FixYa.com
Tags:
Wireless Access Points
Generic problem for all Wireless Access Points
Sierra aircard 875u connect to Playstation 3
posted by Tyedaniel on Jul 16, 2008
Hi, I have a sierra aircard and am thinking of buying a playstation 3 does anyone know if I can connect the aircard straight to the ps3 or connect my ps3 to my laptop and then connect to the internet to use the online features on a ps3???? thanks want to connect my serria wireless usbconnect to my playstation 3
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 13, 2008
FixYa! (100)
mumphra
Rank:Apprentice Apprentice
Rating: 100%, 2 votes
Actually, screw sending me the message. It would probably help more people if I just posted it in the forums.
I have a Verizon Wireless Mobile Broadband card plugged into my laptop because no one in my house has a desktop and we never bothered around with WiFi. I assume this aircard you speak of is similar to mine.
First, connect to the internet with your card. For me there's an application I have to run where I basically just open the app and click Connect. If you have XP (which I really hope you do because I haven't tried this on any other OS) open your Network Connections menu. This can either be done by opening the "Start" menu, highlighting "Connect to" and clicking "Show all connections", or by opening the Control Panel from the Start menu and selecting "Network Connections".
In the Network Connections menu, find your current connection. It'll be the one that says "Connected" in gray letters under the title. I don't know if they all are, but for some reason mine was under the Dial-Up category on the list. Next, on the same menu, look for the "LAN or High-Speed Internet" category. You should have a setting there called "Local Area Connection". I have two. You want the one that doesn't say anything about WWAN or Wireless. It should say something about your ethernet card if you leave the mouse cursor hovering over it.
Now that you've identified both settings, right click the first one you found (the one that says "Connected") and click "Properties". Once that menu opens, click the "Advanced" tab. Check the box under "Internet Connection Sharing" that says "Allow other network users to connect through this computer's internet connection." In the "Home Network Connection" box, type the name of the second connection you found in the previous step (the one that uses your ethernet card). On some computers, instead of allowing you to type anything, that box will drop down and show a list of all your connections. Either way, you know which to pick. Click "OK", and fire up your PS3.
Now, at this point I plugged one end of an ethernet cord in my PS3 and the other into my laptop. Your computer might say something to let you know it has established a Local Area Connection. Log in to any Playstation Network registered profile on your PS3 and open Network Settings under the Settings tab. Go to "Internet Connections Settings". I was able to click "Easy" and my PS3 did all the work from there.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: EnGenius / ECB-8610 / 54Mbps / 802.11a/b/g / Dual Band / 400mW / Wireless Access Point EnGenius EOC-3220+ (EOC3220PLUS) EnGenius 802.11b/g Wireless Access Point HP (F2135A) (F2135A#ABA) HP (F2135C) (F2135C#ABB) HP (P1981A) Motorola Canopy 5.2 GHz Wireless Access Point - AES Encryption (5201AP)
Can you Help with these Wireless Access Points problems?
activate plz
IMEI: 351862012680631 NO... Answer This...
Trendware TEW-630APB (TEW630APB)
No lights(lits)on WLAN-No acces...
Dear Friend, I have a problem.... Answer This...
Linksys Business Series WAP4400N Pre-802.11n...
WAP4400N suing TMobile UMA...
Out TMobile Blackberrys use a... Answer This...
MSI AP54G
wireless connection
msi ap54g - 2 laptops and one... Answer This...
3Com AP7250 802.11g/b (3crwe725075a-me)...
Subnet mask
I need to change the subnetmask... Answer This...
Repair Service
Find Wireless Acc. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
