Question about Dryers
I have a Maytag Neptune MDE4000AYW Dryer. The internal light is on but the control panel will not start the dryer. The breaker did not trip, i have full electricity to the dryer. My settings work but will not preform when i press the start button. Is this an internal electrical problem? Can i fix this myself?
  • 525 Answers
This is your complaint;
"I have a Maytag Neptune MDE4000AYW Dryer. The internal light is on but the control panel will not start the dryer. The breaker did not trip, i have full electricity to the dryer. My settings work but will not preform when i press the start button. Is this an internal electrical problem? Can i fix this myself?"
Thank you for providing a valid make and model number!
Tip: A volt-ohm meter is a valuable tool for diagnosing problems.
My Solution:
!. Sometimes a breaker will only trip 1 side of the 2 sided breaker. Reset the breaker by flipping it off then back on to remove any doubt!
Note: This is not 100% positive, as a breaker can fail on 1/2 the sides, so you will need a meter to test voltage, if you have ruled all else out.
2. Sometimes a thermal fuse in the dryer will open due to a venting issue. The fuse is mounted on the blower housing
or on the element tube. See links for part diagram: http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=516650&PPStack=1
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1660&PPStack=1
See this link for diassembly procedures:
http://www.repairclinic.com/0100_18.asp
Inspect your vent thouroughly for obstructions. Also, inspect your lint filter if you use fabric sheets, by holding the filter flat under running water. If the water beads up and does not strain through the filter screen, replace the filter and avoid using fabric sheets.
3. The door switch may have failed, see link for part diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46718, See item no.6.
4.Wiring: The wiring at the dryer terminal block may have burned up. See link for diagram:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=516193&PPStack=1
5. Push to start switch failure. See link below:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1033496&PPStack=1
In an effort to improve my quality of answers, please show your appreciation by rating the effectiveness of my answer.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 16, 2008
Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
May 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag mde4000ayw won't start. moisture monitor
This is either your start switch or your motor that is bad. I would suggest you begin with the start switch. We love Maytag appliances and we also love the moisture monitor on this model of dryer.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct switch out to you asap.
We look forward to working with you and hope to get you back to drying right away.
Happy Holidays to you!
Ella
Nov 12, 2009 | Maytag Neptune MDE4000 Electric Dryer
Circuit breaker trips after 10 minutes
could be a weak breaker,or poor high resistance connection from panel to dryer plug, then have someone check the current draw on the dryer while operating and see if it's within specs of the machine tag, if it's higher than that you may have a defective motor or heating element to case causing a higher than normal current draw
Nov 09, 2009 | Maytag PYE2300AY Electric Dryer
I have a MDE4000AYW Neptune dryer and at times the machine will trip the breaker over and over and then again I can run several loads and it will run fine
There is no way to guess what this problem is. The breaker could be failing, but you need an ammeter to test the current draw. Could be a loose connection, could be a failing element. You need to troubleshoot the problem with a meter
Sep 04, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My maytag neptune has no power any suggestions
Check for ~220 volts AC across the two slanted contacts on the dryer power socket. If nothing, check the house electrical panel for tripped dryer circuit breakers(pair)--push the breakers OFF, then ON to reset. Recheck for 220 volts at dryer socket--if ok now, try the dryer. You need to use a voltmeter for this checking. If it starts, then quits, you likely have an internal short (heating element) inside the dryer case that trips the circuit breakers.
Jul 23, 2009 | Maytag Neptune MAH9700 Front Load Washer
Neptune Intellidry dryer.
You need to do a continuity check on the dryer cord. Also manually reset the breakers and make sure you have power (both legs). After this and you still have trouble, do a continuity test on the door switch. The door switch will keep a dryer from operating. After that, you will need to check that your motor is being called to come on. Also check the capacitor and that it is reading the correct microfarad's with in 5%.
Apr 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Electric Dryer
pf = power failure
do= door open
the dryer is tripping the breaker because your house wiring is probly not up to snuff, or you have a bad breaker. nothing you are saying sounds like a dryer problem, but could be a big issue with house (could be very bad, could cause fire)
May 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
303 people viewed this question
Top Dryers Experts
