Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Scanning I need to know how to use the scanner
  • 304 Answers
Http://www.kodak.com/global/en/service/products/ekn033540.jhtml?pq-path=9104
Here is a link where you can download all the documentation for your unit for free:
This is a Fixya rating for sure.
Posted on Jul 16, 2008
  • George Kohler
    George Kohler Jul 23, 2008
    Please log in and rate this comment fixya if it helped you resolve your problem. If it did not send me an E-mail with
    your phone number to geokohler@gmail.com And I will help you fix your problem. Do not rate the problem until We
    have it fixed.
    Thank you,
    George
    Ps. This is totally free or charge to you. I even pay for the call.
How can I use scanner on my printer? my printer says it is a printer, scanner and copier. I do not know how to use the scanner. I put a print under the lid, pressed scanner, but where is the picture/print?...
You need to install the software that came with the printer. Then in the HP program group there will be a number of programs, one of which will allow you to scan. Try all the programs if you do not know which one to use (on my printer I have to use the HP Solution centre program).
Mar 02, 2011 | HP PSC 2175 All-In-One InkJet Printer
I downloaded the disk for my scanner and now I dont know what to do so I can ues it.
Not sure what kind of scanner you have, but on my Lexmark, I have to push the scan button on the printer to scan. It then downloads the application list to the scanner, and scans. After it scans, then the Lexmark Imaging Studio (the downloaded program on the computer) comes up on the computer screen, and received the scan. Not knowing what kind of scanner you have, I can only explain in generalities. Good luck, and hope this helps.
Jun 16, 2010 | Office Equipment & Supplies
Scanning is extremly slow
What interface? If it is a USB interface the scanner sends the numbers the same as if you had entered them on the keyboard. If you do just enter the barcode (need to know format actually sent to application) numbers does it also respond slow?
Plug the scanner into another PC/laptop, open notepad and scan a barcode, does it scan fast?
The POS application, if it is windows, open notepad and scan the barcode, does it scan faster.
It is likely the POS application that is responding slow.
For the POS applicaton:
- Is scan database local or on the network.
- Have you maintained the scan database? Re-index, compacting, etc
Apr 13, 2010 | HHP 3800g Handheld Barcode Scanner
How can I scan from my scanner to my computer
Of course scanner have it's own freeware software provided with driver & software for your scanner with all operating system required.
Run the Disc to install a program with the drivers also to let you scan documents, pictures, & etc...
All the setting are there to know how to scan.... First Preview it then scan and it will send to your driver (destination folder) where it saves the files.
Sep 19, 2009 | Epson Perfection 2400 Photo Flatbed...
Can I scan
go to scanners and cameras in the control panel and double click on your scanner, you should now be able to use your scanner directly without using Kodiak's software.
Aug 14, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How to scan in text formate in ricoh2030
You need an OCR (Optical Character Recognition) program such as Textbridge or Omnipage ect. The program should use your scanner to scan and then read the page(s) and save as text.
Jun 11, 2009 | Ricoh Aficio IS420 Flatbed Scanner
Documents when scanned have lines or is half scanned.
Look at the optical scanning strip (small strip) and clean it with some WIndex. This is an ADF scanner right? If not, still clean the glass.
Jan 22, 2009 | Visioneer Office Equipment & Supplies
PSC 6000 Plus not scanning
There are a few questions:
What kind of cable do you use?
USB, SERIAL, PS2
What kind of computer?
Normal computer or Laptop?
Then...
When you recieve the scanner like new you always have to program it.
First you do
Reset to factory defaults.... Never do this with working scanners
then
you have to program it.
First the Connection type
and then if needed a computer type.
After that you usually have to scan a suffix.
This means when you scan a barcode it needs to do something after.
normally it doesn't give Enter after you scan.
That is what the suffix is for.
and then you scan additional symbologies to scan
Like Code 39, UPC A etc. etc.
It needs to be programmed with the manual you recieved.
if you don't have it you can download here.
http://www.scanning.datalogic.com/sitefiles/manuals.aspx
go down in the list to quickscan 6000
and programming manual.
please don't print all the pages. only what you need.
If you need more help i will hear it.
good luck.
Jan 09, 2009 | Datalogic QuickScan® QS6000 Plus...
HPLS2208 needs enter after scan
Check to see if there is a scan book that came with it. It will allow you to program the scanner to automatically read the code and enter after every scan.
Feb 25, 2008 | Symbol LS2208 Handheld
Scanner isn't scanning all the time
It doesn't sound like a power issue. Most likely it either needs cleaned, or it needs the laser recalibrated or replaced. Try cleaning the glass for starters, and then hold the scanner about two inches from a white piece of paper. You should get a solid, bright red line. If the line is distorted you need to recalibrate the laser. If it's dim, the laser unit is going out. The laser can be replaced, but I don't know if it's one of those things where the part plus labor costs more than replacing the scanner.
May 31, 2007 | Datalogic Gryphon D200 (901661076)...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
37 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
