Question about Microsoft Windows Server Standard 2003 for PC
Solution I have a win2k3 server standred ed & xp client. client machine are slow
  • Tim Babcock
    Tim Babcock May 11, 2010
    Can you elaborate as to what is slow?
Increase your virtual memory in xp client machine,,
im desingh from india,, contact me +919791122322
Posted on Jul 16, 2008
  • desingh Jul 16, 2008
    very nice,,
Tally erp 9 working slow
you have not mentioned the networking involved .?
how are the clients networked to the server ?
Are you using a switch or a hub ?
Are you using a fast ethernet connection 100 Mbs or 1000 mbs into server from a network switch ?
How fast ? 10 mbs will cause problem on five client machines sharing 10 mbs into a server
Jul 07, 2017 | Microsoft Windows 7 Home Premium 64BIT...
Tip
Get Faster Internet Broadband
we all know our board band provider don't give us the full speeds we are meant to get but this is proven to give ya internet a boost
this ones simple:
this is for broad band connections. I didn’t try it on dial up but might work for dial up.
1.make sure your logged on as actually "Administrator". do not log on with any account that just has administrator privileges.
2. start - run - type gpedit.msc
3. expand the "local computer policy" branch
4. expand the "administrative templates" branch
5. expand the "network branch"
6. Highlight the "QoS Packet Scheduler" in left window
7. in right window double click the "limit reservable bandwidth" setting
8. on setting tab check the "enabled" item
9. where it says "Bandwidth limit %" change it to read 0
reboot if you want to but not necessary on some systems your all done. Effect is immediate on some systems. some need re-boot. I have one machine that needs to reboot first, the others didn't. Don't know why this is.
This is more of a "counter what XP does" thing. In other words, XP seems to want to reserve 20% of the bandwidth for its self. Even with QoS disabled, even when this item is disabled. So why not use it to your advantage. To demonstrate the problem with this on stand alone machines start up a big download from a server with an FTP client. Try to find a server that doesn't max out your bandwidth. In this case you want a slow to medium speed server to demonstrate this. Let it run for a couple of minutes to get stable. The start up another download from the same server with another instance of your FTP client. You will notice that the available bandwidth is now being fought over and one of the clients download will be very slow or both will slow down when they should both be using the available bandwidth. Using this "tweak" both clients will have a fair share of the bandwidth and will not fight over the bandwidth.
on Jan 27, 2009 | QuickStart PC Cleaner XP (798936829016)...
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on...
So you verified ICMP traffic isn't blocked and it appears the servers allow the netBios traffic to pass.
On the client machine, check to make sure the windows print and file sharing is installed and the machine isn't blocking netBios traffic.
Make sure TCP ports 137,139, and 445 are open on the xp machine and any devices in between.
It's acting like the TCP data is being blocked by the client machine.
HTH,
-Aaron
Sep 28, 2009 | Microsoft Windows XP Professional
Tm-t88iv epson made prnter driver for win 2003 server r2 std
Epson POS driver will not install on a Win2K3 machine due to the InstallShield Wizard w/c checks if your running XP/2K or not.
Download the driver from EPSON POS site & extract the contents first on an XP machine.(Installing the driver will create a C:\Epson folder where ACTUAL driver is extracted).
Dec 24, 2008 | Epson TM-T88IV Label Printer
Epson TMU220 driver para Windows 2003 server, para utilizarla con el Terminal Server
Epson TMU220 driver will not install on a Win2K3 machine.
Download & extract the driver first on an XP machine.
Dec 08, 2008 | Epson TM-U220 Matrix Printer
Error code 0x0000232B RCODE_NAME_ERROR
http://www.annoyances.org/exec/forum/win2003/t1165771257
Jul 14, 2008 | Microsoft Windows Server Standard 2003 for...
Diffrences between win 2000 & win 2003 ?
Hi Sir Nice quition see what is the diffrences between win98 and XP u know sir ''''''''''' see below
********* win2000server and 2003 diffrence men Security and advanced server Tools is their ok byy*********
Apr 18, 2008 | Microsoft Windows Server Standard 2003 for...
Problem to login in win2k3 server with win xp server
Check to see if the xp clients are part of some GPO. Test and see if you can login with only one station by removing that object out of the GPO. If it works... then it means that the GPO that the XP clients are apart of is configured incorrectly.
Feb 26, 2008 | 3Com OfficeConnect 56K Business Modem...
Windows xp pro oracle 8i database access very slow
check your computer comfiguration check the ram for memory
Nov 28, 2007 | Microsoft Windows XP Professional for PC
No working drivers for Belkin f5d7000 on win2k3
Most drivers for any software or hardware are usually only backward compatible so many "back" versions and will not be supported and can not be guaranteed by any company.  That is simply a "fact of life" with all products in the computer industry.
Time to update your win2k3 machine to the newest and latest.  We all have had to do it at some time or other.
Oct 20, 2007 | Belkin (F5D7000) 802.11g/b Wireless...
Microsoft Windows Server Standard 2003 for PC Logo
61 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
