Question about Canon PIXMA MX310 All-In-One Printer
Canon mx310 my faxes don't print out they get stuck in the memory
My computer has a flashing message recieved in memory black ink low - recommened new c-crt. I cant recieve any faxes
  • 6 more comments
  • Anonymous Jul 16, 2008
    Same problem
    Everything else prints but not the fax in memory
  • eddietz Aug 08, 2008
    How do I clear the memory ?
  • newcoast Sep 09, 2008
    FAX stuck in memory. How can I down load it?
  • ninagenato Nov 18, 2008
    i recieved a fax and it will not print. it says fax in memory, how the f do i print it, its a very important document.
  • L-maried73 Jan 13, 2009
    My printer says recommend new c-crt. What is c-crt?
  • Anonymous Jan 20, 2009
    All faxes are received in memory and need to be manually printed, then deleted. Is there a program to view and delete faxes on my computer instead of using the built in navigation?
  • Anonymous Jan 21, 2009
    s a comment to megapropsm's canon mx310 my faxes don't print out they get stuck in the memory problem,
  • Anonymous Apr 01, 2009
    Changed the color cartridge out and it still says low ink, reset everything in menu on printer in software, still no luck. Also the In use memory light will not go out.
I think it means that you must have a new colourink cartridge.
Posted on Jan 19, 2009
Change the ink cartidge
Posted on Jul 19, 2008
After faxing I get recom. new c-crt. What sure I do? cj
Posted on Nov 08, 2008
Replaced cartridges and machine still shows low ink. need to retrieve faxes in memory
Posted on Feb 04, 2009
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Hi, I got a message: received in memory - recommend new b-crt
The b-crt is the black ink cartridge, when you put in a new one, it will print the fax for you.
Jun 22, 2009 | Canon PIXMA MX310 All-In-One Printer
Low ink message with incoming fax, no fax but printing works fine
Unplug the machine for 3 minutes and plug it back in. sometimes this will reset everything. good luck
Feb 04, 2009 | Canon PIXMA MX310 All-In-One Printer
Cannon MX310 - Fax - Waiting for report
I had the same problem.
My INK Level was Low and I had the setting "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink OFF", and so the report would not print due to the ink level being low.
Solution:
Configure "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink to ON", and the report will be printed immediately, and the message will disappear.
Jan 20, 2009 | Canon PIXMA MX310 All-In-One Printer
My Cannon Pixma MX310 has "received message" in fax, but I have refilled cartridges and the printer says "ink low", I would like to print fax messages in the machine, or is there any way I can look at them...
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Jan 07, 2009 | Canon PIXMA MX310 All-In-One Printer
Ink is low unable to scan/fax
I had the same problem. I had just installed new black ink cartridge and had the same problem "CHECK INK" and alarm light is on. My color ink had just runned out. I was just about to go buy the color ink to see if it would fix the problem but decided to try it one more time. This is what to do..Click on the print command and a cannon message will pop up saying that you have no ink (it being the black or the color) then you will get the CHECK INK message all you have to do is PRESS the "Stop/ Reset" button for atleast 5 seconds and it will let you print..
Dec 22, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon mx310
Canon cartridges have an intelligent chipset to prevent them from being refilled. To have them working properly you need to reset the chipset.
Try the software on this link.
If the above did not work you will need to use a cartridge chip resetter if you want to refill your cartridge.
Jun 06, 2008 | Canon Pixma MP500 All-In-One InkJet...
My canon mx310 wont allow me to send a fax, it says 'waiting for report' when i press send.
I have the solution for this problem. You need to go into your fax settings, and adjust the RX Settings. There is an option there to "print if no ink" and you set that to YES, and it will spit out the pending report that is preventing you from sending faxes.
May 25, 2008 | Office Equipment & Supplies
Received in Memory issue
=) SOLUTION!!! To print from memory, simply press the "FAX button on the front panel.
Then, press the "MENU" button. "1. Fax Settings" will appear in the display. Press the
"right" arrow key once so that you get "Memory Reference" to appear on the screen.
Press the "OK" button once. It will display "Print List", but you want to "Print Document",
so press the "right" arrow key until you get to "Print Document" and press "OK."
Once you are there, press "OK" again and the message "Print 1st page only?" It displays a YES and NO, so hit the left or right arrow key to choose. If you want to print the entire document,
choose NO and press "OK" Your document will print out!!! =)
Feb 10, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
2,818 people viewed this question
old marine
old marine
