M dj mixer it turns on but no sound comes out
  • 2,071 Answers
No sound problem is power amplifier trouble maybe the IC there is defected or cold solder of joint of the parts.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If i have helped,please click fixya.It is the only way i get paid for my work...
Good luck:
Posted on Jul 16, 2008
I am not getting sound thur my mixer what could be the problem.
Is there any hum sound? Are the switches set to the proper inputs-phono, line?
Feb 14, 2015 | Numark Im1 2-channel Pro Dj Mixer With...
Why mixer turns on but no sound come out, just a weird interfearance noise any ideas?
Be sure the inputs are OK and the amplifier is also working. It is probably the internal power supply but that is just a best guest.
Jul 22, 2014 | Gemini DJ Gemini PS2 2-Channel Stereo DJ...
How do i hook up and ipod and/or computer to the Gem Sound CMP500
you need to connect the player to a dj 2 channel mixer using a red and a white RCA CABLE ...(line 1) then into (line 2) ... from pc /laptop ... need a stereo mini jack to 2 RCA (RED / WHITE) INTO back of the mixer ... before turning on please remember to set volume on pc/laptop 80% MAX ... and DISABLE EQ's or FX ... dj mixer has all the EQ / FX needed :
Mar 05, 2013 | Gem Sound CMP500 Dual CD / Mp3 / USB...
No sound coming from headphones using my dj mixer. however through speakers sounds fine. Im using 2 pioneer cdj 1000 mk3 and a djm 800. The sound works perfectly through speakers. how ever nothing through...
hii there, pls try to use another headphone on your mixer, if you get the same problem. It means your headphone have no problem. Problem is with the the jack of your mixture. Open your mixture and check the jack properly attached internal.
Dj Ajay
djajay@inbox.com
Nov 15, 2009 | Pioneer DJm600 DJ Mixer W/Sampler Black...
Vestax pmc 06 mixer / Virtual DJ Mix station
you need a sound card with headphone out seperate from master out
Oct 19, 2008 | Vestax Pmc06proa Thin DJ Scratch Mixer...
Pioneer DJM-600 black Professional DJ power on but not working!! i check bouth the fuses and are working i can see that is power in te mixer but no answer with any signal of leds or music signal
So you get power to the unit, but no sound coming out? How about through the headphones, do you get sound coming out of the headphones?
Are all the volumes and gains raised up? All the eq's are up? Check the back of the mixer, there is a master gain volume - where the connections are - make sure this is up also.
If nothing, then you'll need professional help at this point.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Sep 23, 2008 | Pioneer DJM-600 Silver Professional DJ...
Samsung HLN5065W freezes in black / White screen
Picture freezing that is the symtoms of depected DMD modules...
Just click below for electronics store you can order online;
Partstore.com.
Vance Baldwin Electronics
http://servicemanuals.vstore.ca/
http://www.electronix.com/catalog/
Hope this may help;
Regards,
VOTIT
Aug 21, 2008 | Samsung HLN5065W 50" Rear Projection...
Outputting high pitched sounds and master balance switch problem
Maybe the issue is not with your mixer. Maybe its with one of the units you connect to the mixer. Does this happen in all the channels?
If the service company could not duplicate the problem, then the problem might be somewhere else. Double check and replace your cables going to your amp, as well as the cables coming from your CD players and such.
- OPTiC
A DJ Pro Audio Co.
Dec 06, 2007 | Pioneer DJM-600 Silver Professional DJ...
26 people viewed this question
 Grubhead
Grubhead
