Hi
try this links. http://support.microsoft.com/kb/909819
Thanks!!!
This is simple 123
1. Clean the pick up lens with 100% cotton.
then you test run, if not reading again proceed to #2
2. check the flex ribbon wire of the pick up lens, replaced a new one is good!. if not reading again go to #3
3. Replace the pick up lens...
This is the 3 step simple method to fix the unreadable disc for xbox
Thanks!!!
The XBOX systems depending on the one you bought has one of 3 possible
DVD Drives in the system. Thomson, Phillps and Toshiba. The Thomson
drive is one of the worst drives to have as it has a high rate of
failure. It could be the possibility of your DVD Drive is starting to
fail or having problems with some games.
The other possibility is that your XBOX is starting to overheat which can cause problems reading discs.
Lastly, it could simply be there may be a problem on the disc your XBOX
picks up and your brother's doesnt. Try cleaning your disc in a
circular motion or cleaning with a non-abrassive cloth from the inside
of the disc outward.
If the problem persists, find out about having your XBOX serviced.
If the disc works on other machines its your disc drive
if you got warranty USE IT,
or you can trade it in and get a 360, one realese of the xbox had a hardware issue (disc drive) which microsoft replaces's you can contact microsoft to see in you fall in this catagory..
if not repairs are straight foward,
1.) open the xbox up
2.) remove the disc drive
3.) purchase a replacement
4.) put it in
5.) thats it
the drive is held in place by some screwas and a cable.. It wont take brain surgery to replace it
Here is an Xbox repair guide it will confirm what i am saying and show you exactly how to fix it,,, Its cheaper than you may think, ,, The guide is free
here is the direct link in case u missed the axcess link
http://www.llamma.com/xbox/Repairs/repai...
U read the manual i posted ?
my xbox 360 says unreadable disc with all games. it just started this today. up till now it has been fine
