Question about Norelco Advantage 6705 X Electric Shaver
Norelco shaver won't turn off
After replacing the battery, the on/off button no longer works properly. The shaver is always on, pressing the button only causes it to go from a high speed to a low speed, but never off. Seems like it would be a short circuit, but I checked around the solder connections and didn't see any. Has anybody else had this happen?
You should check the switch behind the batteries. You likely dislodged the piece of plastic that presses on the switch. It's simple to place back properly--if that's what the problem is.
Posted on Aug 08, 2008
Where can i take my Braun 6520 to have the battery replaced?
If your shaver works but will not longer hold a charge as long as it should, the batteries need to be replaced. If the shaver is dead and the green indicator no longer illuminates when plugged in, you have waited too long and the circuit board is now damaged and can not be repaired.
For battery replacement, see shaveroutlet.com at the link below
Professional Battery Replacement for Most Models
Dec 28, 2016 | Braun Health & Beauty
Power button broken on Norelco 7825xl shaver - Can't turn on... Button has actually fallen back into the shaver itself, and can no longer be reached to depress - to turn on or off. Help... i love this...
The specific part you need is no longer available. However, the part linked here at shaveroutlet.com will work with your model also. The entire switch button is included. The light display just wont work properly
Philips Norelco Front Body Housing with Switch Button for Quadra 7865XL
Jul 12, 2016 | Norelco Health & Beauty
My batteries were holding a diminished charge, but i usually used razor with a cord, usually left plugged in. green charging light was always on. one day i unplugged cord for a day or two. when i plugged...
It is advised that you change the batteries when you realize that they are no longer charging properly. Most likely, only the batteries need to be changed but it is possible that you have caused further damage due to leaving it plugged in continuously and the batteries may hae become corroded or leaked.
If you decide to attempt to change the batteries, you will fin the correct type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
You will find helpful videos on the item page to assist you in installation
Sep 24, 2011 | Norelco ReflexPlus 6863 XL Electric Shaver
The shaver doesn't work when the button is pressed. I even charged, but doesn't work. Maybe the button is broken, or inside of it is broken.
Ok, it looks like it could be one of two things. Either the battery is not holding a charge after you charge it, which you would know because it will have some power to it. The most likely scenario is that unfortunately the wires that need to connect to make the Cruzer 2 power "on" are faulty and no longer connected properly. You have a few options: 1st, they offer a two year manufacture warranty. I suggest you take advantage of that provided you still have the original receipt. They may even help without a receipt. The other option is to take it to an electronics person who can soder electronics. If you want to do this cheaply or even free check out your local technical colleges. It is worth a shot and either way should be free or inexpensive. Good Luck!
Mar 29, 2011 | Braun 2776 Cruzer2 Shaver Electric Shaver
The battery on my Remington MB70 trimmer is no longer hold a charge. Can the battery be changed to perhaps an Li-ion variety?
The charging system in your trimmer is not designed for lithium ion batteries. Installing a lithium ion battery could cause fire and/or personal injury. You should always use the same type battery that came in the shaver originally
Oct 07, 2010 | Remington MB-70 Beard Trimmer
Norelco 985rx Overheats upon charging..
You should always use the same type batteries that your shaver was designed to be used with. Your shaver was designed for use with NiCd batteries. If you have use NiMH batteries this may be causing the problem you described.
However, I would say that it is more likely that you have some sloppy solder that is bridging something that is not supposed to touch. You should check the battery solder joints on the circuit board and clean up any sloppy solder work that may be there.
Apr 15, 2010 | Norelco Reflex Shaver 5885XL Electric...
The braun 5510 shaver.. rechargeable or not
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
Feb 03, 2010 | Braun Health & Beauty
I own a Braun Electric Shaver Model 6525 Flex Ultra Speed. I plug it in and nothing! I am pretty sure the rechargeable battery needs replacing and I don't know how to open the razor to replace it. Also the...
if the shaver is DEAD and the green light no longer illuminates when you plug it in, the circuit board is almost certainly bad. The circuit board will burn out if you run the shaver from the batteries for a long time after the batteries have stopped charing properly.
you can purchase a new circuit board which has the batteries alrady on it. it just needs to be dropped in place inside the shaver.
you will find this part at shaveroutlet.com. see link below
http://shaveroutlet.com/braun-printed-circuit-board-with-batteries-p-107.html
Jan 15, 2010 | Braun Flex Integral 6525 Electric Shaver
Norelco Advantage 6705 X Electric Shaver Logo
1,898 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
