Question about Motorola Mobility H700 Wireless Headset
How to pair up headset with cell phone?
How to pair motorola H700 headset with samsung a707 phone?
    Master:
  • 497 Answers
First ul hav to press the button(big one) for a lil while..let the snap b closed...the light wud change to purple...then at the same time set ur bluetooth on the samsumg mobile to discoverable mode....snap open ur bluetooth and in ur mobile it will ask for a pass key which in default is 0000...then it will get connected
Thanks for using Fixya
keep me updated for further assistance
Posted on Jul 16, 2008
  • Yaz  S
    Yaz S Jul 16, 2008
    To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code.
  • myemmitt Apr 18, 2011
    thank goodness for your comment, I have paired this item with other phones in the past with no problem, no luck this time with my new phone, the a777 samsung, and I never had to set it up that way as far as I can remember, but thanks so much for your comment or I would have never gotten them paired. you are a hero. thanks again.
How to use my H700 after charging ?
If tv is bluetooth capable, look under menus and pair with H700.
Phones if initially paired will simply need to have bluetooth 'active' (as by default it is usually off). - If not pair - you will need to go through menus under 'settings' to pair with the H700 (also at this point indicate that the H700 is 'trusted device').
Nov 25, 2014 | Motorola Mobility H700 Wireless Headset
Problem with Blackberry Pearl 8100
Did you try deleting all devices paired and then try pairing again?
May 20, 2008 | Motorola Mobility H700 Wireless Headset
How do i sync my phone with the h700
Hi, Motorola H700 Bluetooth headset is a basic Blutooth headset that can be synced, or paired, with any Bluetooth-capable cell phone. Something unique about this phone is its retractable microphone, otherwise known as the headset's "boom." You can send and receive phone calls hands-free and wirelessly with your contacts using your H700 headset, in one touch of a button.
instructions
Press and hold the "Call" button on the headset for four to five seconds until the LED light glows purple.
Flip open the headset "boom."
Set your phone into "discovery" or "pairing" mode. Open the Bluetooth settings or options on your phone and choose to add a new device.
Select the "H700" on the phone when it finishes searching for Bluetooth devices.
Enter the passkey for the headset, which is "0000," to finish syncing the headset with your phone.
And your done..
Hope it helped.
May 30, 2011 | Motorola Mobility H700 Wireless Headset
Passcode
The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
Hope I helped Dr Reed
Apr 06, 2010 | Motorola Mobility H700 Wireless Headset
Motorola H700 won't pair with LG CU720 phone
You will need to enter pairing mode on your device. The H700 User Manual indicates that you do so by first turning off any previously paired device and opening the headset BOOM. The indicator light should light a steady purple while in pairing mode.
You may not need to turn off your phone if you do not desire this, you may be able to get by turning the blue tooth function off and on, on your phone and attempt to pair again.
Pairing Pin is likely 0000.
Dec 29, 2008 | Motorola Mobility H700 Wireless Headset
Pairing h700 to sanyo s1
After your phone has found the H700 you have to tell your phone to pair with it. It will then ask for the code. Punch in 0000 and confirm. After a little bit the H700 will flash blue several times rapidly and then start blinking about every 5 or 6 seconds. It is then paired with your phone.
Apr 21, 2008 | Motorola Mobility H700 Wireless Headset
Im trying to connect my headset to my phone
how to turn on speakerphone on the Samsung SGH-A707
Mar 08, 2008 | Samsung SGH-A707 Cellular Phone
Pairing
i have a samsung r410 and have the same problem.... im thinkin its the phone....
Oct 04, 2007 | Motorola Mobility H700 Wireless Headset
H700 Headset
Is the Samsung bluetooth turned on?
Jul 17, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
115 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
