Question about JVC Audio Players & Recorders
JVC TH-D60- randomly get nothing but static from the speakers. literally works fine once, and the next time you turn it on, you hear nothing but static. have disconnected every cable, and no change.
  • 2,071 Answers
Static and scratching sound caused by dirt or dust in the PCB (printed circuit board) and loose or cold solder joint ;.Clean the circuit board with the use of laquer thinner or alcohol ,so static sound will gone.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If this solution help you understand the problem :rate as fixya..
Good luck;
Posted on Jul 16, 2008
Why would JVC 8010 optic digital randomly malfunction?
I don't know if this helps but, if you have your bluray hooked directly to your tv some times TVs can have issues sending the proper channel to audio out to the receiver. You should always connect your bluray and other devices directly to your receiver.
if that's not the case,
Try turning the tv speakers back on, test the bluray hooked directly to the tv and see if things work flawlessly just with the tv and bluray.
If they don't there may be something just wrong with the cables.
If they do work flawlessly then there may be something wrong with the receiver.
If you already had your bluray connected to the receiver, I would still try direct to tv test and swapping cables.
The randomness leads me to think cables. But you can rule them out by testing directly to TV.
I hope that helps
Sep 06, 2014 | JVC Audio Players & Recorders
When i turn the cd player on it had alot of static?
Unfortuneately, the cd lens worn out, the only way to fix the problem is replace the laser pickup assembly which is not cost effective to repair.
Mar 24, 2012 | JVC CHX1000 12-Disc CD Changer
How do i hook up my tv to the sound system so i can hear regular tv through the speakers? I can hear it when i play a dvd but not regular tv shows.
The simplest way would be to run RCA cables from your Cable Box analog audio out (if THAT is where your TV programming comes from) to the available Audio In on the JVC. Page 9.
If the cable box has coaxial or optical digital audio OUT, run THAT (instead of the analog audio) to the correct Digital In connector. Page 8 and 9
This would free up the analog audio from the cable box to send directly to the TV's audio input for causal programming, like news, so you wouldn't need the JVC on.
http://www.retrevo.com/s/JVC-TH-D60-Home-Theater-Systems-review-manual/id/2771ag518/t/1-2/
Feb 07, 2011 | JVC THD-60 System
Rear speakers
If your factory wirig harness has been cut< take a 9 volt battery and touch diffrent wires, once you touch th negative and positive side of one speaker you will hear a small static sound out of that speaker. that may help you locate th speaker. and th brown will be your ground on each speaker
Apr 06, 2009 | 1999 Audi A4
Cannot figure out how to hook up my jvc th c5 to my tv & cable tv
Do you have audio outs on you tv to run to the jvc
Mar 15, 2009 | JVC TH-C5 System
Hello, I have all working speakers for the JVC TH-M505 home theater system, but the control center/receiver gave out. Do you know if I can use them with the JVC TH-M606 HomeTheater Control Center? Thanks...
If the JVC m606 requires a stipped wire to connect them then they should be fine just make sure you connect the right speaker to the proper output if your speakers have a specified connector on the end then you would have to cut that off and strip the wire. if your m606 requires a specified connector for the speakers then you would have to change the connectors out for the proper ones.
Mar 07, 2009 | JVC TH-M606 System
I have a JVC TH-D60 dvd digital theater system. My problem is I can only get 2 speakers to work at a time. They all work but not at the same time
DVD movies are so recorded as to get specific sound from each speakers, for eg, if the scene involves a bee going in circles then, the sound is first heard from the left, the right, the back right and the back left, That should explain.
Oct 03, 2008 | JVC Audio Players & Recorders
Problem with my MX Gt 88!!
use the speakers it came with it works fine for me i have mine hooked up to a 300w inverter anything less i dont get the best sound you cant turn the volume up too loud on the reciever it will draw too much power and shut it off or blow the fuse in you car unless the inverter you are using has an external fuse on it my inverter warns me that i am drawing to much power so when i hear the beep i turn it down a notch and works fine but ya try using the speakers th system came with
Nov 02, 2007 | JVC MX-GT88 CD Shelf System
Bass speaker stops working every now and then
Hi, Ive finally found the problem with my system :o) Its not the subwoofer its the DVD unit!!! think outside the box. Mine was randomly switching into headphone mode, so i pluged some headphones in took them out and walla its working fine. Not sure why this happaned perhaps some dirt or something else got inside there???? Let me know if this helps
Apr 07, 2007 | JVC TH-A85 System
No sound
Sounds to me like your center speaker is either not connected, or somehow not working. The not working part could be explained by a failed speaker or, possibly a failed amp in the unit.
Mar 11, 2007 | JVC TH-M505 System
66 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
