Question about Sharp 56DR650 Television
Sharp 56dr650 Won't turn on, error code>
I have a Sharp 56dr650 and it won't turn on. When I try to turn the tv on it blinks 3 green and then 2 red. What is wrong with the tv, and where can I order the part to fix it?
  • lenon May 11, 2010
    SpawnKiller, which samsung model did you use?
Remove color wheel,seperate from bracket open and lube and clean motor will work fine
Posted on Sep 04, 2008
  • spawnkiller Sep 04, 2008
    if your looking for color wheel go to discount-merchant.com...and look up samsung color wheel i know its a sharp but the color wheel at 69 dollars works fine ...dont be fooled my colors on there when you place your color wheel on white surface they will look the same ...i gambled and bought color wheel...and fixed problem....
    will also work on 56dr650 and 65dr650...my motor was noise at first...and i mean loud to the point of not turning on ....so look it up and you will fix your problem
  • 103 Answers
Please check the lamp
Posted on Jul 17, 2008
2 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Posted on Jul 31, 2009
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
My Sharp 56DR650 LED Blinking
Check the number of time it blinks. that is the error code and compare it with the problem listed in the owners manual. see www.fixurtvs.com. The code 32 means the color wheeel is getting stuck. You can try to clean it and put it back or look for a replacement. Repairs should cost you 350 to 450 at shop and 150-250 at home subject to the availability of parts. Cleaning it just a stop gap measure and not a lasting solution. dont worry if the wheel opens up into two with black dust inside. Just clean it put a drop of light machine oil like sewing machine and put it back. there will be hum but the wheel works for months and maybe a year. it varies from tv to tv and quality of your workmanship.
Jan 24, 2010 | Sharp 56DR650 56" Rear Projection HDTV
Sharp lc-22sv6u won,t power on. no green light.
Jul 31, 2009 | Sharp Aquos LC-22SV6U 22 in. LCD EDTV
Sharp 56DR650 won't turn on
the 32 message indicates lamp issues. Buy a new lamp with new cage and that should fix the problem.
May 30, 2009 | Sharp 56DR650 Television
Sharp 56DR650 shows power but wont turn on, Sometimes it turns on
That's error code 32. Indicates lamp trouble or failure. The system will shut down automatically.
Aug 29, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Sharp DLP No picture
i have a 56DR650 and it does them same thing. It is still under warranty but where i bought it, they said they can no longer fix it so they are giving my money back. the problem has to do with the color wheel inside.
Oct 31, 2007 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 56DR650 Television Logo
734 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
