Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Belkin router have you gotten your router to work with xbox live yet and if so what did you do?
  • stickman39_2 Jul 31, 2008
    no need to worry i returned it and got a lynksis now it is flawless
Change the U PNP settings, worked for me
Posted on Jul 31, 2008
My son cannot access the internet on his xbox one through my Belkin router
The network settings on the Xbox One are on this page.
http://support.xbox.com/en-GB/xbox-one/networking/network-settings
You must be able to select the Access Point (Belkin Router) and put in the password.
You should be able to see the connection is live or not from the same page on the Xbox.
On some routers you also have to make special instructions to allow the Xbox to have Internet ports put through to the Xbox one.
Network ports used by Xbox LIVE
Jan 21, 2015 | Belkin Computers & Internet
Xbox live
Some modem have built in router.So in my case i have hughesnet hn 9000 modem so what i did is connect my modem to a switch and from your switch connect to your xbox live. so buy a switch.
Feb 14, 2010 | Belkin (F5D7230-4) Router (587009)
Have belkin wireless router and it's not working wireless nor can
Log in to the router and just lower the firewall, that should do it.
Apr 07, 2009 | Belkin Computers & Internet
How do i find my WEP key, I have a Belkin 54g router
hi im an xbox live support representative
you could actually just call your router manufacturer so they can provide your'e wep key
if you still have some issues just call xbox customer support
thank you
Jan 31, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Xbox Live Can't Connect to Friends
Hi akemccarthy
you may need to open the ports for the linksys Router aswell
because the linksys links the belkin to the internet there using a shared connection
once youve fowarded the ports properly check to see if you have enabled the UPNP on both of the routers if they have any
heres a website showing how to port forward the ports you need opening
http://portforward.com/routers.htm
Dec 18, 2008 | Microsoft Xbox 360 Console
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
Keep getting kicked off xbox live
You should reduce the MTU of your router. You can simply call Belkin support for them to assist you on how to reduce the MTU.
Oct 26, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin F5D9230-4 router with xbox live
I was having troubles with a belkin router as well. i called belkin tech support and they never helped as they would not accept that the router was the problem. i found i could connect the xbox directly to a modem and it would work fine but when i connected it through the router it would always disconnect from games or not allow me to join a game, only host them, with no one else joining. no matter if i forwarded the appropriate ports, put the specific ip address into the dmz or even turn upnp on (i've tried different combos of each, all on at same time, to even setting up manually) and nothing would change. I found that the router had an option to turn off NAT which belkin told me would render the router useless.  I decided to go against them, turned it off and set the ip and dns to go with the modem. Now everything works fine as the router just acts as an expensive multi plug and wireless system. all the computers in the house can connect to the internet at the same time and access eachothers hard drives and i can access xbox live fine with no problems. there is also no lag when playing gtaIV multiplayer with 15 other players.  i hate belkin tech support and i will not pay for another expensive multi plug connector from belkin... ever.
Mar 06, 2008 | Belkin (F5D7230-4) Router (587009)
XBOX Live problems with Belkin N1 router
I suggest setting this up with a WPA encryption rather than WEP encryption. This should get ya setup without a problem. Also, I've noticed live to be a bit buggy since Christmas. If you continue to have troubles after trying this call 800-4my-xbox. The recording will tell you if they are having network issues.
I bet this helps!
Dec 31, 2007 | Computers & Internet
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
48 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
