Question about Hunter Floor Stand Fan Stand (Pedestal)
Hunter Pedestal fan model number 90171--1307
This fan is not in circulation any more I don't think..It got messed up and before I could look at it, the fan was brought to some po dunk guy to be looked at and he jacked it up even more. I need the wiring diagram so I can connect these wires back together and see if the motor is burned up or what.
On the other hand, I don't have a receipt for the fan. It is less than a year old. Will hunter replace it with a new one, or one that is comparable? Thank you for your help.
4 Suggested Answers
SOURCE: low battery on hunter 44422
I have the same unit, 44422. The base has four clips, two on the top and two on the bottom. The front portion is clip-on. Try to push on the base's bottom and pull off the front portion, like opening a book. After the battery replacement you will have to reset the unit trough the little reset hole. Otherwise, the ''LOW BATTERY" will not go away. Yes, you will have to reprogram the unit.
Posted on Jan 25, 2009
  • 19 Answers
SOURCE: need a wiring diagram for thermostat/hunter model44260
Hello please try this link and see if this contains the information that you need
Reply to bsix@hotmail one way or the other Thanks
http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/42711.pdf
Posted on Sep 14, 2009
milten1
  • 1304 Answers
SOURCE: Hunter 44260 Thermostat Problem
make sure you have the jumper in place
if you dont have a secondary heat source red should be on r with a jumper to rh
Posted on Oct 17, 2009
Pedestal floor fan. I need a new motor. 45 watt How much are they if you have in stock?
Dear Tom,
"Fixya" is a source of information and suggestions for people's problems, they have no parts or prices of things.
Try Amazon (new things) or e-bay (used things) on your computer for the motor and it's price.
Since these items are likely made in China, the motor may or may not be available.
Jan 25, 2016 | Hunter Floor Stand Fan Stand (Pedestal)
Pedestal fan blades
That's a store brand for Home Depot, so Good Luck!
Mar 29, 2014 | Hampton Bay Dryers
How to oil a standing Hunter fan
If the fan does not have 3-in-1 oil'r cap located near each end of fan, then lay fan down so blades are up. Then use WD40 with straw to spray on the turning shaft and let oil drip down for several hours.
You cannot over-oil a turning shaft, so plenty of WD40. Just be careful because air mist from WD40 is harmful to breathe and vapor is extremely flammable, so no smoking while spraying.
Sep 21, 2012 | Hunter (90121) Stand (Pedestal) Fan
Where can I get a new motor for my Hunter Designer's Choice Ceiling Fan (model # 99048
Call Hunter at 1-901-745-9222. I think this number is still current, it might not be. Tell them your issue, most likely they will send you an entire new unit (or is your fan the OLD Designer's Choice from the 80's with a rubber flywheel?)
Apr 06, 2012 | Hunter Designer's Choice 5-Switchblades Lg...
I need to purchase a Hunter ceiling fan receiver. The receiver model # is 85069-060.
hunter technical support number is-- 1-888-830-1326 call this number and they should be able to help. good-day ! just tell them you need a new receiver, and give them the model number of the receiver and the fan model number.
Aug 25, 2011 | Hunter Ceiling Fan Remote Receiver...
Good Morning, I have a Hunter foor standing,
Hi medoody...
Sounds to me like you need to disassemble,clean and oil your fan.
After 5 yrs of running it probably needs it badly.
Please take time to rate me
Aug 11, 2011 | Hunter Floor Stand Fan Stand (Pedestal)
Have an expensive Hunter indoor/outdoor pedestal Fan that stopped working. It just "hums" and does not turn. Please help.
With the fan UNPLUGGED, try to spin the fan blade with a pencil or something that will fit through the blade cage.
If the blade spins easily, there is an electronic problem (control or motor) that must be serviced.
If the fan blade is stuck or very hard to move, the shaft and bearing are probably dirty and need to be cleaned. You can temporarily fix this with a tiny amount (a drop) of WD-40 applied to the shaft where it enters the motor. Spin the blade manually to work the oil into the bearing. If the motor spins freely, the dirty bearing condition is verified. To properly clean the shaft and bearings, the motor must be disassembled.
Jun 11, 2011 | Hunter Floor Stand Fan Stand (Pedestal)
Need installation instructions for a Hunter Regalia ceiling fan, model 28642, item 183013, as the fan came without any. Am ready to install now!
Robin - Here's a link to the Owners Manual for the Model Number Hunter Ceiling Fan, you listed.
You may download and print it for future reference.
http://www.hunterfan.com/uploadedFiles/Support/Downloads/45065.pdf
Please don't forget to leave me a rating for helping you. Thanks!
Apr 14, 2011 | Hunter Heating & Cooling
I just purchased this fan from Target. It doesn't turn on. I unscrewed some screws and ...there is no connection from the base to the fan. There seems to be a lot missing from the motor too. My guess is...
More than it's worth by a lot. I would go to target with the target SKU and have them find one at a different store and have it brought in for you. If it is the last one in all the world there is a reason. If you like the look, copy all its model numbers and such take a good picture of it and see if you can find one on the web. The shipping on the fan would be around 50 dollars and hunter would charge you full shop rate and parts as it is not their responsibility but Target's. If you wait too long you will have some trouble returning it, so I would choose your course of action soon. Hunter can help you find who has the model for sale if it's not one made specifically for Target. Good luck, Farmerbear at FixYa.com
Sep 30, 2010 | Hunter (90121) Stand (Pedestal) Fan
I have a Dayton (motor model #4C354C) model 3C215C 24'' circulator two speed pedestal fan. I need to remove the ocillator shaft so I can remove the back cover in order to replace bearings. Thanks
if you go to the link below there is a small diagram and a parts list but not alot of info available for this product and of course it has been discontinued. im sure if you need anymore info you could call grainger they are very helpful and can get you a better parts breakdown http://www.grainger.com/Grainger/rp_search_by_product.jsp?mfgSearchCriteria=DAYTON&modelSearchCriteria=3C215&suppSearchCriteria=20005580&search.x=1&exact=yes&from=detail
Mar 13, 2009 | Dayton (1UM36) Stand (Pedestal) Fan
Hunter Floor Stand Fan Stand (Pedestal) Logo
183 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
