Question about HP iPAQ RZ1710 Pocket PC
Pda ipaq 1710 not starting up
Reset my pda it goes to the start up screen but does not continue please help!!!!
  • Anonymous Nov 18, 2008
    same problem. hang. no software, where can i get it?
  • Anonymous Jan 19, 2009
    same problem. Apparently the unit has to completely run out of power (could take months ... mine took about 6 months) before it will reboot. So one solution is to wait it out .... which isn't much of a solution .... but it's cheap!
Press the 1st and 4th button on the shortcut menu on the front and press the reset button. This will go through a complete hard reset and deactivate the battery. IT will take your PDA back to factory default mode. It saves you a lot of trouble. GOOD luck. If my explaining it to you didnt help then google "complete reset pda ipaq 1710". :)
Posted on Jul 20, 2009
Try usb sync and reload hp companion software
Posted on Aug 22, 2008
When I connet the Ipaq 2490, teh screen lights up
press & hold power, press & hold calender, press & hold mail, press & hold reset small hole at base of unit, screen will blank, device will now hard reset.
Oct 13, 2009 | HP iPAQ HX2490 Pocket PC
Tip
HAD RESET HP iPAQ rz1700 Series (1710 / 1715
While holding the far left (Mobile Media) and far right (Today) buttons, press in on the reset button (reset hole) on the bottom for about 2-3 seconds. To verify that you have hard reset you device, press the power button. If the device does not turn on then you have successfully hard reset you device. To reactivate the PDA, either connect the device to the AC adapter or press in on the reset button.
on Mar 10, 2010 | Cell Phones
Screen align problem
try to do hard reset if its not works
try to update rom image
if still not works try to replace your touch screen to new one
Dec 15, 2008 | HP iPAQ H3950 Pocket PC
My screen is all white will not do anything else
Try to hard reset : Hold calendar, iTask and reset button like for 10 seconds.Warning! It earses every data on your PDA, but if you want to save it ... ;)
Apr 25, 2008 | HP iPAQ H5550 Pocket PC
Hp iPAQ h1945 won't start
Hello and sorry for the delay.
the h1945 series is a very intresting pda. I have seen all sorts of problems relating this one. There are some things you may want to try. Based on that knoledge I may be able to find what's rong with your unit.
First, check if the back cover fits tight on the back of the unit. It's important because on some ipaq models, there is a small micro-contact that doesn't allow the unit to power on if the back cover isn't attached. I'm not sure if the 1945 has one, it's been 2 years since i've last phisically repaired one of these, but you may look for one yourself. It's a small contact near one side of the back opening, check to see if it can be pressed. If you don't have anything like this just ignore this tip.
Second, leave the pda connected to the charger for about 6 hours. Even if it doesn't do anything. Then try to start the bootloader by pressing the 2 outer keys near the D pad (simillar to the hard reset procedure) then, while keeping those pressed, press the power button and in the same time press the soft reset button with your stylus. You must do this with your charger connected to the pda. It may be difficult to achieve in the first try. Just try to do this a few times and if the pda doesn't respond even now, please post back. Furthermore, if you need more info about these 2 tips please reply.
Mar 21, 2008 | HP iPAQ H1945 Pocket PC
Rx1950 freeze on soft reset
You can do a hard reset by doing the following...
01) Press and hold down the "Calendar" and "iPAQ Wireless" buttons.
02) While holding down these buttons, use the stylus to lightly press the "Reset" button/hole on the back of the iPAQ until the screen goes blank.
03) Release the "Calendar" and "iPAQ Wireless" buttons.
04) Press the "Reset" button/hole again (so that it resets/powers on.)
Nov 01, 2007 | HP iPAQ rx1950 Pocket PC
HP IPAQ RZ 1710
try to connect to ur PDA harddrive where u have uploaded those files via ur PC sync conn. and delete them
Sep 09, 2007 | HP iPAQ RZ1710 Pocket PC
Pda delete information
Hi, most iPAQs have a soft reset at the bottom right which can be pressed with the use of the stylus. also, there is a hard on/off switch (which erases most info) on the bottom left inside a small/narrow slot/hole. A far more detailed instructions may be found at the manufacturer's website as well as the manual(s) that you probably need. http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?&lang=en&cc=us&prodTypeId=215348&prodSeriesId=420454&lang=en&cc=us Hope this be of some help to you. Good luck.
Apr 25, 2007 | Compaq iPAQ H3630 Pocket PC
Ipaq RZ 1710 won't switch on
If you've backed up your PDA, I'd strongly suggest trying a hard reset. This has happened before to one of my RZ1710 pda's. The only solution was to hard reset it. This can be done by pressing the two extreme left and right buttons (The Calander, and Home button) and the reset button on the bottom of your iPaq with the stylus.
Sep 11, 2005 | HP iPAQ RZ1710 Pocket PC
HP iPAQ RZ1710 Pocket PC Logo
1,170 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
