Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Ligthing the oven glow bar
My mom has a Ge Spectra Eterna series oven and we can not get the bottom of the oven to lite. Any suggestions?
    President:
  • 1,314 Answers
You need to replace the oven glow bar take out the oven racks in the bottom of the range you will see two screws remove them remove the bottom oven pan under that is the flame spreader shield under that under it you will se the ignighter at the back of the burner bar just follow the instruct sheet with the ignighter to install and reverse just because the old bar glow-es don't mean its good just replace it
Posted on Jul 22, 2008
I have a ge spectra gas range and the broiler works but oven wont work?
Check to see if the igniter glows white hot. The igniter needs to be glowing white hot before it will allow the valve to open and lite. Here is the part to order if you find it bad. Post back the results.
Feb 05, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
My mom's spectra oven emits a strong odor when the oven is in use. I noticed through the oven door glass that the flame is yellow. This does not seem right to me. I've always seen blue flames. Is there...
Sorry to read about your problem, I hope this helps you out.
you may a gas flow or control failure, i dont think a adjustment would work in this case
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | GE Eterna EGR2000EMBB Gas Kitchen Range
Ge spectra eterna series gas stove broiler will not fire up. The glow plug gets hot, but the broiler fails to start.
I have an GE Spectra Eterna Series where the oven comes on and only gets warms no matter what setting the oven is set at. Can some one solve this problem?
Mar 07, 2010 | GE Eterna EGR2000EMBB Gas Kitchen Range
GE gas oven--Spectra--the oven does not heat--the broiler works, however
Most common problem is the glow bar ignitor. Lift off the bottom panel of the oven and remove. (Some have two screws holding the panel at the back of the panel.) Turn the oven on and see if the glow bar glows.
Even if the glow bar glows doesn't mean that it is working 100%. An amp probe is need to see if the glow bar is drawing the proper amperage to allow the gas valve to open allowing gas to come to the burner. The glow bar should draw about 3.5 to3.8 amps. If drawing more or less than this, replace the glow bar ignitor.
I hope this helps.
Jan 25, 2010 | GE Ovens
Oven won't work on gas with electric ignition stove
The glow bar for the bake burner is bad, needs to be replaced. Remove oven bottom to get to it, and also the utility drawer.
Feb 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
Oct 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge Spectra
Remove the bottom of the oven you will see 2 screws in the back. once you do that there is a flame baffel on top of the burner held on my one screw. remove that. now turn the oven on and watch to see if the glow bar comes on. I would say it wont or if it dose it is to weak to open the gas valve. Replace the glow bar and you will be back in business. the glow bar is a ware item everytime theoven is on and is heating the glow bar is on . good luck
Jul 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
307 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
