Question about Mitsubishi CS-35405 TV
How to set inputs in Mitsubishi CS-35405
I used to have an input for my satellite dish, DVD player and one for the VCR. My DVD player input has disappeared for some reason and I do not how to set it back up. I cannot find my manual. Can someone please walk me through how to set up inputs on the TV?
  • 3 Answers
My cs-35405, only has input 1 and input 2, but has ant. A and ant.B So there are really 4 inputs. The input button on my remote, gives choice of these 4. Any vcr, dvd, cable or cable box, and satellite would be hooked seperatly on these. But to record TV, satellite or cable would need to go to recorder first and then toTV.
Posted on Apr 06, 2010
I have hooked up my tivo and cable box but can't get my dvd player or wii to work with my cs-35405. I can not afford a tv now so please help.
You may have to hook up the DVD to the inputs on the front of the TV. If there are not enough side or front inputs, you may have to run the game through the DVD player, if it has inputs.
Dec 09, 2014 | Mitsubishi CS-35405 TV
Cant find how to set tv to show dvd player
Look at your remote control for your set. Find a button that says "input" or "source". Use that to choose which ever input your dvd player is attached too. Model of TV and DVD player would help make the answer more specific.
Sep 01, 2013 | Mitsubishi CS-32309 32" TV
How to hook up dvd/vcr combo to a tv with dish satellite
Run the line level outputs (red,white, and yellow), from the satellite receiver into the "In" terminals on the dvd/vcr...then run the line level outputs from the dvd/vcr to the inputs on the tv
Dec 27, 2010 | Philips Magnavox DVD/VCR Dual Player
I need to know to to install the dvd into a dish network box
The DVD does not go into the dish box, but rather it connects to a second input on your TV. To access it you toggle the INPUT setting on the TV.
Dec 04, 2010 | GoVideo DV2150 DVD Player/VCR
Ant A and ant B
There should be 2 buttons labeled Input, in between Volume and Channel. Press up on Input. If you are using a remote different from the one that came with the TV, then look for a button labeled 'Input' 'Int' or 'Mode' somewhere along the top.
Mar 29, 2008 | Mitsubishi CS-35405 TV
Mitsubishi CS 13101
EXT means external input,i.e.from an outside or alternate source.
That source could be a DVD / VCR , cable box, video game,etc.
2) New dvd/vcr recorders allow A / V inputs only,usually obtained
from a source box ( cable or satellite ) They do not have coax cable input/output,also known as RF in/RF out.
3)The dvd/vcr manufacturer expects the consumer to upgrade equipment periodically.If your TV or A/V receiver ( surround sound) has a video monitor output,problem solved!
Hope I helped you ......T.
Oct 18, 2007 | Televison & Video
Connecting to a DVD/VCR player/recorder
In the menu of the Philips dual unit,select set-up then look for channel auto-program instructions. Be sure to hook-up a tv channel signal source before beginning auto-search.Hope this helps.
Oct 03, 2007 | Mitsubishi CS-27205 TV
Recording to DVD on samsung recorder from dish network dvr
Connect the "yellow, white , red) jacks from the Satellite to the same colored inputs on the DVD. If you use "Input 1", for instance, set the dvd to record on Input 1. Set Satellite to desired channel. Good to go.
Sep 08, 2007 | Samsung DVDR120 DVD Recorder
Multiple video inputs
Unfortunately, you cannot use the connectors at the same time. The S-Video connector overrides the standard video connector. This is why they share common audio left/right inputs. If you could use them separately, they would each have their own set of audio inputs. (S-Video does not carry audio signals on the cable.) I'm assuming that you are connecting your Satellite as an input to your VCR, and then your VCR to the TV via a video connection. The VCR passes the satellite signal through unless you are watching a tape, then it overrides the dish signal. You have a few choices here: 1. You can connect the coaxial (RF) output from the VCR to the TV, and watch the satellite and VCR on channel 3 (or 4). You can then connect the DVD via S-Video, and watch it on "video". This is the simplest solution, and provides the best picture quality for the DVD (with this TV), but lower quality for the dish and VCR. 2. You can connect the DVD player via RF (if it supports that), watch the DVD on channel 3, and connect the VCR via video. This will make the DVD picture quality terrible. 3. You can replace the VCR with a combo DVD/VCR unit. You can then connect the S-Video out from the combo unit to the TV. This is a more expensive solution. 4. You can replace the TV with a model that includes more inputs. This is the most expensive solution, but will allow you to watch your DVD over component cables (very high quality) and VCR and dish over S-Video. Ironically, the obvious choice, connecting the DVD as an input to the VCR (as a pass-through) simply WON'T WORK. The signal put out by the DVD player is "copy protected" (using a system called MacroVision) which the VCR will refuse to play, even as a pass-though. Best of luck with this. Given that you are trying to make this all work without replacing equipment, I recommend option #1, until you decide to break down and buy a shiny new HDTV. They are coming down in price every week, but only you can decide when the time is right.
Mar 22, 2007 | Sony KV-32S26 32" TV
Changing the inputs
It might depend on the type of input. VCR often use A/V or component cables. if you are using AV (red, white, yellow) make sure they are plugged into the right input. if plugging in to a component (white, red, green, blue, red) make sure the yellow plug goes into the green input. If plugging in component make sure your red wires are not backwards. There should be a white and red together (these are the audio) and a green blue red together (these are video)
Sep 08, 2017 | Mitsubishi CS-35505 35" TV
Televison & Video Logo
200 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
