Question about Vacuums
How do I replace the vacuum bag in my Kirby Ultima?
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=790541
Generic problem for all Vacuums
Posted by lunalilo on Jul 16, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There is a cardboard collar on the Kirby bag and all you need to do is to pull off the cardboard collar and replace it with a new bag by hooking the bottom of the Kirby intake and then push on the top part onto the fill tube. You can always check the Kirby owner’s manual under troubleshooting or you can call the Kirby factory listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Hours 8:00 am to 5:00 pm (EST)
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 16, 2008
How to replace filler tube on Kirby G4 vacuum?
first take cloth bag off, held on at bottom with bag clamp, then wash cloth bag in washing machine at 40, inner hose is held on by 2 cable ties top and bottom, your new hose should come with 2 new cable ties, ask kirby agent when ordering, them simply refit.
Aug 25, 2014 | Kirby G4 Bagged Upright Vacuum
Fix for broken tubing leading into filter bag?
You can replace the black tubing. There is no need to get a new vacuum. You can find the parts you need by following the link below.
http://www.usavacuum.com/Kirby-Generation-3-s/145.htm
Make sure to leave positive feedback.
Thanks USAVACUUM.COM
Mar 05, 2010 | Kirby Generation 3 Bagged Upright Vacuum
I broke the zipper on the cloth bag on my kirby gen. 3 can i replace this myself
Yes.
To order Kirby vacuum bags, replacement parts, or cleaning products, please visit your local independent Kirby Distributor, or call:”
1-800-437-7170 United States and Canada
Nov 15, 2009 | Kirby Generation 3 Bagged Upright Vacuum
How do i replace a kirby vacumme bag?
if you look on the back where the bag goes in the vacuum you will see a strap at the end of the bag, loosen the strap and remove the bag
Apr 22, 2009 | Kirby G6 Bagged Upright Vacuum
Belt
go here
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Rob
Mar 06, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G4 Vacuum "BOOT"?
Greetings from GoVacuum,
The bottom part of the bag, which you referred to as a "Boot" is actually called a Kirby G4 Mini Em-Tor with Fill Tube Assembly. Kirby Part # 199493S. The part is only available to purchase with the fill tube assembly, this is the part that the disposable paper bag connects to inside the cloth outer bag.
Kirby has redesigned this fill tube, as the original design sometimes would cause the inner fill tube to crack. The Mini Em-Tor Fill Tube Assembly, part 199493S comes already assembled with the "boot" at the bottom, and the vacuum bag collar (the part the bag actually attaches to) at the top of it. You will need to remove the cloth outer bag from your old part, and put it onto the new "Boot". The cloth bag connects the "boot" with a special zip tie, which is Kirby Vacuum Bag Clamp. Kirby Part # 196599S. Where it is possible to remove the bag clamp without breaking it, I will warn you that this is no easy task. Spare yourself the aggravation of having to try and remove the clamp, and just cut the bag clamp with a knife or scissors.
You will also have to remove the top of the bag collar at the top of the cloth bag by releasing the fill tube from the inside of the cloth bag.
All of the parts are located on our website, www.govacuum.com. If you have any questions about the repair, you can get me on a live help, chat service located in the top right corner of our website. I'd be happy to walk you through this.
Thanks,
Chris Jones
GoVacuum.com
Sep 30, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby G6 without suction
you probably have a clog in the feed tube going from vacuum head to the bag try removing bag and check for clog there hope this helps
Aug 20, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby Sentria
When you replace the outer bag assembly, you have to make sure that it is turned clockwise untill it fully stops. There is a small switch on body of the Kirby that is only engaged when the bag assembly is installed correctly
Jul 07, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby vacuum
There are 2 safety switchs, one on the front that the nozzle activates, and one on the side that the bag asembly activates. The motor brushes and/or armature maybe bad.
Feb 12, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
