Question about Kitchen Ranges
Error code F93 Kenmore range model 970-686030
  • 3 more comments
  • tawknalot1 Aug 25, 2008
    F93 error code keeps coming on and beeping! The oven does not want to come out of the lock mode. I ended up having to trip the breaker because it continuously beeps!
    Is there a way to reset this or is there a part that needs to be replaced?
    I noticed that the place where it should be locking into is bent ( I have a 19 month old that is constantly slamming the oven door shut...)
    Please let me know something asap!
    Thanks!
  • Anonymous Oct 06, 2008
    I have one Kemore elite gas range model 790.3670, 790,3671 but I can't open the door, because it keep to appear an error code is F93. Can you please help me to fix problem.
    Thanks,
    Huong Than
  • Anonymous Nov 09, 2008
    I have the same problem...what did you end up doing??
  • ihatesears Nov 21, 2008
    Kenmore 790-series oven worked fine yesterday afternoon. We never use the self-cleaning feature. Last night my wife pressed the 'bake' button to begin pre-heating but she did not hear the customary beep, nor did the oven begin heating. Shortly after, the F93 error code started flashing. Looked in the manual which told us to call a support number; first support person said we'd have to call a technician who would charge $75 just to tell us what the error code meant. We laughed at him, then called back to speak to different person, who was more sympathetic but just as unhelpful. We've tried unplugging and leaving it off for a minute then plugging back in--no luck. Tried holding down various buttons for several seconds with the same result. This range is 9 days away from being purchased two years ago; the stove still works. WTF?!!
  • Anonymous Mar 17, 2009
    same thing i think its broken
I replaced door lock mechanism.....now. Error codf93 gone now, but It still is erratic...& readout juggles between loc & dr....holding the cancel...for 3 seconds, doesn't seem to help.
Posted on Feb 24, 2012
My stove just did the same thing but I have the maintenance agreement and they just told me to unplug the stove completely for 30 minutes. This will rest the internal working of the stove. Hope this helps I am trying it now
Rita
Posted on Dec 21, 2009
5 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: oven locked
F93 - Maximum oven door lock time exceeded
Door lock is jamed . or faulty let me know
Posted on Dec 25, 2008
57 varieties
  • 1653 Answers
SOURCE: I have kenmore elite gas range 790 series getting
The F93 shows that the Maximum oven door lock time has been exceeded.
Turn off the range and turn off the AC power and wait for up to 10 mins. The door should reopen. Turn on the AC power ans see if the error persists. If it does then check the following.
1. Check the wiring between EOC & Lock Motor Micro Switch.
2. Replace the Motor Door Latch assembly if necessary.
3. Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. Lock Motor continuosly runs - if Micro Switch is open, replace Lock Motor Assembly.
6. Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
Posted on Nov 12, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Kenmore elite range, model 970-698593, Error Code E015
Just asking if your model number is correct. I do not find 970 models but do find 790 models. If it is a 790 model there can be aproblem with the door lock on the oven door. You may want to check to see if all the shipping materials have been removed from the door lock / latching area. I would recommend that you review the installation instructions in the owners manual, paying particular attention to the removal of shipping materials.
Adittionally if the problem presists it says to replace the Electronic Range Control (ERC) This is not a cheap part! Good thing it will be at their expense including the repair service call..
Hopefully you have already called for warranty service? We both know a brand new oven should not be producing any error codes. If you have not called for warranty service you do so now. Make sure to tell them that you already have talked to customer support and that unplugging the unit for ANY period of time made no difference in the error code.
Thanks for choosing FixYa.
Kelly
Posted on Aug 01, 2010
  • 77 Answers
SOURCE: Kenmore GAS Range, model 970-334422,
it is very likely that the display may have gone bad. but before you buy a new one does it have any thing on it at all
Posted on Aug 19, 2010
Fridgidaire F93 error code and beeps as soon as we try to use oven. Beeping stops with cancel but stove doesn't work, last 2 days.
Computer operated and monitored devices don't like safety features being disconnected.
I did find this though.
Based off the information you have provided your Frigidaire oven is displaying the error code F93. An F93 error code means that you have reached maximum oven door unlock time exceeded. This could be a potential issue with your EOC (Electronic Oven Control), lock motor, or light switch. I would recommend resetting your range and you can do that by disconnecting power from your appliance for ten minutes. Once you reset power to your range, if you continue to experience an issue I would recommend consulting with a technician. They would need to check each component to assure that the proper amount of power is being provided to each part. I hope this information is helpful.
Also this information generally.
Fridgidaire F93 error code Google Search
Dec 08, 2016 | Kitchen Ranges
What does the F93 code mean and how do we fixt it
i know that it can be very difficult to have issues with your oven. the f93 on this model of kenmore range indicates that you have a problem with the oven door lock assembly (see image below). this can be caused by a failed oven door lock assembly, a wiring failure or a bad electronic oven control board.
i recommend that you unplug the range and check the wiring between the components first. you can remove the upper back panel of the range to access the electronic oven control board in the console. you may need to remove the lower panel to access the door lock assembly on the back of the range. the image below shows the wiring diagram and other information that should help you check the wiring connections. check for a mechanical binding of the door lock assembly as well. if the wiring connections are okay, you will likely need to replace the oven door lock assembly. if you need further assistance, please reply to this thread. thank you for using manage my life.
May 23, 2015 | Kenmore Elite 30" Slide-In Gas Range White
How i can stop the fan and open the (locked) door (error F93)model Frigidaire CGEB27Z7HB
Hello Yves Trottier, thank you for your post!
I understand that your Frigidaire range is displaying the error code "F93". Typically, "F93" stands for maximum over door unlock time exceeded. This could be a potential issue with EOC (Electronic Oven Control), motor door latch assembly, or fan motor. I would recommend performing a reset on your range which consists of you disconnecting power from the range for approximately ten minutes. If you continue to experience such issues I would suggest consulting with a professional technician for proper diagnosis and repair. Hope this information is helpful. -Matt
Dec 06, 2014 | Frigidaire Kitchen Ranges
Kenmore oven c970
The F93 error code that you are seeing indicate that you have a failure in the oven door lock circuit. I recommend that you have a service technician fix the range. Good Day
Feb 12, 2014 | Computers & Internet
I have kenmore elite gas range 790 series getting error code f93 the oven door is locked
Nov 12, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven locked
Dec 25, 2008 | Kitchen Ranges
F93 error
F93 error code means Maximum oven door lock time exceeded. Check oven door lock/door lock switchs.hope this helps
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self Cleaning
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 03, 2008 | Kenmore 94220 / 94221 / 94222 / 94224 /...
Kenmore Gas Range/Freestanding/ Electronic Ignition
I have an electronic ignition Kenmore Gas Range. The Model Number is 790.78573407.
Am getting the error code F93 in the oven control panel. The manual says the likely cause is "Maximum oven door lock time exceeded". When I plug the oven the "door lock light" flashes and then the "F93" error code flashes. Am not able to use the bake or broil.
Aug 31, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kitchen Ranges Logo
2,734 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
