Need to reset Sanyo DS25580
The TV was left on Video input, no longer have remote and need to get it back to normal TV input. The Menu on the TV does not give me the option to switch the input. Help!
  • 3 Answers
SOURCE: whana change my sanyo tv to input to play games?
you need a sanyo remote with input button - can buy from www.sanyo.com
Posted on Dec 29, 2007
  • 1894 Answers
SOURCE: my DS25580 tv, I need
if your Tv has a switching panel in front of the unit you can do the functions with out a remote.
else you will need the remote surely
Posted on Jul 16, 2008
likha
  • 790 Answers
SOURCE: Sanyo DS25580
ah ok!
you mean your sensor in TV is not working?
ok ill teach you how to check the remote first... first get a radio and set in AM (amplitude modulation) then try to push the button in front of the AM radio, if you push the button of the remote control in the front of radio AM you can hear a sounds beep beep beep every push you can hear a beep. if you hear the beep sound the remote control is good.... if not its bad....
i hope you rate me as solved in premium thread
thanks!
SOURCE: how do I reset My TV Sanyo DS25580
How do I hook up an xbox 360 to this tv, as there is no video channel?
Posted on Aug 30, 2008
  • 864 Answers
SOURCE: How can I input my sylvania 27"
Here are the instructions for the TV.
http://www.sylvaniaconsumerelectronics.com/pdf/om/6427TE.pdf
They do not say how to select Video or Game mode without the remote. Try connecting a vcr or game to the input and do the Channel Pre-Select process to see if that will pick up the input as part of the Channel Scan. If it does you will be able to get to Game or Video using the channel up/down buttons. Another option is to get a replacement universal remote that has a code for your TV and will assign a button for Game or Video.
Posted on Jul 29, 2009
How can i program my remote control to operate my TV?
You will need to get a programmable remote. The one you have will not work.
Jan 26, 2014 | Televison & Video
My DS25580 tv, I need to find out how to switch the Video Input manualy with out the remote?
Hi just go to menu settings then find the TV System you can see there what system you want
Thanks!
Jul 16, 2008 | Televison & Video
Connected DVD player to Sanyo DS27930 TV via input
According the manual for this TV the remote control has an input button, it is left of the power button. Make sure that the remote mode slected for TV not VCR or DVD and press input button to make a selction, make sure that the power to the DVD player is on. If yours is different try stepping through the channels buttons, some TVs input is selected through the channel buttons.
Jan 02, 2010 | Sanyo DS27930 27" TV
My t.v is on video input and i need to change it back to t.v. without the remote its a sanyo
I had the same problem and had to order a replacement remote off eBay. There are plenty of them on there. The one you want for your TV is: SANYO T.V. REMOTE CONTROL Model FXWC. Search for that and you'll find what you need. Mine cost $15.00 including shipping. There appears to be no other way to do what you are trying to do.
Mike Vail
Windsor, Ca. USA
Jun 09, 2009 | Sanyo DS27820 27" TV
Sanyo DS25580
ah ok!
thanks!
How do I reset My TV Sanyo DS25580
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
Whana change my sanyo tv to input to play games?
Dec 09, 2007 | Sanyo DS31590 31" TV
No Video
From the manual (search Google for CM27101S): Normally, your TV displays the signal coming through the antenna terminal. However, If you?ve connected another component to your TV(such as a VCR) using the Video/Audio input, you will want to be able to view the signal from the component. To do this, you will need to switch from the ? TV ? input to the ? Line1, Line2 ? Input, as follows: 1 With the TV on, press the MENU button twice, then ? Set-Up ? menu will appear. 2 Use the WCHVbuttons to select ? Input ?. 3 Press the CVOLB buttons to change from ? TV ? to ? Line1, Line 2 ?. 4 Wait 10 seconds, or press the MENU button to return to normal TV viewing.
Aug 07, 2006 | RCA F27676BC TV
Televison & Video Logo
253 people viewed this question
Top Televison & Video Experts
Electro Med Services...
