect your amp to the bad speaker box only.
With your amp turned off, disconnect the wires from the mid-bass driver in the bad box and connect them to the mid-bass driver in the good box. Disconnect one of the wires from the "good" mid-bass driver first, so you don't have two crossovers connected to it at the same time--even if only one of them will get powered on. It keeps the confusion down to a minimum when trying to isolate your problem. Oh, and disconnect one wire from the bad tweeter, in case it is shorted.
Turn the amp on and listen briefly before turning the amp off.
If you got sound, the "bad" crossover is fine, but the "bad" mid-bass driver is blown. And, since you got no sound in the previous tests, the "bad" tweeter is blown, as well.
If you got no sound, try it the other way around. Meaning--
With the amp off, disconnect the speaker wires coming from your amp from the bad speaker box and connect them to the good speaker box.
Your amp is now connected only to the good speaker box.
With the amp still off, connect the mid-bass wires from the good box to the mid-bass driver in the bad box. Remember to disconnect one of the "bad" crossover wires from its own driver first, so only one crossover is connected to the "bad" mid-midbass driver. Remember to disconnect one wire from the "good" and "bad" tweeters, so the only sound you hear--if any--is from the "bad" mid-bass driver, powered by the "good" crossover.
If this produces sound, but the previous attempts failed, you have a crossover problem.
If you still get no sound, something went wrong and you need to retest the good speaker by itself and back up a few steps and try again.
Assuming you got sound from the "good" crossover while it was driving your "bad" mid-bass, make sure no wires have come loose inside the "bad" box. Assuming you have sound connections at each end of each wire, you now need to desolder the electrolytic capacitors from the circuit board.
Make sure you mark them first, so you can put them back where they belong.
You can remove only one at a time, if that helps.
Use an ohmmeter to check some components.
The big red coil should read pretty close to a short, maybe one ohm.
The capacitors should read open or infinite resistance, although you might see a steadily increasing resistance while the capacitor charges up from the ohmmeter. If you read a steady low resistance on a capacitor after it has been removed from the circuit board, that capacitor is bad and must be replaced. The markings on the capacitor should give you some clues as to the proper replacement.
All things considered, I suspect that your problem is a shorted electrolytic capacitor. But, I gave you all I could think of so you can narrow it down and isolate the problem, whatever it might be.
I hope this helps.
Stopped working mid a 2 min set. no lights no clock display,
The most common cause of this type of failure during the cook cycle is the fuse melts causing a dead condition. To replace the fuse the cabinet has to be removed and the fuse replaced with the same type and amperage. Pay attention to the fuse holder to make sure it isn't burnt or corroded causing a poor connection which overheats the fuse.
The main burner (left front) only heats on half the circle.
Your referring to an electric range I'm assuming. In that case the heating element is only heating to a mid-point then stopping. This typically means the heating element is burnt or is partially burned out. The element is usually user replaceable and requires the old one be unpluggude and replaced with a new one. You'll need to get the element from the manufacturer.
Apr 21, 2010 • GE Cooktops
Dryer stopped in mid cycle.
Sounds like you might need a new motor.
Stops washing mid way of cycle
Remove the two screws at the bottom corners. Lift the bottom front out and down to release the top clips. Inspect the belt for wear.
If you need further assistance, let me know
Regards,
reg501
Top Bob Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Bob Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
