I have a philips 55pp model hdtv buit in 10/02. The pic just began to ward this past weekend. I've gone online thinking i need to replace the lamp, however, every place I've called does not have this model tv lamp. It does have a convergence menu, but when I use the remote to manually adjust it, I get lost.what to do? Is it worth fixing? I really enjoy the set.
  • SODAK Sep 02, 2008
    I have the same issue with my 55PP9401 TV. I replaced the convergence chips and now need to do a manual alignment...but can not find the instructions on how this is done. I have pushed the service button inside the TV and see the Grid...but my factory remote does not seem to move any of the lines...Please help!
    Thanks Lance
techman
  • 3130 Answers
SOURCE: rca 52' projection convergence problem
Its a good possibility that your convergence problem could for now be cold solder connections on the driver ICs on the convergence board. The longer you use it the more of a problem its going to surge those ICs till they go bad and maybe cause other componet falure as well. If your not a technician i would have this set serviced asap before it becomes a major repair Good Luck
Posted on May 22, 2006
SOURCE: GREEN CONVERGENCE IS MOVED,I THINK I CAN FIX FROM SERVICE MENU,CAN SOME ONE TELL ME HOT TO ACCESS IT?SAMSUNG PROJECTION TV HCN 4226W.
1. Go to Picture section
2. Scroll down
3. More menu option appear
4. Then pick 'convergence' on the list
5. push remote right key
Then you're at the convergence menu.
Posted on Mar 02, 2008
  • 2322 Answers
SOURCE: Remote LOST - need info on what button to press...JVC AV-48WP30
There might be some features that the universal remotes aren't able to do. To perform the convergence alignment you should have the original remote.
Do you have the user manual or service manual?
The service manual will explain this process better.
Posted on Apr 10, 2008
  • 4 Answers
SOURCE: Sony HDTV Convergence Issue
I have the same issue, on my 60pp9202. It works some times, and then its ok. If I leave it on, it will be ok, until it gets turned off.
Chuck
Posted on May 09, 2008
SOURCE: where can i buy remote control for phillips 55pp9401?
You can access the Intellisense with any universal remote that has a settings button.
TV > Settings > Video > Scroll down to find Intellisense.
Posted on May 26, 2008
Philips HDtv model 51pw9303/17f: It won't turn on... We think its the fuse too but not sure. Can anyone help?
no not the fuse, the lamp is gone replace it if not check the color wheel u need a tech to do this
Jul 18, 2013 | Philips 51PW9303 51" Rear Projection...
I have a philips 60pl9200d/37 the picture is fairly dark even though I've turned the brightness all the way up
The lamp can cause a dark picture if it is defective. There is an access door to the lamp. Take the lamp out and inspect it. Especially at the bottom of the center stem where you may see a bubbling of the glass. If so it is bad for sure. Other problem could be in the main board. For good price on lamp with housing go to pureglare.com and enter the model number.
Oct 24, 2011 | Philips 60PP9202 60" Rear Projection...
I was watching tv this morning and my set made a loud popping sound and the screen turned black. A red light appeared which read lamp and there was a burning smell. I unplugged the tv waited for a few...
The lamp is most likely needing replacement. Replaceing the lamp is a very easy proceedure on that model.I am pasting a pic where the lamp cover is located on rear cover. Remove the screw and the lamp is behind the lamp door.
Jun 08, 2011 | Mitsubishi WD-57734 57" HDTV
Lamp bulb replacment
much cheaper to do it yourself, go online put in your tv's model number and seach for thr lamp and make sure you order the entire lamp assembly, on the back of your tv there is a door open and take out old lamp so you know what you are ordering, and when replacing the new lamp amke sure not to touch the lamp
Aug 12, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Red lamp light on no pic
the power supply has gone bad inside your tv. so wen you take to the manufacture, he will replace the power unit, your problem will surely get solved, thank you,, plz rate me,,,
Jun 30, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Magnavox model 50ML8105D/17 shuts down after only a few seconds and overheat and lamp failure lights come on , I`ve replaced the lamp , but the problem still occurs
We reduced the picture size to 4:3 and was able to get quite a bit more life out of the lamp, without it shutting down. It does take awhile to get use to. But is much better than a dust catcher
Jan 31, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My 60" philips tv
sounds like the LSB board, which is a common fault with your model. You can get a new DPTV 300 series LSB at the following link.
http://servicemanuals.vstore.ca/
Sep 27, 2008 | Philips 60PP9202 60" Rear Projection...
New replacement lamp ty-la 100rl not working
If you place order for Panasonic lamp again this time, I think you would not face this problem as in past you had no problem.
Sep 05, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Televison & Video Logo
112 people viewed this question
Top Televison & Video Experts
Electro Med Services...
