Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Connecting Hard drive to laptop
I have just bought a Maxtor mini 4 HD and want to connect it to my Apple Mac book. There are two cables marked "Power" and "Data & Power" It says to connect the Data & Power first followed by the Power and finally the other end to the mini 4. The Macbook only has two USB sockets both with the same logo. Do I have to use both of these and if so, which one first? Hope someone can help Thanks
Setback
  • Anthony Gibson Jul 16, 2008
    Thanks Latoof, just didn't want to blow anything up !
    Problem Solver:
  • 14 Answers
Hmmm i think it doesnt matter which goes first or not. just connect them with each socket since they arent marked i dont think it would matter
Posted on Jul 19, 2008
    Sergeant:
  • 287 Answers
I assume that the "2 cables" are actually joined to gether...
Yes just plug the 2 USB connectors in as dirceted.
The USB drive must require more than the 500mA that the USB spec allows for each port. This is a reasonably common solution
Posted on Jul 16, 2008
  • Dave Jul 16, 2008
    BTW since you are connecting the mini 4 pin to the HDD last it really does not matter which order you plug in the USB's to the Mac.
    If you require more USB's for other devices you will need a USB hub... make sure it is a powered Hub (comes with an ac plug pack) though.
  • Dave Jul 16, 2008
    NP better safe than sorry...
I have a maxtor III usb 2.0 500 GB external hard drive. the light on the front goes out and works sometimes. when the light goes out the external drive gets disconnected . i checked for loose connections....
Possibly, the USB is not receiving current enough and occasionally it resets the USB interface. Try connecting it to another system, or to a powered USB host, and see what happens.
Another possibility (but you'd need to disassemble the external enclosure and connect directly the disk inside to a SMART-capable motherboard) is that the hard disk is developing a fault.
Apr 15, 2010 | Maxtor 160GB OneTouch III Mini USB 2.0...
Where and how can I order a 1394 connection cable for a Maxtor personal storage hard drive 3000DV to a Mac laptop?
Amazon.com is a great place to find cables.
Here is a 6 to 4 pin firewire 1394 cable that should be compatable with your HD. It is very inexpensive.
Here is the link to the product!
http://www.amazon.com/4-pin-IEEE-iLink-FireWire-Cable/dp/B000SMZ9E2/ref=pd_rhf_shvl_2
Cheers!
Feedback is appreciated!
Dec 31, 2009 | Computers & Internet
Suddenly my WD external 500GB My Book dropped off my control panel and doesn't respond. I am hoping that it has not crashed. It is not more than 2 years old. It has some pretty important work files on it...
Here are a few things to try. If you have access to a secondary PC or laptop, try connecting your drive to it using a different USB cable. Also try unplugging your drive from the power outlet for a few seconds and then connecting it again. If it's still not being recognized, go to the Seagate site (they bought Maxtor) http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Operating_System_Detection_Issue&vgnextoid=1b734a3cdde5c010VgnVCM100000dd04090aRCRD
This will help with troubleshooting.
If that doesn't help, I would assume the worst and begin working on data recovery to be safe.
Try a free download of Seagate File Recovery.
  • You can preview your disc and file content in a simple hexadecimal viewer which tells you if a successful recovery is possible. You'll know in advance exactly which files can be recovered before you make a purchase.
  • If your files are recoverable, simply purchase the software for Windows or Mac and restore your files. It's that easy.
  • https://services.seagate.com/diysoftware.aspx
  • Oct 18, 2009 | Western Digital 500GB My Book World...
    Cannot get external hard drive to work
    - Make sure that the hard drive (HD) is properly connected to the computer.
    - Try connecting it to a different computer to make sure that the HD is the problem.
    - Check the Disk Management in your computer to see if the HD could still be detected. Once detected, reformat the HD and it should work again.
    To check the Disk Management:
    NOTE: Make sure that the external HD is connected and turned ON.
    1. Right-click "My Computer" (XP) or "Computer" icon (Vista)
    2. Select Manage and click on "Disk Management".
    3. From the Disk Management, you will see a drive letters
    4. Write down all the drive letters and then disconnect the Maxtor HD from the computer.
    5. If there's a drive letter that disappears, then that is your Maxtor HD.
    6. Reconnect the Maxtor HD and reformat it. You may right-click the drive letter and there's an option to format the HD.
    If you're hearing a clicking sound while the HD is turned on, mostly, it's already defective.
    Have a great day!
    Oct 17, 2009 | Maxtor Hard Drive
    Maxtor one touch 4 mini 250GB hard drive beeping
    I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
    I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
    I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
    I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
    Oct 15, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
    How to Connect Maxtor OneTouch 4 Mini 320Gb to PC
    I have one as well running along with a PC. PCs and Macs are formatted differently. Go to www.maxtor.com and create a search for reformatting from a Mac to a PC with your Operating System in the search as well. Should have no problems after doing that. It will tell you and or show you where and how to reformat.
    Oct 01, 2009 | Maxtor OneTouch III Mini Edition 120GB...
    Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
    Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
    May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
    Help with Maxtor onetouch 4
    The Maxtor OneTouch 4 Mini is a portable hard drive, with USB interface.
    What you have to do is, just connect your Maxtor OneTouch 4 MiniT to the one end of USB cable, after that insert he other end to your laptop USB por.
    Wait for few moments your operating system will read your new connected portable hard drive.
    After that you can find a new drive letter in your My Computer, thats for your portable disk drive.
    thanks
    Iqbal
    Mar 10, 2008 | Computers & Internet
    MX6L060J3 (Maxtor)
    If you?ve tried another hard drive with the same results it would seem unlikely that both were bad. The more likely candidate is an error in connecting them or a bad motherboard. Your Maxtor hard drive is an IDE so check the following: - You have two IDE channels on your board usually marked in some fashion Make sure you are connecting the drive to the primary channel. - Are you using Master / Slave or cable select to identify your drives? Make sure you are using the correct cable depending on which system you are using. - Make sure you have jumpered your drive correctly, in your case it should be set as Master or cable select. - If you are using cable select make sure you have the drive plugged into the correct connector, typically it would be marked drive 1. By the way home users should not attempt to take apart hard drives. There are no user replaceable parts and all you?ll do is ruin the drive. Good luck and let us know how it goes.
    Jul 27, 2007 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
    Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
    52 people viewed this question
    Top Apple Computers & Internet Experts
    Paul Carew
    Martin Buck
    Martin Buck
    Paul Bade
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
