Question about Fisher and Paykel GWL11 Top Load Washer
Module RPS and Pump
My Spart Dribe washer fault was traced to Module,RPS and Pump. Is this something that I can repair myself?
    Genius:
  • 1,028 Answers
Huh?? doubt all three are bad pump can be removed and ckd ..lean washer back pump twist locks into tub and hose clamps can be removed with fingers control is under top and rps sensor is behind rotor on washer bottom ckd all connections first
Posted on Jul 17, 2008
GWL 15 fisher & paykel. Fault code 240. Replaced the rps and the motor control board. Regular wash goes through till the spin cycle. Then the fault code activates and stops the machine. If you turn...
Hi Lu here.Did you replace the rps sensor with the same one as you removed? Did you check for corrosion on the plug you attached to the new sensor ? And finally did you get the correct control module? By the way there are different models of RPS sensors.Sorry for the questions but I need to know what has been done.Please reply for further help.Regards LU
Jun 14, 2014 | Washing Machines
Fault 240 wl80t65cw1
240. (11110000) Hall Out Of Order. RPS Fault
Same as previous Hall Error faults See fault code130 for directions.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
Mar 29, 2014 | Fisher and Paykel WL26CW1 Top Load Washer
Rps sensor on my F&p GW712 as the LED 1 & 7 come on and it beeps and I read somewhere that the problem is the RPS Sensor
Fault code 130
yes it is the RPS
Info on fault 130
faulty.
Mar 02, 2013 | Fisher Paykel EcoSmart GWL15
What is error 240 on a Fisher & Paykel IntuitiveEco IWL16 Top Load Washer
240. (11110000) Phase 6 - Hall Out of Order. RPS Fault
Same as previous Hall Error faults, just an extra fault code for Phase
6. See fault codes 130 and 131 for directions.
130. (10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
from the Rotor Position Sensor. Likely causes of this fault are a bad
Action: 1. Check for corrosion on the edge connector of
2. Check the contacts on the rotor positional
sensor end of the hall harness to see if any
have been damaged. (Each set of contacts in
the socket has two wipers. If the distance
between these wipers varies between
different contacts, replace the rotor positional
sensor harness.)
131. (10000011) Phase 1 to 6 - Repetitive Rotor Position
Sensor Error
This fault is similar to fault number 130 above but differs slightly in that
it is a continuous condition.
Oct 02, 2012 | Fisher and Paykel IWL12 Top Load Washer
Having problems with fisher&paykel mw512au washer stopping mid wash
Fault code 240 is RPS
240.
faulty.
May 20, 2012 | Fisher and Paykel Washing Machines
Hi, washer model GWC12 fisher and paykel. machine goes beeps and only long wash and second rinse cycle orange lights is on.tried off power from the wall and follow every steps that is mention in the manual...
It is showing fault code 130 which is a RPS or Rotor position sensor fault, This is located on the motor stator under the washing machine, Most often this is caused by water leaking past the seal and onto the motor. You need to check for signs of leaking or moisture and as long as there isn't any you may get away with just replacing the RPS. Please note that RPS faults can also cause damage to the electronic motor controller module which won't be able to be diagnosed until you have replaced the RPS.
Mar 04, 2012 | Fisher and Paykel IWL12 Top Load Washer
Hello, I have a 10 year old Fisher & Paykel smart drive 9 pride 5.5 clothes washer. Model MW059. When i start cycle, water starts filling and then suddenly stops for a second or two and then repea
That sounds like a bad RPS, you would get fault code 130.
faulty.
Action: Ensure the correct rotor for this phase of machine has been fitted.
Service manual, You will need Adobe reader installed to view PDF's
http://www.angelsnz.net/ZL3SV/misc/F&P%20Service%20manual%20517735.pdf
Feb 13, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fault code 130 - fisher and paykel intuitive iw812
Hi just read your posting.Now Error Code 130 means the fault on your machine is called Single Rotor Position Sensor Error.This means the Rotor Sensor which is located on your motor is faulty or the wiring to the rotor sensor is faulty or the Control Module that reads the information from the rotor sensor is faulty.Now to test the wiring you need an electrical tester to check if the wires going to the rotor sensor are broken but unfortunately to test the Rotor Sensor you need a device called RPS tester.If you eliminate the wires as the fault, which is not too difficult, and change the rotor sensor without testing it the fault could be the Control Module.I am sorry I cant help you test the rotor sensor without an you having an RPS tester.Please reply and let me know how you would like to proceed and I can help you as much as I can .Looking forward to your reply.
Aug 03, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
F Code
the display is showing u something else look for the F then another letter or number. F is not a valid code
Sep 28, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
62 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
