Question about JVC Audio Players & Recorders
I have a LT-37sh6 tv and a JVC DR-mh200sek dvd recorder.I cannot record any programes and the tv channels on the dvd player have no sound.On previous recordings and dvd playback there is sound.I also cannot tune into the av channel l1 or l2 ?
  • Anonymous Mar 29, 2014
    also cannot record program that is playing
  • 2,071 Answers
No sound problem is power amplifier trouble maybe the IC there is defected or cold solder of joint of the parts.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If i have helped,please click fixya.It is the only way i get paid for my work...
Posted on Jul 16, 2008
I have a THS220 box and have difficulty recording programmes
Hello Joan,
To record a satellite you will need two scart leads.
Plug one end of the first scart lead into the "DVD/VCR SCART" socket on the back of the satellite receiver, then plug the other end into the "INPUT" scart on the back of the VCR. Take one end of the second scart lead and plug it into the "OUTPUT" socket on the back of the VCR and plug the other end into "SCART IN" socket on the back of the TV.
To record, select the satellite channel you want to record, then, on the VCR, select scart input, (at this point, you can record a satellite program). To watch a satellite channel or recorded satellite channel, select the scart input on the TV.
If you need anymore information, then let me know.
Kind regards,
Ron.
May 04, 2014 | Thomson Audio Players & Recorders
Can i play records through my sherwood rd6108 receiver? When i try to play a record i get no sound no matter which channel i use.
Record players require a PHONO input on an amp.
Most amps no longer have this, so you will need to source out a pre-amp for the record player, and then you can plug the record player into the pre-amp and then hook the pre-amp into a tape, DVD or AUX input.
Feb 27, 2011 | Audio Players & Recorders
I have sound when I play the dvd or the cd player
Sounds like the setup info got scrambled in the receiver. Re-program the TV input...from optical or coax or whatever way it is going into the receiver.
Apr 06, 2010 | Harman Kardon AVR 230 6.1 Channels...
Hook up dvd
not much info, use the 3 colour RCA cables that usallly come with your DVD player, they will be white/red (sound) and yellow (video) plug these between the outputs on the DVD player to a spare input on the tv or amplifler input, recommend using the DVD input. This should be all that is needed, if it is a dvd recorder you will need to have this in the loop of the areial, so it would go >wall socket>digital settop box( DVB box/HD/SD tuner)>DVD/dvd recoder>VCR>TV(if you want to retain older analog channels, hope this helps
Cheers Toby
Mar 22, 2010 | Audio Players & Recorders
Much loved old J.V.C. unit
Sounds to me like the belt drive is slipping!
Need to open her up and check tightness of belt and probably try to buy another one which will be tighter!
Mar 21, 2008 | Audio Players & Recorders
Setup configuration
Have you tried to? I would need to see a wiring block. unit to unit, labeled at each unit including the monitor. I'll bet you can do what you seek to acheive..Give me more info, I'll show you how to do it.Just a list of makes,models,serial #s. If you have all this in PDF files, shoot 'em to me.I'll draw thr lines for you.
Dec 30, 2007 | JVC RX-D301S Receiver
Can't view picture, but can hear sound
Are you trying to record TV signal onto a DVD, or are you playing back? What make & model is your TV and DVD player/recorder?
Oct 22, 2007 | Yamaha RX-V620 Receiver
62 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
