Question about Nokia 6070 Cellular Phone
Battery icon appeared in the main display
How can I remove this battery icon in the center of the main display. I can no longer receive calls when it started.
How can i unlock a nokia 6070 mobile phone
Posted on Jul 18, 2008
How do I delete an Icon with the letter M in it which appears by the battery info
The Android "M" Developer Preview's second release was released just a short while ago, and we've already discovered an outstanding new feature: the ability to individually enable or disable icons in the status bar. In fact, if the only icon you want is your battery and clock, you can have that now - everything else can be removed!
To access the settings, you'll need to have developer options enabled. From developer options, there's an option to enable the system UI tuner, which then appears in the main settings tree near the bottom of the list.
There are also other changes to the tuner - you can show your battery's remaining percentage inside the battery bar now, which is also very, very nice and something we love very much.
What exactly demo mode is, I'm not sure - it appears to set all the status bar icons to their "on" states, but only certain ones. Demo mode, as one of our intrepid commenters pointed out, is probably for developers taking screenshots or videos of their apps. It forces notifications off the status bar and sets the bar to display cell signal, 100% battery, and locks the clock at 5:20 - so you can have a consistent status bar. Very handy.
But either way, these two other changes are amazing.
Mar 24, 2016 | Cell Phones
How to have the battery life show on the screen ?
The battery indicator will only show on the screen in the upper right-hand corner of the screen when the unit is NOT connected to an external charger. When the charger is connected, the unit is running off of external power. The unit has to be running on battery power in order to display the battery status icon.
May 27, 2014 | Garmin nuvi 1450 GPS Receiver
The weather Forecast Icons don't change on my honeywell weather station model # TE852W
This problem could arise due to various reasons
1)Replace the batteries in remote sensors
When the batteries are properly installed, the remote weather sensor will resume sending signals to the main unit.To enforce an immediate remote signals search, press and hold
DOWN on the main unit.
2)Remote thermo-hygrometer sensor could be weak in sending the signal about weather Forecast.Test it properly.
3)Reset the unit and check
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 11, 2010 | Honeywell TE852W Weather Forecaster With...
Battery charge
Power up your unit with nothing connected to its USB port. The battery status icon should appear at the top of the main screen.
Apr 15, 2010 | Garmin nuvi 255W GPS Receiver
Armada E500 notebook Power button not responding.
Unless you took the batteries to a service center, I am dubious about your ability to confirm the main battery is holding a charge. The average lifespan of these kinds of batteries range between 3-5 years and is likely at the end of its lifespan. This would explain the diminishing performance over the last year if there were significant power or power circuit issues, they would likely be observed on AC power as well. This model of laptop requires the battery calibration utility be run in order for the laptop use the battery. In fact, the battery can show a full charge and still not function if the utility and battery have not been properly configured.. . . instructions on HOW TO do this below. If this doesn't FixYa then the battery will need to be replaced (links to replacement sources) www.BatteriesOvernight.com/HP-Batteries,----- OR --- www.new-laptop-battery.com/Compaq/?Compaq-Armada-E500-battery.htm. You will still have to run the configuration utility when you receive your new battery.
Link to Armada e500 manuals:http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01124216/c01124216.pdf
How to run config utility: Standby and hibernation must be disabled for the battery to discharge completely and shut off. To use the Battery Calibration utility, first identify whether the battery requires calibration by launching the Power Management applet as described above. On the Battery Calibration tab, all installed batteries will be displayed in the primary list box. Next to each battery name will be an indication of whether calibration is required for that battery. If calibration is necessary, the phrase “Needs Calibration” will be displayed. Select the battery to be calibrated, and click the Start Calibration button. During calibration, the utility will display an icon on the Windows System Tray to indicate that calibration is in progress. Each phase of calibration (charging or discharging) will also be displayed. Calibration is complete when the icon is no longer displayed in the System Tray. Battery calibration requires several hours for completion. If you choose to continue using the computer during the calibration process, it must be connected to AC power. The calibration process must be allowed to finish without interruption. Performing any of the following actions will prematurely terminate calibration:  Clicking the Stop Calibrating button in the Compaq Power tab.  Unplugging AC power from the computer.  Unplugging the calibrating battery. (This action may result in data loss if a second battery is not installed.)  Undocking the computer.  Pressing the power or standby button.  Powering down or suspending the machine by using the Windows menu. IMPORTANT: If the calibration process is interrupted, it cannot be resumed. You must restart the computer and start the process again.
