Question about LG KG800 Cellular Phone
Can't connect I tried to connect my phone and my computer using USB port given in the box. It always stops and the say "Initializing please wait" but nothing really happened until I clicked OK. Anything is wrong with my cort? It is HOT after plugged in a little white. Thanksss for help
    Master:
  • 848 Answers
Just try with other ports ........also check whether your port is being protected ( locked )
Posted on Jul 16, 2008
GhELLO : I NEED TO DO UPDATED THE BIOS FROM USB PORT?
The USB ports are controlled by the OS. Try the following:
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
Aug 04, 2011 | Sony VAIO VGN-AW330J/H Notebook
I can't get the Notebook to recognise that a mouse has been plugged into the mouse port. I have found out how to disable the touch keypad FN and F9 but not how to enable the mouse.
You may need to refresh the USB ports. Follow the instructions below. You do not have to disable the touchpad to use an external mouse.
Mar 25, 2011 | Advent Netbook
One of the USB devices attached to this computer has malfuntioned...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Mar 12, 2011 | Magicard Avalon Card Printer
My memerysticks stop working when i put in i cannot see my my home work on screen
Thanks, Joe
Mar 12, 2011 | Computers & Internet
One usb port of the two on the left side of the acer aspire one 532h just stopped working. Is there a driver or a diagnostic that I can perform?
Thanks, Joe
Feb 19, 2011 | Acer Computers & Internet
My computer doesn't appear to be communicating with my printer. I am utilizing a usb cable and port. Is it possible that my printer USB port or modem isn't operating correctly??
Thanks, Joe
Feb 01, 2011 | Samsung CLP 300 Laser Printer
RCA pearl 1602-A won't register when plugged into USB port.
When my computer wouldn't recognize my Pearl, these are the steps I followed after downloading the firmware upgrade from http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1
remove the battery,
start the program,
hold the play button while plugging into usb,
release the play button when the term "initializing" replaces "searching",
click the start button to replace the firmware.
You might want to try leaving the "format data" box unchecked the first time. If that doesn't work and allow you to backup your music, bite the bullet and format the data area.
After I did this, my pearl started normally, and my computer recognized it again. It also fixed my aac-error problem.
Jul 02, 2009 | RCA TH1602 MP3 Player
Cant use my usb
Refresh and reinstall USB Ports Of Your Computer Hello there, the other day i tried refreshing and reinstalling the USB ports on my PC, as some of my connecting devices are not recognized. I present the detailed procedure on refreshing the USB ports.
Let’s go!!
Here are the steps to refresh/reinstall/uninstalling the USB ports on the computer.
The USB port needs to be refreshed to make sure that no other device has captured the USB port of the computer. The Mouse, video camera, your external USB hard disk; what ever it may be.
3. Click the Device Manager Button.
Now connect the USB devices like mouse, video camera, your external USB hard disk...USB hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main USB devices at the rear end USB port. As they require more power to initiate.
The above steps are for XP operating system. When coming to the matter of Vista, please note the changes below:
1) Right-click Computer icon from the desktop , and then click Properties to open the System Properties window, and then select the Device Manager tab.
2) Click the Plus (+) sign next to Universal Serial Bus Controllers/Root hub.
3) Click the USB Composite Device entry to highlight it, and then click Remove. If a screen appears to confirm the deletion, confirm the deletion.
4) Disconnect the USB cable to the all-in-one, wait a couple seconds, and then reconnect the cable. This should restart Windows device detection (Plug and Play).
5) A New Hardware found screen may appear, click next through all of the screens that appear for the Wizard to install the USB Composite Device. Click Finish once the wizard completes.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | Toshiba Satellite M35X-S311 Notebook
USB Connection issues
Try your camera on another computer. This will illiminate any issues with the camera's USB port, or its set-up.
I would think you tried other USB ports on the computer.
Another thing to look at is in the set-up of the camera, that the USB port from the camera is set to work as a vertual drive if this is what you want.
If you are using the camera with its own computer software utility and using it as an intergal operation with its software, there may be a set-up issue with the software, or there may be some corruption in the software installation. This can also be a corrupted driver.
An easy way to get the photos out of any camera is to invest in a USB card reader that is compatible to the memory card in the camera. You can remove the card from the camera and put it in to the reader to download the pictures to the computer. The card would appear as a vertual disk on the computer.
Jerry G.
Apr 12, 2008 | Sony Alpha DSLR-A100 Digital Camera
Mobile not working on p.c
uninstall then reinstall the cd software for the mobile on to the pc then install usb drivers....hopefully you are working with a winxp pc and not vista...vista is to problematic.
Dec 31, 2007 | Motorola Mobility RAZR V3
LG KG800 Cellular Phone Logo
29 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
