Question about Samsung (MP0804H) 80 GB Hard Drive
See only one of four partitiona in a mobile disk
When I connect my portable hard disk to my computer, it only connect/show me one disk partition, I got 4 partition in that portable disk Samsung MP0804H USB Device. I can not see the other three, why?
Can you help me ?
  • Samsung Master
  • 2,794 Answers
Go into the control panel.
Go to administrtive tools.
Go to Computer management.
Click on disk management on the left side of the screen.
Click on the drive you partitioned.
Does it show four partions?
Were they partitioned as NTFS or a different format?
Posted on Jul 16, 2008
Tip
"Unable to find a free MBR slot in virtual partition.dll usually due to no free...
Situation:
When attempting to run an operation in Ghost that requires a reboot into the virtual partition, you receive the error "Unable to find a free MBR slot in virtual partition.dll--usually due to no free slots on disk."
Solution:
This problem occurs when the client computer has used up all four primary partitions in the partition table of the boot drive. An Extended partition takes up one Primary Slot, so having three Primary partitions and one Extended partition would also cause this issue.
Computer architecture allows each hard drive to have no more than four primary partitions (the other partitions are extended partitions). Because the Ghost Virtual Partition is implemented as a primary partition, you see this message when the disk is using all four primary partitions and does not have an available slot for the virtual partition.
Use one of the following methods to resolve the problem
  • Start the computer from a Ghost bootable floppy disk rather than a Ghost Virtual Partition. You can use Ghost Boot Wizard to create a Ghost Standard Book Disk for this purpose.
  • Repartition the disk. If you repartition the disk, ensure that you create backups of your data before doing so.
on Feb 01, 2010 | Computers & Internet
After install window not show may hard drive
Right-Click "Computer", Manage, Storage/Disk Management. What you see here is what you have, or at least what Windows thinks is connected. If you have a missing hard drive, check your hard drive connections.
Jun 26, 2014 | Computers & Internet
I formatted my lacie 301891 (320 GB) and his capaity is now only 9,99 MB what did i do wrong?
You may have partitioned your hard drive. Have a look at your Computer Management Console by right clicking My Computer > Manage. Then under Storage, select Disk Management.
Jul 14, 2011 | LaCie 301891 320GB Starck Mobile Portable...
I am using segate u series ST340810 hard disk. when I am formatting this hard disk this hard disk does not shows partition to format and shows messege of disk cannot access what should I do?
Hello Ravindr,
After connecting the Segate Hard Drive in your computer go to Control Panel. In Control Panel you will the option Administrative Tool. In Administrative Tool open the Computer Management and you will find the number of attached Hard Drive and the Partitions they have. If the Hard Drive you have attached is not showing the partition then there may some physical damage with the Hard Drive media. Please get your Hard Drive checked by Segate professionals and then replace the Hard Drive with new one.
Jun 03, 2011 | Seagate U Series (ST340810) 40.02 GB Hard...
I have an Acer 3002LCi laptop. I upgraded the RAM to the maximum 2GB. I also installed a WD Scorpio Blue PATA 250GB HDD. I installed Windows 7 from disk and computer shows drives C and D but drive C...
Install a partition manager program like
http://www.partition-tool.com/personal.htm
open it and you will see the entire hard disk. In there either create another partition in the unallocated space or add it to the D partition.
Mar 23, 2011 | Western Digital Scorpio Blue 250GB PATA...
My external hard disc moder no : TS80GSJ25S shows there is no disc in your drive
If you have used this drive before then the drive is malfunctioning and my need to be formatted. If not, then the disk could need initializing and then formatting. You can check the status of the disk using the windows disk management utility. The directions to use this utility are shown below, If the disk does not appear in the manage disks section, check the connection to the computer, and try to power cycle the drive by unplugging it, waiting for about 20 seconds and then plugging it back in. This may renew the connection and restart the drive.
Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility.
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments. Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives
Jan 09, 2011 | Transcend StoreJet USB 2.0 External Drive...
My toshiba 250gb external hard drive doesnt show in my computer (xp) but it is in device manager?
Click Start
Right-mouse click My Computer
Click Manage
Expand the Storage branch
Click Disk Management
Click Disk Management (local)
Click to create a partition on the drive, and to assign a drive-letter.
Oct 27, 2010 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
How do i get a new hard drive to recocgnize the external drive
Connect the external storage
Click Start
Click Manage
Click Storage
Check to see if there is a "healthy" partition covering the disk-space of the external storage device.
Jun 24, 2010 | NexxTech Portable Hi-Speed USB 2.0 Kit...
External 500gb hard drive not readable
Check the partition size in Disk Management (if running Win7 - download a free Partition Manager if not) and see if the system is seeing the partition correctly. Seagate has recovery software available on their website but you may just have to repartition and reformat.
Apr 25, 2010 | Seagate 320GB Portable External Drive ...
Samsung (MP0804H) 80 GB Hard Drive Logo
112 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
