Question about Lexmark T630 Laser Printer
Stopping Auto Tray Selection
Where is the setting to stop the printer from using paper from another tray when trays are empty?
We have 4 trays - all A4 in size but with custom\preprinted paper. We would like to stop printing when for example tray 1 is empty - at the moment if tray 1 is empty the it automatically selects paper from tray 2 or 3 or 4.
  • Anonymous Mar 17, 2014
    lexmark
    Scholar:
  • 191 Answers
If you use different print materials of the same size in the trays, each tray with a different print material should have a unique paper type setting to prevent the printer from linking the trays together and mistakenly printing on the wrong paper.
From the printer's operator panel, choose the paper menu, then paper type, then select the source (ie, tray) that you want to change.
For example, if you have plain paper in tray 1 and preprinted paper in tray 2 and both are set up where size = A4 and type = Plain paper then when Tray 1 runs out it will automatically feed from Tray 2. To prevent this from happening you should change Tray 2 type = Letterhead. In this way, the printer knows that the two media types aren't identical and won't pull from that tray unless you specifically tell it to.
Posted on Mar 10, 2009
Xerox WC 7530 Tray 5 is default
check the computer you are printing from. Check the printer properties when the print box comes up before you click on ok. Check the paper source setting in each computers printer settings
Aug 24, 2017 | Office Equipment & Supplies
Does not sense lower feeding tray as full
One suggestion is to check if there is paper behind the tray which is stopping the paper lift mechanism from functioning properly. The paper senso rcould be dirty or broken and will need to be serviced. Or, the papersize dial could be set to the wrong paper size.
Nov 10, 2011 | Canon imageRUNNER 2200
HP optional 2000 sheet tray 4 problem.
Uninstall and then reinstall the drivers for this printer and then upgrade the firmware.....it will work....goodluck!
Jul 29, 2010 | HP LaserJet 9050 Printer
Printer shifts from normal paper tray to mp try
Change the tray select from Auto to Tray1 in printer properties.
Hope that solves
Apr 28, 2010 | Office Equipment & Supplies
Printer switches to tray 3 when out of paper instead of stopping
You can do one or a nother thing. You can change the paper size in paper tray 3 to Legal size or you can go into the user settings, under addtional funcation and choose, that tray 3 will not daisy chain when tray 2 is empty or you can make tray 3 not to be able to print too.
Mar 12, 2009 | Canon imageRUNNER 2200
Ricoh/Aficio SP C410DN Tray priority switches on its own
It is pulling paper from the tray specified within the application you are printing from or the driver. For example, from Microsoft word, you would have to go into page setup and select the tray you would like it to pull from. You will also want to check which tray it is pulling from in the driver, however the application generally overrides the driver settings. Both of which override anything you program at the machine.
Mar 12, 2009 | Ricoh Aficio SP C410DN Laser Printer
IBM Infoprint 1532 Tray Selection
For tray linking to work, both Paper Size AND Paper type must be configured the same for both trays. You probably have the paper sizes the same but types could be different. The is no setting to make tray linking work.. it will do it automatically if the above settings are correct.
Feb 24, 2009 | IBM Infoprint 1532 Laser Printer
Will not print to tray two message tray one empty stops
YOU NEED TO GO TO THE WEB MENU AND SET YOUR PRINTER TO AUTO SELECT TRAY AND SET BOTH TRAYS TO SAME EXACT PAPER TYPE
Feb 13, 2009 | IBM Infoprint 1332 Laser Printer
Paper tray selection
If I understand correctly you have two trays and the first one is set to Letter but keeps defaulting to the second tray which is Legal?
1- Sawp the trays, if it is defaulting to tray 2 then put Letter where the Legal is and see if it solves your problem.
2- it may be that it is defaulting to Legal and not to the 2nd tray, no matter what position it's in. In that case the only way to change it is the settings ( most copiers it will be in the service mode not User mode) you will not have access to it if that's the case.
Did you talk to the supervisor or Service Manager? It must be a mom and pop shop otherwise they would have sent a tech out.
Good luck.
Aug 19, 2008 | Sharp AR-160 Copier
Go to Paper Menu > Paper Size > Tray 1 - note what the Auto setting states (Letter, A4, Legal, etc.) Pull the tray out to set what it is configured for. Then reinsert it & pull it out a few times, noting what the display show the Auto size show. It should match the tray's settings.
If the Display indicates otherwise, it means one of two things:
1) The "auto size sensing" board on the left may be defective. The left side of the tray has a matrix of 3 plastic tabs that stick out in certain order depending on the tray setting. If this board fails, it may show Executive or A4 when the tray is set for letter.
2) The tray may be in-between two settings. Try to readjust the tray length setting between sizes. (You will notice the plastic tabs will change order.) The last time you loaded paper it may have pushed it just enough so that it is no longer seen as letter by the auto sensing board.
I hope this helps...
Nov 28, 2007 | Lexmark Optra T610 Laser Printer
Lexmark T630 Laser Printer Logo
2,625 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
