Question about Tomtom ONE GPS Receiver
Will not turn on!!!!!!!!!!
I have a tomtom go 510. It will not turn on! I tried the reset button in the back. Nothing! Can this be repaired or worth repairing? Who can I get to repair it! thank you ,,Brian V--airman15905@hotmail.com
  • Tim Babcock
    Tim Babcock May 11, 2010
    Are you able to get it to function when pluging the USB cable into it as well as the computer?
Not at all.even with the USB to the computer??
Posted on Jul 17, 2008
Tomtom 510 - packed up
try re setting the TomTom, reset button is founded on the bottom underneath where the docking mount connect, hold down for 15 seconds, then press the little button on the top on the right side while turning on. worked for me
Jun 06, 2010 | Tomtom GO 510 GPS Receiver
Wont turn on
Do a reset. Check TomTom website to find where your reset hole is. Use a paperclip to do the reset.
Apr 26, 2009 | Tomtom GO 510 GPS Receiver
Tomtom 510 will not activate. tried it with connection to electrical outlet and without being plugged into the outlet. It quit working after it was plugged into an automobile cigarette lighter plug, then...
After posting my problem, I did some more browsing and came across this on the amazon webiste:
31 of 32 people found the following review helpful: stars-4-0._v45457020_.gif Cure for not able turn on the Go 510, 16 Jun 2007 By Sirius (Essex) - See all my reviewsI like the tomtom so far the only niggle was it would not turn on once.
No troubleshooting on instructions, found cure on internet,reset button
underside. With the tomtom turned over and the card slot on top right hand
side there is a small rubber foot at the half moon shaped enterance, up at about the 10 o'clock position from the foot,but before the green circuit
board there is a small half round cut out with a hole under you need to press in this hole for a few seconds with a paper clip to reset. I wonder how many people have sent their tomtoms back that would not turn on.
Tried it & worked a treat!!! Newcastle here we come again ...
Apr 07, 2009 | Tomtom GO 510 GPS Receiver
Tomtom 510 doesn't reset
Before you keep resetting your tomtom I would intall a new battery. Call your closest "batteries plus store" or "radioshack store" and then try to reset it, it might be only the battery and nothing to do with the reseting.....
Mar 24, 2009 | Tomtom GO 510 GPS Receiver
Tomtom 510 will not switch on.
Hi!
I have in my possesion 2 Tom Tom 510s both with exactly the same problem, one was used with the incorrect (Nokia) cigar lighter charger the other suffered a Voltage spike from the vehicle it was used.
Both the input transitors have blown and as they are so small they are virtually impossible to re solder. However there is a Guy on eBay who for £80 will repair it.
I bought a different system, £70 and although basic does what it says on the tin.
Sorry to bring bad tidings,
Paul 'W'
Jan 05, 2009 | Tomtom Go Plus GPS Receiver
Frozen tomtom
You can get your original splash scren from here. You can also download free splash screens created by user through TomTom HOME.
To correct your device, try:
1. Hit the reset button on the back of the device - inside the serial connector.
2. Make sure the device is off and connect it to your computer via USB dock and connect the charging cable (green light should be on)
3. Hold down the power button until the device restarts.
4. The device should automatically connect to your computer.
5. Run TomTom HOME and check for any updates.
6. If there is no new application, try: www.tomtom.com/9091 <-- that will show you how to remove and then reinstall the application.
Dec 22, 2008 | Tomtom GO 510 GPS Receiver
GPS Won't Turn On
www.batteryship.com
look up tomtom 510 - or whatever model you have
Order the battery..........comes with manual and tools to fix it
only 20.95
it works
cheaper than sending it in!!!!!!
These are genuine replacement parts!!
Laura
Jan 30, 2008 | Tomtom GO 510 GPS Receiver
Is there sonething wrong with my tomtom go 510?
Usually resetting the unit (pressing the reset button) is supposed to fix this
Oct 22, 2007 | Tomtom GO 510 GPS Receiver
Tom tom go510
Try this,http://www.tomtom.com/support/solution.php?GID=1&PID=234&SID=0&CID=152&Language=1&FID=4229 reset
May 11, 2007 | Tomtom GO 510 GPS Receiver
Frozen tomtom
Is there a reset button? See this from PocketGPSworld.com: Reset hole The Reset hole is hard to find, you need to first remove it from the mount, turn it upside down, and within the mounting base area of GO you will see two interface slots (currently only one is being used) and towards the front of the unit on the base you will see a little hole marked reset. This is just like soft resetting a Palm or Pocket PC, it requires something small like a paperclip, and nothing was supplied with GO to enable you to easily reset the device.
Feb 25, 2007 | Tomtom GO 510 GPS Receiver
Tomtom ONE GPS Receiver Logo
52 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
