Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Machine won't turn on!
Our Saeco superautomatica's lights don't turn on anymore when we turn the machine on.  It is plugged in, the socket is not faulty, the lights just don't turn on anymore and it just doesn't work anymore!
  • broadfoot2 Jul 17, 2008
    how do I access the boiler?
  • mastrFixer Jul 22, 2008
    i found the two fuses and reset them, i read that there are three fuses... where is the third.
  • 74 Answers
What Mirran is trying to tell you that the fuse needs to be reset.
if you find the round boiler push the fuse to reset it, its light brown
Posted on Jul 16, 2008
  • 515 Answers
I think your fuse in the machine is gone.
Open the top and check it, if you have a round boiler then the fuse i located on the boiler, if not a round boiler then you had it on a cable.
  • Mirko Blas
    Mirko Blas Jul 16, 2008
    Yes, thats right Kaffesumpen. I´m still not awake. Sorry:-)
  • Mirko Blas
    Mirko Blas Jul 17, 2008
    You have to lossen the two screw in bean hopper and that one under the water tank. Open the door where the dregsbox is and look in each corner in the front, there are one screw in each corner you have to loosen. Remove the steam knob and lift off the top.
My Saeco Vienna Superautomatica leaks
Check the little chamber under the white plastic valve behind the brew unit, that might be blocked with coffee.
Apr 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Superautomatica will not make a full cup of coffee
I'm wondering if you had any luck solving this? After 3 years of great coffee, my machine is only making a 1/4 cup or so. All parts are clean. I'm guessing something on the circuit board that the dial is attached to....thanks!
Feb 27, 2010 | Saeco Vienna SuperAutomatica Coffee...
There is no power going into the machine
HI
Here are the things to check.
Power at the wall socket.
Power filter
Wire off.
Fuse or reset button on the boiler.
Control board.
Nov 28, 2009 | Saeco Vienna SuperAutomatica Coffee...
Brand new Saeco Villa machine won't prime
Press hot water button then open valve, then push the valve knob in if that works take it back and tell them that the valve is damaged.
Aug 29, 2009 | Saeco Vienna SuperAutomatica Coffee...
Need to take out brew group jammed
Hi
Look on the left side where the box should be. In the left side towards the botton there is a long opening. Take plastic knife and slide it in while the machine is on and blinking and see if the brew unit will cycle. The drip tray has to be in for this to work. There is a metal bar that has to be pushed toward the rear of the machine to cycle the brew unit.
Apr 23, 2009 | Saeco Vienna SuperAutomatica Coffee...
Hot water
Grinds are too fine and or the coffee chute is clogged.
Feb 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
Machine will turn on but that is it
The light 20 is power control light, 26 light if any problems are indicated on the machine and should only light if there are any trouble with the machine. 22 should light when the temperature is right.
Try to open the steam knob and make a cup of water.
Apr 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
Proble with old model of saeco superautomatica electronic twin
most likely a component, i suggest returning for service or replaceing
Dec 10, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
454 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
