Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Cpu heatsink i bent two of my standard intel heatsink push pin locks, is there any where i could go to buy new ones?
    Sergeant:
    Champion:
  • 417 Answers
Yes Any Computer Shop
Even Ebay
Posted on Jul 17, 2008
CLip of motherboard felt off.
http://www.heatsinkfactory.com/cpu-retainer-clips-intel-pentium-4-478.html
That would be for an AOpen AX4SPE-UN motherboard, because it has a Socket 478 processor socket.
I had it happen to an old mobo in the past, with a Socket 478 processor socket; and no clips.
I used a straight piece of coat hanger, and went from hole to hole, on one side.
http://www.ebay.com/itm/P4-Socket-478-Intel-CPU-Retention-Retainer-Bracket-/140647148266?pt=US_Fan_Heatsin_Brackets_Accs&hash=item20bf392aea
Had a slight bend in the middle, and this bend went partially across one side of the finned Heatsink.
Small piece of coat hanger again, on the other side.
Cut to the right length, and with the correct bend, the two pieces of coat hanger, put even pressure down on the finned Heatsink.
Problem is they twisted. The pressure on the bent part against the Heatsink, made them want to spin up away, from the Heatsink.
So I added a piece of coat hanger on each side, to keep the side coat hanger pieces from twisting.
Hard to explain, and looked like something from Dr.Frankenstein's laboratory.
Worked though.
(Too much pressure, and it will break the plastic retention bracket on the motherboard.
Not even pressure on both sides, and Heatsink will not sit flat on Processor. This = No.
You just have to 'dial it in', (Coat hanger pieces), or use the correct part/s)
Regards,
joecoolvette
May 06, 2013 | AOpen AX4SPE-UN Motherboard
Is it possible to put the cpu back in the wrong way? i have just cleaned my comp & i removed the fan over the cpu & the video card? i put them back & now i cant get a signal to my monitor could...
If there is no activity when you power up then it could be the CPU.
Remove the CPU and check the CPU to see if you have not bent any pins. The CPU can only be installed in one position.
The CPU when removed usually sticks to the heatsink.
The CPU should be removed off the heatsink.
The CPU is locked onto the CPU chip holder, lift the locking level up to release the CPU or there may be a locking screw instead of a lever. Turn the screw anti-clockwise to release the CPU lock.
Insert the CPU in the chip holder and lock the CPU in place. If it a screw lock then turn the screw clockwise to lock the CPU in place.
Smear some fresh heat sink compound on the CPU and heatsink and place and then lock the heatsink in place.
Sep 25, 2010 | Medion (40010998)
Processors problem
Make sure your pins on the bottem of the cpu is not bent. If they are, you will need a new cpu.
Good Luck
C2Solutoins
Mar 02, 2010 | Intel Core 2 Duo E8400 LGA775 3.00GHz 6MB...
Computer wont start(Plz Help me ) Added Much Detail as possiable
start by removing everything, ram, any cards plugged in, drives etc. Then try and boot it. If the issue is still present, shut it down and remove the heatsink and cpu. I have known CPU's to be jolted out of their sockets after an impact. Take the heatsink off, lift the lever and remove the cpu. Check that all the pins are still aligned and straighten any bent pins then refit the cpu and lock the lever down. Refit the heatsink making sure that the heat transfer pad or heatsink paste is still present and lock it down. Plug the power cords and front panel wiring back in and try and boot it. If it boots, shut down and refit each item you removed one at a time, booting in between each item. If the issue arises again, the last item you fitted is the culprit. If you can refit everything and boot the system up, lady luck is with you. If you still cannot get it to boot after refitting the cpu, replace the mainboard. Sorry but without special gear, locating a fault like this on a mainboard is a real pain..
Dec 20, 2009 | Biostar G31-M7 TE Motherboard
I have an Intel Celeron D 2.26GHz Socket 478 256 k /FSB 533. Is it possible to replace the Pentium 4 1.6GHz in the Vectra with the Celeron. If so what steps would I take and will I have any XP COA...
You need to check with the motherboard maker. A manual would tell you and you might be able to get the info online if you search for the above model number, find the manufacturer and look up the specs. It needs to have the same socket(form factor) and support the bus speed of the new one.
Replacing a CPU is straightforward but non trivial.
Oct 12, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
How to install CPU- Intel Pentium Dual Core E5200 into a asus barebone system P4-P5N9300pc please?
This particular CPU is not on the list of processors supported by this board. See "CPU Support List" tab:
ASUS P4-P5N9300 Spec
How to install Socket LGA 775 CPUs:
Lift up the cpu slot load plate (which covers the pins and also locks the cpu in place) and install the processor slowly, vertically and carefully into the socket without bending any of the tiny pins in the motherboard socket. Lock the load plate.
The advent of the LGA 775 form factor moved the tiny pins from the CPU to the motherboard socket. Great for Intel, not so great for motherboard manufacturers. Now bent pins are the responsibility of the board makers. Customers with bent pin problems are no longer contacting Intel.
Sep 23, 2009 | ASUS Computers & Internet
Finding information to aid replacing cpu cooler
Yes, some do come with push pins like that instead of screws so that it is easily removed and installed also. Usually the push pin ones are cheaper. The cpu and heat sink are compatible by cpu socket type.
Apr 04, 2009 | Fujitsu Siemens Computers & Internet
The cpu heatsink clip has come apart, would like to know how to fix. the model is hp pavilion 734.uk
http://cgi.ebay.com/Intel-Socket-478-HEATSINK-RETENTION-BRACKET-Module-ONLY_W0QQitemZ170211538308QQihZ007QQcategoryZ14293QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
That's what usually breaks if you have a 478 pin cpu. Should be available in any computer shop. If the actual metal bracket on the heatsink broke you will have to buy a new fan/heatsink. Both solutions are cheap.
Apr 24, 2008 | Computers & Internet
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
42 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
