Sanyo DS25580 The TV was left on Video Input thus I can not change the input even wehn I go to Menu. Is there a way to reset it? once again the remote on the set is not working.
  • 790 Answers
Ah ok!
you mean your sensor in TV is not working?
ok ill teach you how to check the remote first... first get a radio and set in AM (amplitude modulation) then try to push the button in front of the AM radio, if you push the button of the remote control in the front of radio AM you can hear a sounds beep beep beep every push you can hear a beep. if you hear the beep sound the remote control is good.... if not its bad....
i hope you rate me as solved in premium thread
thanks!
Posted on Jul 16, 2008
Won't channel up and down, stuck in input mode
Good morning Cheri
try restarting the tv, just disconnect all electricity for 30-60 sec.
connect again. If that does not work, Try set- up on the menu, if you get the apparatus to obey you and leave the input mode.
If that does not work I always restart the router and "exchange"box,
enjoy your day
kolbrub
Mar 25, 2014 | Sanyo DP50749 50 in. Plasma TV
My DS25580 tv, I need to find out how to switch the Video Input manualy with out the remote?
Hi just go to menu settings then find the TV System you can see there what system you want
Thanks!
Jul 16, 2008 | Televison & Video
Sanyo TV 27 inch stuck on Video mode. It reached this mode by me pressing the input button on my (GE) Universal remote, not knowing it would put it in Video mode and then accidentally pressing enter to...
Universal remote alway work only the basic for the tv.Beyond that will have problems or stuck in some input or modes.Sorry i can't help u, because i don't know what is the reaction to ur tv by the universal remote,must use the universal remote again tries all the buttons like video modes or input botton.Or take the battery out like 20 mins of the universal remote to erase ur tv codes enter it again.Tries those buttons u pushes before,see if u can get out the video mode.All else fail.Try website like Remotes.com to buy the tv original remote to use.
Jan 20, 2011 | Sanyo DS31520 31" TV
I have a sanyo tv. Slightly older. Not hi-def or New
Hi:
This may be due to the possiblity that the you are on the wrong input source, If you watch HD Channels then the input source would either be componet or HDMI input. Try changing the input source of the television with the TV's remote until you see the Channels again. IF you are not watching HDTV then the television is on the wrong reception channel for the Direct TV's box. Try channel 4 or 3 or even 73.
May 06, 2010 | Sanyo AVM-2509S TV
How do i get to video mode without original remote
you should have an input button. if so press the button until you get to the input that your dvr/vcr player is on. if you do not have a input button got to the menu button and you should be able to change the input thru the menu.
Jan 11, 2010 | Sanyo AVM-2759S 27" TV
Connected DVD player to Sanyo DS27930 TV via input
According the manual for this TV the remote control has an input button, it is left of the power button. Make sure that the remote mode slected for TV not VCR or DVD and press input button to make a selction, make sure that the power to the DVD player is on. If yours is different try stepping through the channels buttons, some TVs input is selected through the channel buttons.
Jan 02, 2010 | Sanyo DS27930 27" TV
How do I reset My TV Sanyo DS25580
How do I hook up an xbox 360 to this tv, as there is no video channel?
How to record from my Sanyo DTV to my Sony Recorder?
first have the video recorder connected to the tv correctly,either coax out, red.white,yellow out, componant out or hdmi.[ see on back of the unit & the tv which connection you used.input selector is also known as video/source/line in or aux, sometimes even game. if there no such button on your remote, scroll down from channel 2 and you should be in some aux input.have the dvd playing,then you should see the video when you get to the right input.
wg
Feb 17, 2008 | Sanyo DP26746 26 in. LCD Television
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
Whana change my sanyo tv to input to play games?
you need a sanyo remote with input button - can buy from www.sanyo.com
Dec 09, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
182 people viewed this question
Top Televison & Video Experts
