Question about Miele 24 in. G665 Built-in Dishwasher
Drying cycle problems
I have probs with the drying cycle which used to emit steam from the grill on the front when drying. Now no steam comes out but a squeaky sort of noise like something rotating badly and then we get water coming out of the grill when we open the door to empty it. Otherwise everything works perfectly.
  • Anonymous Aug 29, 2008
    I've the same problem. Anyone has an idea on that issue or the manual that talks on this.
Take the door fascia off, and you'll see a pipe from the steam outlet to the Soap Dispenser in the door.
Take that off, and flush out the small bit of food that is blocking the tube.
Put the cleared pipe back in situ.
Run machine, you should get steam, and no water.
When it blocks again, and you get the water again, repeat unblocking process etc...
Posted on Nov 01, 2008
Hi I have a hotpoint WD62 washer dryer. when I'm using the dryer the clothes still come out wet like the steam is not going out of the machine. Any tips on what to check for? Could something be...
I had the problem. I replaced the water inlet valve, and that fixed it. It seems no cold water was coming in on the drying cycle to condense the steam.
Sep 24, 2010 | Hotpoint WD62 Front Load Washer / Dryer
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Is it normal to see steam coming out of the dishwasher in the drying cycle?
Yes, The colder the room its in the more steam you will see. It will look like more steam if sun light is shinning over it. Just like your clothes dryer blowing steam out side. Its just drying.
Oct 30, 2009 | Dishwashers
Our Maytag MDBH950AWS is only two days old and we are having the
I have one that does not vent. Was told the new one do not vent. Mine is 1 month old I have had repairman out twice. #1 Said my heater worked. #2 said he repaired my venting that was blocked.No steam in front anymore.
The problem with the dishwasher being full of moisture after the drying cycle, also letting it stand overnight after drying, STILL full of moisture! I think this is going to remain like this. After three months is it the machine adjusting to the moisture or YOU!
Jul 23, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Jenn-Air JDB8910 dishwasher moisture coming out left side.
thats a vent fan to help with drying cycle its normal for steam to come out during cycle of drying you might use no heat air dry and turn your jet dry disp up but its a normal part of drying cycle
Feb 11, 2009 | Jenn-Air 24 in. JDB8910 Built-in...
Does not dry all the way
I too have a similar problem. Drying light blinks, doesn't shut off, little if any steam escapes when door is open during drying cycle. Wonder if this is Ariston's Dynamic Drying? My unit is new too.
Aug 20, 2008 | Ariston Technologies LL64WNA Built-in...
Water is being used in the drying cycle
This is normal operation. Water is used by the condensor to liquidfy the steam from drying.
Mar 27, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Drying cycle
Is the drying fan rotating(you should hear this)? Or the watertap closed. It uses cold water to make the steam into condense. If tap is closed, the machine has no water to cool the steam with. Check lint filter.
Jan 22, 2008 | Candy CNW156 Front Load Washer / Dryer
Hotpoint Aquarius 1200 WD62 (Tumble drying issue).
no the steam from the dryer part comes out of outlet tube the same tube were the water comes out hotpoint washer/dryers use a condensing chamber which allows the steam to cool down a pass through it as water does and through the outlet pipe
Aug 14, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Washer dryer is no longer drying
two things to check take rear half of cabinet off and check the dryer duct (lhs from front) is not blocked. this is very common check water is being taken in during dry - the water is used to condense steam from the drying clothes. easiest way to check this is to see that some water is being drained during the drying cycle. i assume that drain is operating ok
Jun 03, 2007 | Zanussi ZWD1270 Front Load Washer / Dryer
Miele 24 in. G665 Built-in Dishwasher Logo
416 people viewed this question
Top Miele Dishwashers Experts
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
