Question about Samsung Televison & Video
Txr2035 analog flat screen tv
Tv won't turn on...either via remote or manually...
is there a re-set button?
what could be the problem?
Posted on Aug 14, 2008
Try to turn on via remote or button on set. Only a green flash on front. Nothing else. Can I fix it?
About 435,000 results (0.80 seconds) Search Results
    3 Ways to Program an RCA Universal Remote - wikiHow > ... > TV and Home Audio > Television
    wikiHow... Universal Remote. Are you tired of juggling three or four different remotes just to control your home theater setup? ... Log in via ... Turn on the device you want to control. ... Press and hold the button on the remote that corresponds with the device.... You will need to try another method in this article to program the remote.
    How to Program an RCA RCR312W Remote: 15 Steps ... > ... > TV and Home Audio
    wikiHowHow to Program an RCA RCR312W Remote. ... Log in via ... Press the PLAY buttonevery five seconds until the component turns off. ... If component does not respond or has limited functionality, codes in a different block list can be tried until you find the code that allows the remote to .... Set Up a Home Theater System.
    Your remote reprogramming woes solved - Rogers RedBoard
    Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... You can always contact us via our Facebook page or tweet us ... Hi my TV is anRCA model # RLDED3258A-B I have tried 73 codes from Universal .... I have tried toset up my tv and home theatre with the Rogers remote but no luck...
    RCA TV: input channel/s-video -
Jan 19, 2016 | RCA Audio Players & Recorders
I have try several times to connect my Welby big button remote control to my Panasonic TV.I have the codes of the TV but I can't get it to work.can someone guide me thru.I will appreciate it.
[PDF]Big Button Universal Remote Control User's Manual
Big Button functions just like your original remote ... On the remote control, press and hold the MODE button (TV, VCR, CBL/SAT or. DVD) until the .... Q. Why won 't my Big Button work? A. Make .... PANASONIC 008, 051, 057, 076,. 149, 247 ...
[PDF]Big Button Remote Control Set-up Codes - ValuNet
Innovative System's Big Button Remote Control ... TV. Quick. Number. Manufacturer/. Brand. 0. SANYO. 1. SONY. 2. SANSUNG. 3. LG. 4 ... PANASONIC. 6.
Remote Control Setup, Codes and User Guides - FiOS TV ...
Verizon CommunicationsThis page provides links to setup instructions, remote control codes, user guides, ... No code for my device ... Want to buy the Verizon P283 Big Button remote? Gmatrix Big Button Universal Remote Control ..
Dec 14, 2015 | Panasonic Televison & Video
How do I change from Digital to Analog TV?
source mode,(button on tv usually next to menu) tv menu ( usually first page at top of screen), . or tv/dtv on remote ( some times just say DVT on it but you press it twice to go analog ) it all depends on your tv, also depends if the system on the tv has been updated some tv's when the change over happens, remove analog settings so there is no analog on the tv just digital. you can buy an analog box that will fit to the av socket or just connect a old video to the scart socket and get analog that way.
Sep 14, 2013 | Coby TF-TV3217 32 in. LCD TV
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
RCA Truflat TV 27F522T is completely locked both manually and remote do not work. Was working manually but after checking menu for block accidently FPA locked not can't turn on tv at all.
You must have its remote control to unlock this TV. Try to make your remote control get repaired, and check these.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jun 28, 2012 | Televison & Video
Rca 24" tv remote won't operate tv
If set turns on with the power button on set the remote is : not set to TV, not programmed for the set, has bad batteries or is bad.
If it even works one function it may need to be reprogrammed or taken apart to see if works---you can test the remote by pointing it at a digital camera with a LCD screen and pressing buttons to see if it makes the screen flash on the camera.
Test the remote first
Apr 09, 2012 | RCA Televison & Video
Televison & Video Logo
63 people viewed this question
Jerry Greenberg
Jerry Greenberg
