Question about RCA D52W15 TV
Turns on and shuts off. No picture. No sound.
I have had my RCA projection TV (model # D52W15) for a little over 3 years. I read this TV is the same as model D52W20 without the screen protector. About a month ago the TV made a popping noise and went out. The TV attempts to come on and then shuts off due to what we assume is the circuit protection. With the help of a friend we found a connection loose on what we are assuming is the SSB board. The connection was re-soldered and the TV worked for about a month. A couple of days ago the TV did the same as before. We pulled the board back out and looked at the solder points. We didn’t notice anything wrong with the solder, but did notice two capacitors were popped. We replaced both of them, but the problem did not go away. We reseated the ribbon cables and blew out any dust with compressed air. We also checked the tubes for any cracks or leaks and found nothing. We tried holding down the power button to get the error code(s). One post talks about receiving a 19 error code (one flash and then nine flashes in a row) we could not tell if our error was a 2 or 11 (http://www.fixya.com/support/t104008-rca_hd_model_d52w15). We unplugged the control panel as stated in a previous post and it did not change anything (http://www.techlore.com/forum/thread/18490/RCA-52-quot--projection-tv-model-D52W20/?highlight=d52w20). Does anyone know where to find an explanation of the troubleshooting codes? Any suggestions on where to go from here would be greatly appreciated? I apologize for the length of this post, but I wanted to supply as many details as possible.
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: rca hd model #d52w15
That flashing means that the sweep power supply didnt start up along with the main power supply. It could be a shorted horizontal output transistor or a bad flyback transformer. Youll need a service manual to scope out the horizontal drive and see why itsnot starting up or staying on. if your not a servicer then there are no real user serviceable parts inside so contact your local AUTHORIZED servicer as they will have all the right service manuals as well as acess to all the proper parts. Not that an unauthorized shop is a bad thing its just they the unauthorized usually are not aware of troubles that rca sends there peeps. Good Luck
Posted on May 28, 2006
SOURCE: rca d52w15
I have the same tv. It sounds like the flyback transformer is arcing out. I replaced the flyback transformer and 3 capacitors. Now i have different problem. Goodluck
Posted on May 02, 2008
yambo
  • 230 Answers
SOURCE: d52w15 comes on then shuts off
Hi, thank you for visit fix ya.
This is a common problem on this kind tv.
Replace capacitors on power supply.
22000 uf 16V and 220uf 16 V; upgrade to 35V.
For parts, go to:
http://www.encompassparts.com/
Any question I will be here.
Thank you
Posted on Jul 28, 2009
D52W15
this tv does not have bulb or lamp it has 3 picture tubes red,green and blue
Oct 23, 2012 | RCA D52W15 TV
Tv wont come on
first of all you may unplug about 2 hours and try again as symptom shows some internal overheating or power failure going on
Mar 01, 2008 | RCA HD52W59 HDTV Projection Television
Where is the lamp on an rca d52w15 tv?
That model doesnt have a lamp. They have three CRTs ( Picture Tubes) instaed. You can get the parts for your model at www.tvrepairworld.com. If you have sound but no picture youre needing a deflection board, same item if the set is dead or if the power led flashes three timnes slowly. They all indicate a bad deflection board.
Aug 08, 2011 | RCA D52W19 52" Rear Projection Television
I have a RCA 52in TV & the picture is arched. Model # is D52W15.
Problem description indicates a convergence alignment issue. Convergence circuirty needs to me replaced.
Jan 19, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52w15 will not turn on, flashes three times.
Replace you flyback transformer and Horizontal Output Transistor
Sep 28, 2009 | RCA HD52W59 HDTV Projection Television
Model #m50wh72syx12.... sound but no picture...
I have the same problem, TV is only 3 years old. Already replace bulb once and helped for a little while. The more I check, this sounds like a very common problem. Hmm...maybe a class action suit?
Sep 28, 2009 | RCA Televison & Video
D52w15 comes on then shuts off
For parts, go to:
Thank you
Jul 28, 2009 | RCA D52W15 TV
Rca hd tv d52w15
that model is famous for having bad flybacks. fortunately they arent exspensive and there easy to replace. you can get a new replacement at the following link for less than 50 bucks and they give free instructions on how to install it properly.
http://servicemanuals.vstore.ca/
Jun 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w15
Most likely a bad flyback. It's a cheap part, but service people are even having a harder time getting ahold of one since they are failing often.
Apr 01, 2008 | RCA D52W15 TV
Rca d52w15
Possible short and safety is keeping the set from burning up. A service man should be able to find the short hopefully in a small amount of time.
Nov 05, 2007 | RCA D52W15 TV
RCA D52W15 TV Logo
77 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
