Question about Roper RT21AKXKQ Top Freezer Refrigerator
Frig shut off
Frig light is still on but, it's not cold and stuff in freeer melted. It shut down a few times beore and when we unpluged and pluged back in it would kick on but... not this time. Frig is a Roper top freezer but, not sure of model. It's about 7 yrs old.
My 7yr old roper refrigerator top freezer stopped cooling and freezing but the light was still on with no fans. I dropped the thermostat cover and jumped the thermostat wires,no help . then i removed the wiring harness from the defrost timer and jumped the #1and #4 .She kicked off. I then replaced the defrost timer and it is running fine now
Posted on Aug 15, 2008
  • 481 Answers
It sounds like the defrost timer has stuck in defrost. they are normally in the refrigerator with all the controls knobs. frig shut off - 4d49660.jpg
Posted on Jul 16, 2008
How do I fix ice build up at the back of the fridge compartment?
make sure door is closing properly,and turn temp down,or should I say up,warmer
Feb 17, 2015 | Refrigerators
Fridge quit working a month ago, unplugged it and when i plugged it back in, it started working again. now it quits working all the time, but when i shut door firmly it starts up again and stays cold for a...
You don't say how old the frig is ... you cant have a frig run like this. On one day ... off the next ... slam the door and it works ... Either get a new frig of get this one repaired professionally. Probably best to get a new frig. I would guess minimum service call charge will be $250.00
Apr 05, 2011 | Whirlpool 25.2 cu. ft. Side-by-Side...
Hi expert, have the GE adora side by side..purchased in '08. I have been having problems for about 2 months. It started with the water not dispensing. I disconnected line..purged and still not working...
this unit has a control boardd that actually controls all the componets/timing sequences on it... g.e has had several issues over the last few years with advertising energy effecient stuff and then recalled some of there monogram units or made it available to customers that they needed the doors replaced in order for them to indeed be enrgy star qualified and then there are the units with control board issues... i would almost be 98% positive you have a control board that has failed... if you unplug it will start over and reset but once reaches timing sequence it will fail again and or relays stick on board/circuit problem... i would purchase a new control board also called main pcb
www.sears.com then hit the parts direct link up top it will ask you to enter the complete model number and you can find the part and price... pretty easy to replace also...just make sure while replacing you have unplugged and avoid excess static electricity around your new circuit board... good luck to you ....
Feb 08, 2011 | GE Adora (DSF25KGTBG) Side by Side...
Frig just cool freezer cold
that can be your problem
Jun 16, 2009 | Refrigerators
Not keeping cold both frig and freezer side.
First you need to check if the compressor is working properly.
Remove the rear panel and look for a cylinder with bunch of copper lines going in and out. feel those copper lines one of them should be warm and the other should be cold. Also you should hear the compressor working (pretty noisy) when the temperature in the freezer is not cold enough. If the lines are about same temperature and the compressor does not seem to work, the first place to check is the starter relay. Often the relay breaks. The part is WHIRLPOOL 2188830 2220475 RELAY. I found one on ebay.
Good luck
Jan 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Help frig not cooling model # FRT21LR7A
You have to replace the electrical components on the side of the compressor. The heat from the fan not running by the compressor more than likely has damaged them. These are a safety feature to save the compressor from damage when it overheats.
You can find the factory repair manual here. This will have all the part numbers and what you need to replace to take care of your refrigerator. The Top Freezer Refrigerator one will be about your machine. It covers all the FRT Models.
Thanks
Jan 08, 2009 | Refrigerators
Refrigerator not getting cold
hello, my refrigerator got the following problem; it works fine at the freezer but there is no cold in the frig, when i unplug it from the wall connection and after few time connect it again, it start working, after few hours, the refrigerator stop, the freezer is fine and very cool,but the frig is not cool and the refrigerator do not start working again, even after the freezer gets warm.Please i hope you can help me with this problem.
Sep 03, 2008 | Refrigerators
Warm frigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jun 14, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Frig just not Cold
Check to see if air is blowing into refrigerator compartment.If no air is blowing.It may be that the settings on your dials are not right.If they are and air is not blowing,your evaporator fan is not working,or may be obstructed.
Dec 03, 2007 | Refrigerators
Frigidaire upright freezer and frig with freezer on top
it might have low volatge to compressor and burned out overload try unplugging it again wait a few hours and plug it back in it might start working good luck if it doesnt try replacing relay overload compasator they sell a kit called a 3 n 1 start kit
Aug 27, 2007 | Frigidaire 14.1 cu. ft. Upright Freezer...
Roper RT21AKXKQ Top Freezer Refrigerator Logo
311 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
