FixYa.com
Tags:
GE Profile Spectra JGBP79 Gas Kitchen Range
GE Profile Range on the fritz - HELP!
By pandamama - usenet poster
Hello Handi Folk,
I have a GE Profile gas range (JGBP79) and the oven suddenly tired of
heating up. Top burners work fine.
This has a bake and broil (below and above) burners in the oven each of
which has an electronic igniter (no pilot) which appears to be a heating
element itself (not a spark igniter like the stove top burners)
Does anyone know if (and where) there is a fuse for the two igniters or
other reason for both burners to fail at once?
I suppose it's 'possible' that I've been surviving on the upper (broiler)
burner only, not noticing the oven being slow to heat and so the problem
'could' be the igniter(s) but at $68 each +shpg  (on the GE website) I'm not
eager to experiment.
any more plausible theories?
Many thanks in advance
Martin
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 11, 2005
Not Rated (0)
Powe33
Powe33 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
You might call around the appliance parts stores in your area and see if
they have the repair book for this stove? cost should be about $15, well
worth the price.  Ask the people there what is the price for the parts
you want and how to test it, they answer alot of questions like this all
day long.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Ross
Ross - usenet poster
Rating: 0%, 0 votes
On Wed, 21 Mar 2001 18:32:48 -0500, "Martin Fraser"
The ignitors work independently , make sure the broil wont work.
If the broil works on"broil" it is probably the bake ignitor.
  Since the upper (broil) ignitor and bottom (bake ignitor) went out
at the same time, it is doubtful that the ignitors are bad.
That leaves either the thermostat or the gas saftey valve.
If your handy with a volt/ohm meter you can check for voltage at each
component, if you have voltage to that component and it dont work,
its bad.
Good luck, and let us know how you make out.
Solution #3
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rating: 0%, 0 votes
Try searching or posting your question on:
http://www.psaworld.com/techbo ard/tboard.html
A bunch of people who are quite informed on the subject of appliance repair.
I would be surprised if you did NOT find your answer here.
Good Luck
Frank
Solution #4
Not Rated (0)
Grant
Grant - usenet poster
Rating: 0%, 0 votes
I had a GE oven suddenly quit on me. I called the GE number and they said to
'reboot' the oven by unplugging for 15 minutes. I was skeptical, but I tried
it and it came back to life!
hope that helps
Can you Help with these Kitchen Ranges problems?
trim around the control panel
has anyone had a problem with... Answer This...
GE Profile Spectra JGB920C Oven...
I think the subject line well... Answer This...
Staying heated
I have a GE gas oven and each... Answer This...
Digital Display Doesn't Work
My control panel doesn't work.... Answer This...
Can't get to ignitor
I read this thread and found my... Answer This...
Repair Service
Find Kitchen Range Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
