Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
60PP9202/17F On my high def tuner only the picture slired to the right. It is like in the old days when the vert hold would go back but horizontally. All other methodes of input are fine.
    Champion:
  • 230 Answers
Time to fix it !!. Replace two Ic's Stk 392-110, and get in service menu settings , and adjust point by point. After replaced stk IC's, check if any resistor look brown or born, if yes, replaced it with 6.8 Ohms.Some TV have ssb ( small signal board, replaced it or rebuilding) If you have questions? noetvs@embarqmail.com . Good Luck !!
Posted on Jul 24, 2008
The picture is only about three inches high in the middle part of screen and has a slight curve
vertical circuts or vert drive circut shady easy fix need more info on tv dlp proj plasma usually bad ic 1 or 2 18.00$apiec ver def ic look up ur part #go 2 nte electrnics.com buy part tip replace surrounding capacitors and output resistors good luck
Aug 07, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
Will set be campatable after June with the new high def?
Your set is HDTV-ready....
With an HDTV-ready set you’ll need an external digital tuner to watch HDTV programming.
However, if you have high-definition cable or satellite service you can watch those HDTV stations right now on your HDTV-ready set, no extra tuner needed.
which means you will still need a converter box if you use an antenna signal.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 26, 2009 | Televison & Video
Thin horizontal lines like a ghost picture of the one showing
you have a vert fold over problem . this happens when the caps in the power supply and the high voltage section of the main board start to dry out and fail its not a do it yourself problem . the caps need to be tested and changed if there is a high ESR reading . this can be a labor of love job for an electronic hobbyst but if you going to pay someone to do it it will take time and money , most repair places will not touch this job ( we would never take on this ) theres two much time involved and two much can go wrong on an old set .... if this answer helped please rate a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Apr 21, 2009 | Sanyo Televison & Video
Need to locate the pincushion circuit on RCA F32632SB 32" TV
ok this might help rca labels their circuits this way..
0000 tuner
1000 the tv processor
1100 remote receiver
1200 audio IF
1400 a/v hifi outputs
1500 s-video inputs
1700 stereo audio demodulator
1900 audio output
2300 video IF
2400 sync separator
2700 luminance processor
2900 rgb bias and drive
3100 system control
3300 analog interface
3400 front panel assembly
3600 tuner control
4000 ac input
4100 b+ regulator
4200 degauss
4300 horizontal osc.
4400 horizontal output
4500 vert deflection
4600 standby regulator
4700 secondary power supplies
4800 pincushion correction
4900 x-ray protection
5000 kine driver
7500 fm radio
Jan 15, 2009 | RCA F32632SB 32" TV
Digital ready?
Deacon J,
You will need a digital converter box OR high definition tuner for the transition. What's the difference? A converter box will only output a standard definition signal, either on channel 3 or by composite or S video cables. A high definition tuner will allow you to watch the new digital broadcasts in hi-def, assuming they are transmitted in hi definition. The converter boxes are the cheaper option and you can get a coupon from the government for a $40 rebate on the box, but I would opt for the hi-def tuner fo the better picture quality.CNET has a good write up on the transition here:
http://www.cnet.com/1990-7874_1-5108580-3.html
I did some looking and about the cheapest hi-def tuner I could find was $150, which is 3 times what a converter box would cost. I would expect the cost to fall on the tuners over time. Perhaps a converter box may be a good solution until the prices fall, if they do. The problem is that not many companies are making the tuners, as most TV's already have a hi-def tuner built in, so there isn't a big market for the add-on tuners. I hope this answers your questions.
Dec 31, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Need a tuner for HDTV Samsung Model #HLR4667W
THERE IS A DIODE ON THE MAIN SIGNAL BOARD THAT HAS SHORTED OUT REPLACING THE TUNER IS NOT GOING TO HELP MATTERS
Oct 16, 2008 | Televison & Video
JVC AV 35750 single horizontal line
Jeremey,
It's ring cracks on the solder joints of the vertical IC... IC421 i mounted to a small heat sink on the board. With the unit off and unplugged remove the board and locate IC421 (LA7832) and closely examine the pins connecting this component to the foil side of the board. You'll notice small rings around the footings that are actually open cracks in the solder, caused by heating and cooling over a period of years. Simply and carefully reflow some solder over these cracked joints, careful not to get the ic too hot in the process, and put it back together.. That should sole the problem...
Another problem we encounter a lot in the vertical deflection circuit of this unit are the two feeder caps C424 (100UF/35V) and C425 (470uf/35v).. If you're already there you might want to go ahead and replace these as well - save taking the back off again if they go bad..
Bill
Nov 13, 2007 | JVC AV-35750 35" TV
Tosjiba cn32g90 no picture or sound
Timm,What you have Is Vert Failure,Toshiba is Noted for Bad Conns On the Vert Ic,Pull the Back off and Gently tap with a NonConductive Inturment and watch the Sceen Look for Heatsinks and Tap on those,If you know,or you caqn solder do so ,Do run the tv for a long time with no Vert or it will Cause BURN IN in the Phophurus
Jul 15, 2007 | Toshiba CN32G90 TV
Defective components in vertical deflection and output circuit inclusive of vertical output device, coupling capacitors, and yoke connectors. Passive devices such as electrolytic capacitors, coils, and resistors to/from power supply circuits. If your tele is more than 10 years old dump it and get a newer product. $100 USD is a fair price to diagnose and attempt service, depending on age and configuration. Older products may not have replacment parts available at any repair cost. There may be a pot for adjusting the vertical size. If so, it may be dirty. If you can find it, try adjusting it which could clean it. BE CAREFUL -voltages are very high.
Mar 20, 2006 | Sharp 27H-S60 TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
35 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
