Question about Star Logic 17" LCD Monitor
Black monitor when i turn my computer on the left side of the monitor goes black from top to bottom if i press on the screen it will be normal sometimes this will last for minutes and sometimews i cant use it for hours
    Problem Solver:
  • 6 Answers
If you are the technician open you monitor theres something loose wire in horizontal or loose solder
Posted on Aug 18, 2008
Display half of screen
screen back light on the other side is busted which need replacement.
Jul 14, 2012 | Computers & Internet
When my computer boots up sometimes the screen is ok, but more often the screen fades and goes black. If I switch the monitor off and then on again the screen shows the icons etc for about 2 seconds and...
This could be that the screen topback light or bottom back light is bad or the inverter.
the topback or bottom back light could also be seing as the flouricent of the screen that light up the screen to enable display visible.This top back light or botom back light as the name implies is positioned at the top and bottom side of the screen.It takes an expertize knowledge for one to be able to change the flouricent when comfirms bad.The same is applicable with Inverter.
Jan 06, 2011 | Proview PL913S 19" Flat Panel LCD Monitor
Pioneer AVH-P4000DVD video goes black after 2 or 3 seconds. I can touch screen and it comes back but for only a couple of seconds. Audio is fine
You pressed the Disp. Off button on the bottom left corner. If you press it again it will stop turning the display off.
Oct 25, 2009 | Pioneer AVH-P4000DVD Monitor
Strips of 2 inch wide black and white, running top to bottom
Definately a damaged screen, no way to fix it for less than the cost of a replacement screen sorry.
Jun 16, 2009 | Philips 200P4 (Silver/White) 20.1 in. Flat...
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
My Computer Screen
My monitor problem is: it's screen display rotate 90 degrees to left, so we can't watch it normally, I can't work with some program (word, excel, and adobe reader, etc) because it's screen dislay isn't at vertical position but falling to left side. How can I fix this problem? Help me please.
Post by: Syukri Datasan
Aug 19, 2008 | Gateway FPD2275W LCD Monitor
Hi, I have a compaq deskpro that is working fine however, the monitor is having trouble. I took the monitor to the shop and it is fine also. Likewise, I placed a monitor from another computer onto the...
The monitor setting in windows maybe incorrect. When booting up before you get the windows logo start hitting F8 and then choose safe mode. If your monitor works in windows there then check the monitors settings. You may have a driver issue or a settings issue when in normal windows mode.
Jul 07, 2008 | Compaq Computers & Internet
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Dec 24, 2006 | HP Compaq FS 7550 17" CRT Monitor
Star Logic 17" LCD Monitor Logo
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
ray gallant
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
