Celestial split system air conditioner
Unable to get the thing to heat, despite setting temperature at 30 degrees Celsius. Any ideas?
  • Jo Hopping Jul 16, 2008
    Despite setting the temp to 30 degrees Celsius, I'm unable to get our Celestial split system air conditioner to produce any warmth. It continues to put out air that is quite cold. I'm sure it's just a matter of understanding the remote control a little better! Thanks to anyone who's able to assist.
I am a repair man and have had this problem quite a few times, check that the remote is set to heat and 30 degrees.usually a symbol like the sun,very similar to cool easy to mix up.If the a/c is set to heat the indoor fan will not start till outdoor unit has heated coil.
Posted on Feb 10, 2009
Need a new head for Celestial air conditioning unit for a KFR70GW/K are you able to supply and how much
Posted on Feb 02, 2010
I have a celestial split system kfr-36gw/c3 when I turn it on the red pause light comes on.I can't find anything about it in the booklet that came with the system.how do I turn it off.
Posted on Sep 17, 2011
    New Friend:
I can't get my celestial air-conditioner to heat at all but I found by pressing the green Dehumidification you take it off pause.
Posted on May 29, 2015
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
How do i take the air con from cold to the heat setting
set your temperature to say 20 degrees celsius and the air con should automatic change to heat,
May 04, 2014 | Heating & Cooling
I have lost the manual for my fujita 2.5 split system and all i want is w what to press on the remote control..... as from Winter to summer Cheers Clare
You decide what temp you need.
To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Jan 06, 2011 | Heating & Cooling
The air conditioner is emitting cool air instead of cold air. I have the setting on cold and the temperature setting at 60 degrees. On these days that have been near and over 100 degrees, that cool air...
Typical temp split should be 15 to 20 degrees. A 75 degree return air temp should be in the 50s. Be sure coils are clean , if in that range the machine can do no more. If it is not, you likely have a refrigerant issue.
Aug 31, 2017 | LG LWHD1009R Air Conditioner
My daughter has Mitsubishi split type air conditioner, model MXZ-2A20NA. The problem is that one of the unit puts out more cold air than in called for on the remote resulting in a room temperature that...
The best thing for you to do is to call Mitsubishi Tech. Support directly..they are first class and will probably know exactly what the issue is...
For technical application questions, please call:
Mr. Slim: 1-800-433-4822 (press option #3).
heatman101
Aug 26, 2010 | Mitsubishi Heating & Cooling
Cant get the heater to work
Try putting the temperature setting at the temperature that you actually want the room to be instead of a crazy temperature
Apr 22, 2010 | LG LS-L1210CL Mini Split Air Conditioner
TRY TO SHUT DOWN THE BREAK AND TURN IT ON AGAIN 10 MIN LATER
Mar 08, 2009 | Heating & Cooling
Split HVAC does not achieve requested temperature
If is heating on outside temp must bee max 5 degree
Celsius.If leak inside unit then check drain hose.
Feb 15, 2009 | Mitsubishi MS-A09WA Split System Air...
Non-cooling
- Calibrate your electronic thermostat if it is accurate. If not then replacement is needed.
- Check the location of your electronic thermostat, it may be installed in the room where its too cold.
Feb 29, 2008 | Carrier 36KCARMS Air Conditioner
Heating & Cooling Logo
2,397 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
