SOURCE: Shredder motor seems jammed
must disassemble feeder unit and visual check for jam. The debris may be a part of the shredder that has broken off.
The teeth on the plastic gear that turns the massive metal gears that turn the shredder teeth is probably stripped and needs to be replaced, if you can find the part.
SOURCE: Just not working
Make sure the power cord is all the way in.
There could be a blown fuse. It is hard to trouble shoot when there is not power to any system.
let me know
good luck
SOURCE: Royal 15mx only works in reverse after clearing jammed paper
try resetting the shreddar, unplugging it waiting for about 20 seconds and then plugging back in. Check to make sure there is no paper or paper clips stuck in the shreddar, make sure the unit is properly mounted on bin, the overheat light isn't on is it? if none of this helps and you have a warranty on your shreddar now would be a good time ot call them as you might have a hardware problem.
