Question about Canon PowerShot G2 Digital Camera
Canon G2 'dead' after not using for over a year
My friend has a G2 that has not been used for over a year, and now found that the battery would not charge. He took it to the camera shop to see whether it is the battery. It is not. Taken to Canon service, they say it is the 'circuit board' and will cost US$200 to repair it.
I also have a G2 that has not been used for over more than a year. So I tried to see how mine is -- lo and behold, the same problem. The camera is 'dead'. Checked out that it is not the battery problem.
Anybody has encounted this problem? No sense of fixing it at $200.
We live in Hong Kong.
  • 2 more comments
  • Anonymous Jul 21, 2008
    Canon G2 will not charge, replaced battery, still will not charge
  • Anonymous Aug 15, 2008
    Yes - I have not used my G2 for about a year and I came to turn it on and it is dead! I am going now to a shop to check to see if it is the battery.
  • Anilla Nov 12, 2008
    i tried to charge my camera and afterwards i noted that it still showed that the battery was low. i tried to charge it again and got the same result. Now when i connect it to the charger nothing happens and it cannot be turned on.
  • Anonymous Dec 26, 2008
    same problem here
    Problem Solver:
можно кд
Posted on Jul 16, 2008
If the battery hasn't been used for awhile, it may have lost it's ability to recharge. Go to bargaincell.com and buy a replacement for $8 + shipping. It will be delivered for <$15. Replace the battery and recharge. It should be fine. It fixed my problem. Unless you are leaving the camera in a hot window or a humid shower room, the electronics should last a long time. I've had my G2 for 8 years without electronic malfunction.
Posted on May 27, 2009
Clear mold insides lens of Canon G2/G5
Who found the mold? The lens cannot be disassembled by you. It must be done at a Canon service center and it will be expensive.
Jan 28, 2010 | Canon PowerShot G2 Digital Camera
Batteries go dead
There appears to be an issue with the S2 IS after two years.  See the reviews on Canon's website: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=322&modelid=11368#ModelDetailAct
If yours is two years old then you are probably out-of-luck.  It would probably cost more to repair than to simply replace.  As a work-around, try removing the batteries after use.
Apr 26, 2009 | Canon PowerShot S2 IS Digital Camera
Can't download photos from Canon PowerShot to PC via Zoombrowser
I have used zoom browser for two years to download pictures from my canon powershot SD1000 digital elph. I installed Uniblue updates for speedupmypc and twicker. now my pictures will not download. Is there a connection with uniblue, is it a coincidence ? How can I fix this problem? Scoc
Dec 09, 2008 | Canon ES-E1 EOS Link (4593a006) for PC
G2 PowerShot Power Problem
When you're charging the camera, make sure the power switch is set to OFF. We've run into the same thing- we could plug it in for days, but it won't charge at all if the power switch is on.
Hope that helps.
Jan 09, 2008 | Canon PowerShot G2 Digital Camera
Battery Charging light doesn't flash and battery doesn't charge
I have the same problem. Worked for 3 years and now the battery charges to green but goes dead immediately. I've changed batteries. Its the camera not the batteries. Works fine plugged in. Obviously the cameras are not charging the batteries. Canon must know but I cannot find a fix and warranty is over. I guess buying the expensive camera of the day isnt always assuring you of quality.
Dec 25, 2007 | Canon PowerShot G2 Digital Camera
Canon ZR40 would not turn on
The battery is probably so dead it is using all the power from the wall supply.  Remove the battery, and run only from the wall supply.
Dec 16, 2007 | Canon ZR400 Mini DV Digital Camcorder
Canon powershot G2
I just repaired my Canon G2 with the same symptom.  The internal PCB that you plug the external AC adapter is defective.  The numbers on the board are:
GCMK-M1X
Oct 21, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon SpeedLite 220EX
The two types of Camera refer to the SLR's. I doubt the G2 will support FP flash as it probobly does not have a focal plane shutter like a SLR.
Oct 07, 2007 | Canon Speedlite 220EX TTL Flash
Canon G2 Powershot suddenly went dead
I read of a simmilar problem - a "zoom brush", caused by a faulty part, number CL1-1006-000. Usualy it appears earlier in the cameras career though... Did you try leaving it battery-less for a bit longer than the short changes? Remove it from all possible power sources(There is a small battery inside the main battery compartment) for at least a few minutes. It should reset it in case its just a system crash. Just be aware that after the reset it will ask you to input date and time, and theres another known bug of most of the buttons freezing after inputing date/time. should be fixed by pressing the display button. Hope you manage to fix it somehow...
May 10, 2006 | Canon PowerShot G2 (Black) Digital Camera
Canon PowerShot G2 Digital Camera Logo
516 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
