Question about Haier HDN655E Dehumidifier
I just purchased a new Haier 65 pint dehumidifier and inside on the bottom of the unit, it is covered in oil. Of course the unit is not functioning (it runs but is not removing any water).
  • Debra Facciolo Sep 07, 2008
    Similar issue, but dehumidifier is a year old. It was working fine, but now runs constantly, does not collect water and oil is leaking from the drain hole. Returning to merchant is not an option.
    Sergeant:
  • 225 Answers
This sounds to me like a leak in the compressor housing which has allowed the oil and refrigerant to escape. I would take it straight back to the seller and request a replacement unit.
Hope this helps. D.
Posted on Jul 31, 2008
How many watts is a DE45EJ-L dehumidifier?
There is a review website that claims the unit draws 590 watts. The refrigerant this one uses is R-134a.
Haier 45 Pint Dehumidifier Review
A slightly larger unit is also available from Haier, the DE65EJ that uses R-410a, which is a more efficient refrigerant and allows the unit to be perhaps 20% more efficient. That larger unit is rated for 65 pints a day, and uses 710 watts. It is a bit heavier than the DE45EJ also.
Jul 01, 2014 | Haier Dehumidifiers
Humidity sensor
Go to Http://www.Haier.com/us/products/home-comfort/dehumidifiers . Select the model number and proceed to the Manual. Download the manual and look at the E-Codes to solve your problem.
Dec 19, 2013 | Haier 65-Pint Dehumidifier
Haier dehumidifier will not power on
Turn the ON/OFF Switch to OFF and unplug the unit for 15 minutes.
Once the time has elapsed, plug the unit in and turn the unit ON.
Hopefully, during that 15 minute timeout, the electronics reset and reverted back to the original factory settings. And the unit will turn ON when you press the ON/OFF Switch.
It's also a good idea to check the outlet it's plugged into. It very well could be an issue with the outlet (no power) or the circuit breaker for that outlet has tripped.
If you continue to have a problem getting it started, contact LG Customer Support 1-800-243-0000.
May 27, 2013 | Haier 65-Pint Dehumidifier
I would like to know the average monthly cost of using a 65 pint dehumidifier if it runs continuously for 24 hours for about 300 days a year
To find the Annual Energy Cost, look in the Owner's Manual or other paper work that came with the unit. The Energy Star rating paper work will have that information. However, that cost does not include routine maintenance cost or any repairs that may arise from running the unit constantly for 360 days. Sounds like you'll be running it in a damp basement.
Hope this helped you and thanks for choosing FixYa.
Aug 06, 2011 | Haier 65-Pint Dehumidifier
I have a Haier 65 pint dehumidifier. When I press the control button to lower the humidity setting, the word On comes up and I do not see numbers lowering.
Let's start from the beginning. Turn the Master ON/OFF Switch to OFF. Unplug the unit for 5 minutes. Then plug the unit back end, and turn the Master ON/OFF Switch to ON. Now, lower the the humidity extraction level to 40%, by using the Arrow Down Button. You will need to lower it by pushing the button for each % setting. DO NOT push and hold the Arrow Down Button.
Doing the above should solve the problem.
Jul 12, 2011 | Haier HDN655E 65 Pint Dehumidifier...
Haier 65 pt dehumidifier the lo light is on and the bucket is not fu;; and the filter is clean. ????
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Jun 07, 2011 | Haier 65-Pint Dehumidifier
Tyies to Start
It could be a bad compressor, circuit board, or maybe even a sensor or dehumidistat...
Here is a tip about dehumidifiers2_bing.gif that run but do not extract water from the air..
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 02, 2010 | Haier 65-Pint Dehumidifier
Unit won't start
its field with water, empty
Apr 07, 2010 | Haier 65-Pint Dehumidifier
Filter Removal
I believe that this unit has a permanent filter, and can not be removed to clean. You should however be able to access it to clean it. Hope that helps!
Jun 30, 2009 | Haier 65-Pint Dehumidifier
Haier HDN655E Dehumidifier Logo
164 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
