Polaroid DRA-01601A Power Supply Failure
*I think I accidentally posted my question as a solution just early to someone else's similar question. Sorry.
QUESTION:
Has anyone been able to locate schematics for the power supply in this thing? The undersized power supply seems to the main point of failure. Otherwise, I have been pleased with the unit. Mine was sent back to Polaroid for RMA back in February 2008. I don't think any warranty is in effect now.
Please let me know if any one has tried to trouble shoot the TOPOW DVD RW POWER857B power supply. Two of the chips I can not identify are the 8pin Dip 2216A & a 4in dip 7703
I have tried to locate the power supply manufacturer: Shenzhen Topow Electronics Co., Ltd. Their website is:http://www.topow.com.cn but my web browser can't handle the Chinese to English translation.
I think it is very likely that an AT or ATX power supply could be substituted if all the pinouts of the original power supply are known.
**Both times, my unit failed shortly after the fan started making noise. The problem has to be heat related.
  • 1 more comment
  • nworley4 Aug 29, 2008
    I have the same unit with a bad power supply. I can not find out anything about it. If you found out anything about it would you let me know. nworley4@aol.com
  • derfxa Dec 10, 2008
    Might check the capacitor for power up failure... mine went down... but capacitor looked toasted...I'm going to test it...I'll keep you posted... mine is for a DVD player/ recorder with Topow Power 853D board (same circuit board maybe a few different components,,,
  • Anonymous May 01, 2009
    I have the same problem and would like to know where to buy a new one or have mine repaired. Contact me by email larrympierce@sbcglobal.net
I
I have repair my supply board by replace the 2 capacitors and 1
mosfet because the 5VDC was failure
the mosfet is a IRFP 150 or similar and capacitors are same models
becarefull the 330ohms resistor dont touch the capacitor
or a great risk of short circuit destroy the 5VDC
best regards
jean yves kerfers
olivet
france
Posted on Jan 11, 2010
Where can you buy capacitors? I have a Polaroid DRA-01601A and at least one of the capacitors is blown. Specifically CE10 from what I see on the mother board.
You can buy capacitors from many places. Radio Shack as a local store. Digi-key as an example.
Jim
Preston Computer Service
www.prestoncomputerservice.com
May 21, 2011 | Computers & Internet
Password problem
The password is for the parental control feature.
For the Poaroid dra-01601a the password is 3-3-0-8 type this in using the number pad then press ok. If you press setup on the remote then press down till you get to ATV/DTV then press right arrow button to highlight DTV Parental control, press enter then a dialogue box will appear this is where you can input the password code. Select V Chip and press ok, you will then have the option to select which content controls to use in the menu you will see Block enable, use the down arrow to highlight this then press the right and left buttons to turn either on or off. to exit this setup press 6.
Hope this helps,
James
Apr 21, 2010 | Polaroid DRM-2001G DVD Recorder/HDD...
I have the polaroid dra-01601a dvd/hdd audio
First of all with all do respect I do not have the polaroid drm 2001G. I have as I exprest in my letter to you the polaroid dra 01601A. The problem i had was an audio problem and i simply rechecked all my connections and found that I needed and extra set for HDMI plugs on my TV.
Jan 03, 2010 | Polaroid DRM-2001G DVD Recorder/HDD...
Polaroid dra-01601a hdd to dvd recording
You will have to split the title and record on more than one DVD. The default speed is SP, that is 2 hours of recording. If you want to record longer programs, go into setup and change the default record speed to one of the other settings, for example: SP+ which is 2 1/2 hours or one of the other longer record settings. This DVD burner will only record at the same speed as you recorded to the hard drive. You can also edit out the commercials by using segment. Go to the title you want, press the right arrow, scroll down and select segment. When you want to start your edit, press enter. when you want to stop the edit, press enter again. You can use your right arrow to skip forward 30 seconds and your left arrow to skip back 10 seconds if you went too far when editing. You will see where your edits are on the screen by the darker color. Do this through the whole program. When you record to DVD, the commercials will not be recorded. Hope this helps you.
May 01, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Time shift to hdd
The only way I was able to do it is to capture "while playing back" to another recorder "VCR" DVD"
Dec 10, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Transferring from timeshift buffer to hdd
When in timeshift, press record on the remote (every time you push "record" 30 minutes are added) and make sure the program you are recording is not macro protected. If your program has already finished rewind to the beginning of the program and push record the correct number of times to cover your program and then press stop on the remote. It should then be at the bottom of your hard drive list.
Polaroid DRA-01601A Hard Drive Model/Format
The HDD is 160 gigs.
The menu allows one to "format" the drive.
I have not tried this however.
Dec 04, 2008 | Televison & Video
I have a Polaroid DRA-01601A DVD Recorder (w/160gb hd). I am getting a video output on my tv as a black and white split screen. Can you help?
The picture output may be set for other than 480i. Try to connect the composite output, and you may get enough picture to change the setup to 480i.
Oct 13, 2008 | Polaroid Televison & Video
Polaroid DRA-01601A will not power up
99.9 % of the times its the capacitor which is blown. I had spent few weeks to investigate on this and ultimately found this solution. Till date I have replace two capacitors. To determine which capacitor is gone, Check on the flat silver surface of capacitor. If its not 100% flat it means its gone and you need replacement. Pl. check my attached file to understand on details of inside configuration.
Hopefully it works for you.
I am not able to upload pdf which I have created. Pl. contact me via email to get pdf file
viki_3578@yahoo.com
Regards,
viki_3578
Feb 16, 2008 | Televison & Video
Polaroid Will NOT edit out Commercials!
You need to post edit the recording;
First unprotect then do a split before the commercial
than split after, then recombine the parts without the ad.
Cumbersome, but it works
Feb 12, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Open Questions:
I have horizontal white lines across the display of my LCD Tv, I've included more info in the details section below I have an Insignia model# NS-46L780A12 LCD TV MFG date July, 2011 , recently the display has been acting very strangely because the issue comes and goes consistently dependent to whether or not there's caption writing on the screen - examples being programming information , channel , time etc.....these info blocks are each in their own particular areas on the display , where this gets odd is when your watching live TV ,these info blocks are always filled in with whichever program that's on, the best description of this issue is from these individual blocks of written captions on the screen example - from the top , there will be a continuous vertical row of horizontal lines starting directly underneath said caption all the way to the bottom , this will happen consistently wherever there happens to be writing on the screens display, so you get multiple rows of these horizontal lines from top to bottom of the display and they'll stay there for the entire time you watch your show , some shows have more ,some less ,depending on the writing for that show , this is all on cable TV / live TV I guess you can call it , and when I use my Fire TV stick with certain apps , I'll get no vertical rows horizontal white lines on the display with the exception that I push the mute button or change the level of the volume and the lines start to want to show up and do partially just for a little while ,but almost as soon as the info on the screen disappears as far as mute/ no mute or the volume level , the vertical rows of horizontal lines go away , I should also say that in either case Fire TV stick or cable , these vertical rows of horizontal lines take a little time to develope all the way from where the caption lettering begin and same process for when they go away , it's not instant in either case , it can take up a couple of minutes for either process to happen , one other oddity I guess you could say , in watching a cable tv program where you may get let's say 5 vertical rows of horizontal lines top to bottom at the beginning of the process , if you happen to try to watch that show ,those individual vertical rows of horizontal lines of varying widths will eventually connect with each other horizontally across the display
Feb 18, 2018 | Insignia Televison & Video
Televison & Video Logo
790 people viewed this question
Top Televison & Video Experts