CALIBRATING WITHOUT THE UTILITY To calibrate a battery on computers without the battery calibration utility, complete the following steps: 1. Remove the second battery, if present, so that only the battery needing calibration remains in the computer. 2. Dock the computer or connect the computer to AC power. 3. Turn on the computer. 4. Check the current battery capacity level by positioning the cursor over the battery icon in the system tray. 5. Allow the battery to charge to 100%. You may use the computer, but the recharging process will require more time. 6. Set the system to “drain” mode on the battery conservation settings by pressing Fn+F7, or select Start > Settings > Control Panel > Power (or Compaq Power in Windows NT). 7. Undock the computer or disconnect the computer from AC power. 8. Restart the computer in MS-DOS mode by clicking Start > Shut Down > Restart the Computer in MS-DOS Mode > OK. 9. Allow the computer to discharge until it shuts off. 10. Dock the computer or reconnect AC power. 11. Allow the computer to charge again to 100% as in Step 5.
Feb 19, 2010 | Compaq Armada E500 Notebook
The icon for "My Favorites" is no longer displayed, how do I get it back on the screen?
I have Garmin nuvi 265T. I dont see the battery icon on the main screen. Also, when i unplug the GPS device, it turns off (as if there is no battery).. Does this means that the battery is dead? The device is less than a year old... pls advice.
Nov 07, 2009 | Garmin nuvi 265 Car GPS Receiver
How to remove headphone icon from the display
I have encountered with the same problem with my Nokia 6630. This may happen if somehow your phone is damaged by water or your cell is experiancing a extermly humid environment. So do one of the following:
1. Switch off your cell. Remove battery and put it some time in direct sun light. If possible your headset jack facking sun face. You can also use your table lamp. Just bend it to cover phone.
2. You can also use your hair drier. Just blow the hot air towards your phone.
Jul 21, 2009 | Nokia Consumer Headset
Conon powershot a470 i cant find in the manual where the battery life is displayed? is it on the screen? do u have 2 change setting 2 find it? or does this model not display it on the screen?
Your a470 has a "low battery" flashing icon that will appear in the upper right hand corner of your lcd display when the battery is getting low. It doesn't appear to have a constant battery display. The manual recommends when you see the flashing icon... change the battery as soon as possible.
May 15, 2009 | Canon PowerShot A470 Digital Camera
Hi My cordless phone does not receive or make calls anymore. I have checked and everything seems to be working OK. There is a small icon that appeared on the screen ,like a battery,, and is all black
The battery indicator on the handset tends to be misleading. You may need to replace the battery, or if the phone is under a year old, try charging over night. Simply unplug from the phone jack, leaving base plugged into power.
Apr 18, 2009 | Lands Phones
Is there any such thing as charging my mps nextar MA933a via the USB port? I just get sleepy z's on the display when I connect it to my computer.
Here is what I found:
Connected the player to the PC with and without prior power on successfully
OSD first displays message “Starting…” then:
Icon appears on screen with a picture of a computer monitor to right and mp3 player icon to left
When mp3 player is communicating with computer or sending information, an appropriate directional arrow appears between the two icons; when transferring files using Windows Explorer, the arrow reverses direction appropriately; when there is no activity either way, a series of “Z z z” ‘s appear on screen
Battery indicator icon also appears to right – new AAA battery resulted in a fully charged icon upon startup; no battery whatsoever resulted also in a fully charged battery icon appearing
-Tha Mp3 Doctor
Feb 02, 2009 | Nextar MA933A MP3 Player
Nokia 6070 Cellular Phone Logo
35 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
