Question about Canon ImageRunner 1600 Copier
Ir 2000, system error E000
Hi there, i have a IR 2000 canon copier and i have this error msg
"system error E000"
can you help me with that
  • abangganteng Jul 17, 2008
    It worked (resetting). but the problem comes up again. i think its hardware issue.might?
  • 18 Answers
The main thermistor reading does not reach 40°C 14 sec after the fixing
heater goes ON. (fixing low temperature error)
If E000 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*).
Entering service mode: press "aditional function" and after "#(ID)"
Posted on Jul 16, 2008
  • 1 more comment
  • fixyourapp Jul 17, 2008
    you must open the fixing system and see if the thermal switch is in good contact with the fixing roller and the thermistors are in good condition and positon
  • l_g_s_m_2517
    l_g_s_m_2517 Feb 25, 2012
    Gracias, funciona a la perfeccion...thk....
  • jodan_townsh
    jodan_townsh Jun 07, 2012
    Legend!!! You just saved me a $65 call out fee and $450 labour!! Cheers!
Canon iR 2022 gives a system error E000 and error E003, what could be a problem?
how to clear error code e000 please help me copier ir 2022 show me how to clear
May 19, 2011 | Office Equipment & Supplies
I get an Error E000 on IR 1600
hi you have problem with fuser unit may be some time this problem came when yours copier is 220v and you have put in 110v if u dont then u have problen in fuser unit may be broken lamp or thermal fuse thanks
May 12, 2010 | Canon imageRUNNER 2010F Copier
System error
?SYSTEM ERROR E000? you will need to restart the machine. also check printer board connection if still diplayed
Jun 15, 2009 | Canon imageRUNNER 2000 Copier
Canon IR 2016
Additional Functions>2 key>8 key>Additional Functions (each key is pressed seperately, unlike regular iR copiers) Go to Copier>Functions>Clear> Err_ or Err_Clr. An E000 is a fuser code.
Aug 29, 2008 | Office Equipment & Supplies
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Jul 11, 2008 | Canon Office Equipment & Supplies
Technical suport
I have e000 message on my machine IR 1600
Jan 24, 2008 | Canon imageRUNNER 2000 Copier
Copier canon ir 1600
Problem with fixing Unit, simple simulation will help. otherwise need to change fixing unit,, contact ur service engineer
Nov 03, 2007 | Canon imageCLASS D860 All-In-One Laser...
1,280 people viewed this question
old marine
old marine
