Question about Cobra 25 LTD 40-Channels Base CB Radio
Af audio power amp
In the old cobra ltd`s they used TA7222AP with pins 7 n 8 soldered together, I have a new version of this radio and has a output with YD1022 stamped on it, with pins 9 n 10 soldered together, pins 7 n 8 soldered together , pins 5 n 6 soldered together, ? is this output YD1022, the same as a TA7222AP,
  • 90 Answers
On the YD1022 the pinout is: Corresponding pins on the TA7222 :
1,5 & 6 are ground 3, 7 & 8
2 is audio input 4
3 is feedback 6
4 grounds through a capacitor for frequency compensation 5
7 & 8 are audio output 9
9 & 10 are +12VDC VCC 1
The TA7222 also uses pin 10 for feedback & freq. comp. The circuits are very different & would need to be redesigned to interchange these chips.
Posted on Sep 26, 2008
I have a cobra power mic that has no audio output
Sounds like its not wired up right, the audio wire must be off,take the plug apart and check the white wire, re-solder it. here is the wiring, pin1-shield,pin-2audio-(white), pin3-transmit-(red), pin4-receive-(black).....hope this was helpful...
Apr 23, 2010 | Cobra 29 LTD CB Radio
Receive distortion
Try your tune knob and your clarifier knob.....hope this helps
Mar 12, 2010 | Cobra 29 LTD CB Radio
Low transmit audio cobra 29 ltd nw
Are you talking about this radio or what others are hearing from your radio?
My friend, no one but the holder of a 1st class FCC radio license is permitted to adjust the input power to the final amp. Further, one needs some pretty technical equipment to accomplish this fine tune adjustment. Failure to properly set this envelope will result in degraded operation and possible failure of your radio.
If you can't live with the present circumstance, get your radio profesionally repaired.
Thank you for your quesiton at
Jan 06, 2010 | Cobra 29 LTD CB Radio
Radio 29 ltd no modulation, no receive and good carrier, no capacitor shorted or blowm,changed ic audio by a new one and get still the same problem
did you change IC4=TA7222AP ?
check input ic4 pin1 is it supply voltage?=12vdc.
check C48 couple cap,also check C39 replace
with a 25 watt and C42 also C45.
check R130 1.1 ohm. also R121 180 ohm.
if pin 1 on ic4 is low volt or missing,check TR23
and D22,C119
maybe this will help some
Sep 28, 2009 | Cobra 29 LTD CB Radio
Af audio power amp
Just because the chip is warm doesn't mean it's bad, especially if it seems to work fine otherwise. Do however make sure that the device is properly heatsinked, and inspect the work done in the process of any modifications. If for some reason the device is self-oscillating it could do so at a frequency above hearing thereby going unnoticed. That will cause the device to overheat, and also make modulation weak and the RF to splatter out of band. You'll have lots of power on the RF wattmeter, but people can barely hear you if that's the case.
May 29, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 29 NW ST No Sound, litesup, keys up, needle swings
It sounds like it may have been hooked up backwards when hooked up to the battery charger. If so it probably blew the polarity diode (D23) (1N4004) and with no sound it probably blew the audio IC (TA7222AP) mounted to the case of the radio. Also look at all of the large capacitors and make sure that the tops are not swollen or busted open if so they need replaced also.
Dec 28, 2008 | Cobra 29 LTD CB Radio
No receive cobra 29 ltd classic
Hi and welcome to FixYa,
Initially, pls confirm that there is modulation (transmit audio). The reason I asked is if IC4 (TA7222P) is blown, then the radio would have no audio amplifier which would explain no receive audio. Additionally, the final and pre-final (TR15 & 15) gets is modulated TX+12 through D8 from T1 which in turn is the output of IC4 through C48.
Perhaps a schematic diagram may be of further help.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 18, 2008 | Cobra 29 LTD CB Radio
Not the right sound
If the sound is popping on receive you more than likley have a bad audio ic (TA7222AP)
Dec 11, 2008 | Cobra 29 LTD CB Radio
Likely cause id the audio output circuit, centered on the TA7222AP integrated circuit.
Jul 15, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
No transmitt,Key up and meter pegs out.
The problem is the audio output chip. the number of this chip is TA7222AP, have this chip replaced and it will solve your problem. If you need futher info contact me at :
Sep 09, 2007 | Cobra 29 LTD CB Radio
Cobra 25 LTD 40-Channels Base CB Radio Logo
556 people viewed this question
Top Cobra Radio Communications Experts
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
