Question about HP Color LaserJet 2600n Printer
Can not print an image from e,machine T3642
When Print task is activated, the Print Picture dialog box appears: can not
choose a printer, layout, paper or send image to the printer.
  • HP Master
  • 2,794 Answers
Unistall the Windows XP drivers
and reinstall this set here
Posted on Jul 16, 2008
I want ti print in color only,how do i do that,?Lexmark X1240 All-In-One InkJet Printer
On your computer, with your file open (your document/picture, etc. that you wish to print), click File > Print. From Print dialog box, click Properties, Preferences, Options, or Setup (depending on the program). The Print Properties dialog box appears. From the Quality/Copies tab, make sure there is no check mark in the "Print Color images in Black and White ". Then hit OK button to save the setting. Once you print your colored document/pictures, etc, it should come out in color.
I hope this helps.
Dec 02, 2011 | Lexmark X1240 All-In-One InkJet Printer
Need step by step instructions on how to duplex with my mfc 8500
1. From your application, Choose the print command (in ms Word "Ctrl + p"C1. From you application, choose the print command (in ms Word "Ctrl + p")
2. Choose the name of your machine in the Print dialog box and click Properties.
3. Choose Duplex / Booklet in the Properties dialog box and click OK.
(see page 57 in the manual)
Download Manual Here
May 05, 2011 | Brother MFC-8500 All-In-One Laser Printer
I have a pinnacle Pro 901. How do I print in black & white only?
Hello, try this: Start Menu, > Printers and Faxes> then right-click on your printer. Move the pointer down to 'Printing Preferences' and click the 'Advanced' tab. There you will (should!) see 'print in greyscale' . Select this then click 'Apply' then 'OK' at the bottom of the page.
Regards,
nicam49
Dec 01, 2010 | Lexmark X2250 All-In-One InkJet Printer
In the past I was able to choose the Manual Option which allowed me to print on both sides. Now every time I choose this option, it goes to Off. Can you please help me with this problem?
Many printers support duplex printing, but they don't all make the duplex option available in the same way. With some desktop printers, choosing duplex means that the printer prints all of the copies of the first side of a page, then pauses and asks you to flip the sheets that it just printed and return them to the printer, after which it prints all of the copies of the second side. This method is called manual duplexing.
To print on both sides of a sheet of paper:
  1. On the File menu, click Print.
  2. In the Print dialog box, in the Name list, select the printer that you want to use.
  3. Click Properties.
Note The information in the Properties dialog box varies depending upon the manufacturer of the printer you're using. With some printers, you will see a Layout tab with a Print on both sides option on it. With other printers, you might see a Features tab, and the duplex option might be called something like Two-sided printing. Explore the various tabs in the Properties dialog box until you locate the duplex printing option.
  1. Choose the duplex printing option that you want.
The options will be called something like Long edge (or Flip on long edge) and Short edge (or Flip on short edge). Whether it's better for the paper to be flipped on the short edge or the long edge depends upon the type of publication you're printing. You might need to print a test publication or two to discover which option works best.
  1. Click OK to close the Properties dialog box, and then click OK again to close the Print dialog box and print your publication.
Sep 25, 2010 | HP Deskjet 2460 InkJet Printer
Print is blank on middel side
check the margins of what you print..then check when you click print it will show the dialog box prompting you that you will print the blah blah blah...then click properties,,another dialog box will appear check if the page layout of your printing document and your printer settings are the same...hope it can help you..
Feb 06, 2010 | Epson TM-T88IV Thermal Printer -...
How to save in acrobat .pdf ?
PDF (Acrobat) files are a great way to make sure documents are viewed with the correct layout and fonts - even when the recipients don't have the program you used to create the documents. It's also a format that is viewable across multiple platforms. In order to create a PDF file in Windows you need to be using Adobe Acrobat Distiller.
Open the file you want to make into a PDF.
Choose File, then Print.
Use the PDFwriter option when printing from a word-processing application: Choose PDFwriter from the Name pull-down menu in the Print dialog box. Fill in the document information, then click Save.
Use Acrobat Distiller option when printing from a page layout or design program: Choose Acrobat Distiller from the Name pull-down menu in the Print dialog box. Fill in the document information, then click Save.
Jan 03, 2010 | Adobe PageMaker 7.0 for PC
Paint Shop Pro 9 Printer Selection (no options available)
There is a workaround which will be suitable for those who use Print Layout in PSP instead of just Print.
With your image open in PSP, goto >File >Print Layout.
Now in the Print Layout screen, goto >File >Print Setup (or just click the Printer / Page Setup Icon).
The Print Setup window will now appear with just your default printer displayed. There should be a Print Setup button next to the Properties button, but it never appears in Vista. You can, however, still access it.
Just press 'Alt-P' and the small print setup dialog box appears, allowing you to choose a different printer!!! happy.gif
Jan 08, 2009 | Corel Paint Shop Pro 9
Mirror image
Printing Iron-on Transfers
Load the iron-on transfers.
With your document open, click File, then Print. The Print dialog box appears.
In the Print dialog box, click Properties, Preferences (or Options).
Select a print quality:
In the Print Properties dialog box, click the Quality/Copies tab.
From the Quality/Speed area, select Normal or Better.
Select a paper type:
In the Print Properties dialog box, click the Paper Setup tab.
From the Type area, select Iron-on Transfer.
If your software program does not have mirror or iron-on settings, select a print layout:
In the Print Properties dialog box, click the Print Layout tab.
From the Layout area, select Mirror.
Click OK.
To print your iron-on transfers, click OK.
NOTE: To prevent smudging, remove each iron-on transfer as it exits the printer and then let it dry before stacking.
Mar 29, 2008 | Lexmark P4350 All-In-One InkJet Printer
Ink
Normally when you install the print software you install HP Director or solution centre software that has a estimated ink staus monitor..from user manual
Check the estimated ink levels You can easily check the ink supply level to determine how soon you might need to replace a print cartridge. The ink supply level shows an estimate of the amount of ink remaining in the print cartridges. Tip You can also print a self-test report to see if your print cartridges might need to be replaced. For more information, see Print a self-test report. To check the ink levels from the HP Director (Windows) 1. In the HP Director (or HP Solution Center), click Settings, point to Print Settings, and then click Printer Toolbox. Note You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device. 2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear. To check the ink levels from the HP Image Zone software (Mac) 1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then choose Maintain Printer. 2. If the Select Printer dialog box appears, select your HP All-in-One, and then click Utilities. 3. From the pop-up menu, choose Ink Level. The estimated ink levels for the print cartridges appear.
Print a self-test report If you are experiencing problems with printing, print a self-test report before you replace the print cartridges. This report provides useful information on several aspects of your device, including your print cartridges.
Load letter, A4, or legal unused plain white paper into the paper tray.
Press and hold the Cancel / Resume button and then press the Start Copy Color button
The HP All-in-One prints a self-test report, which might indicate the source of the printing problem.
Jan 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP Color LaserJet 2600n Printer Logo
22 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
