Sony Playstation 3 (PS3) Console Logo
Anonymous Posted on Jan 20, 2011
Can not log onto the PSN. error message 8002AD3D. I have relocated my PS3 to a different state and I'm using a NET40 wireless signal. The strength of the signal is stating 100% in the network settings. Please help
Nikki Mclean
Level 2:
  • Expert 293 Answers
  • Posted on Jan 20, 2011
Nikki  Mclean
Expert
Level 2:
Answers
293
Questions
Helped
88149
Points
891
Hi kdfrance
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
Try turning off media server on ps3 Go into the PS3?s Settings menu and navigate to Network Settings - Media Server Connection disable it thats my first idea which could be causing the issue..Secondly unplug your modem/router for 15 sec then plug back in...THEN FOLLOW STEPS
  1. Select "Network Settings" under "Settings" in the home menu, and then press the "X" button.
  2. Select "Internet Connection Settings", and then press the "X" button. When a message stating that the Internet connection will be terminated is displayed, select "Yes", and then press the "X" button.
  3. Select "Wired Connection" or "Wireless Connection", and then press the "X" button.
  4. Select "Easy" or "Custom" and adjust settings as necessary. Follow the on-screen instructions to adjust the required settings.
Note: You should always choose Easy before going onto to adjusting the Custom settings. In most cases, the Easy settings will work and are set automatically so you won't have to search for information that could have been gathered automatically.
Hope this info was helpful cheers nikki
  • Nikki  Mclean
    Nikki Mclean Jan 20, 2011
    For more information you can also go to this website where you will find more detailed help
    http://community.us.playstation.com/mess...
I AM TRYING TO GET NETFLIX ON MY PS3 AND CAN'T CONNECT TO THE PLAYSTATION NETWORK WITH MY WIRELESS NETWORK. ERROR CODE #800231221
The PSN network is currently down because of a recent hacking incident with sony.
You will not be able to log onto the PSN until they open the servers back up again.
Source:
http://blog.us.playstation.com/2011/04/26/update-on-playstation-network-and-qriocity/
*error code 80023121
tip
PlayStation 3 ERROR CODES
Complete PS3 Error Codes:<br /> <br /> <br /> 0710102 - DNS Error; No DSN server available.<br /> <br /> 8013030 - System Error due to failed update download<br /> <br /> 80010001 - Major Error , Game ability stopped<br /> <br /> 80010006 - An error occurred during the start operation (corrupted folding install)<br /> <br /> 80010007 - An error occurred during the start operation (during disc swap tests)<br /> <br /> 8001000B - it happens when trying to establish wireless connection<br /> <br /> 80010017 - Can't start BlueRay Game<br /> <br /> 8001050B - Will not play demo hard drive games, (when blue-ray disc is inserted) - cause unknown<br /> <br /> 8001050D - An error during the start operation; Ps3 game swapped using the eject function and then play pressed quickly - ps3 game inserted again<br /> <br /> 8001050F - Hardware failure. Cannot update firmware or connect to internet.<br /> <br /> 80010510 - Will not play games installed on the hard drive<br /> <br /> 80010514 - Possibly reading blu-ray disc problem<br /> <br /> 80010516 - An error occurred during the start operation; Ps1 game swapped using the eject function and then play pressed quickly - ps1 game inserted again<br /> <br /> 80023101 - Unknown<br /> <br /> 80028E07 - which pops up when i try to update to 1.93 and says that i have been disconnected from the server<br /> <br /> 80028EA5 - User cannot connect to PS3 network<br /> <br /> 80028EA6 - Connection error , Possible Proxy error power cord. Then shut off your modem/router, for about 5 minutes, then turn the modem back up first and let it sync, then turn the router back on(if using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection.<br /> <br /> 80028EA8 - Seems to mean unable to authorize isp account details<br /> <br /> 80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automatic,<br /> <br /> 80028F17 - Ps2 disc Boot Error , An error occurred during the start operation; Ps2 game swapped using the eject function and then play pressed quickly - Backup ps2 game inserted again<br /> <br /> 80028F18 - Ps2 Disc Error, unsupported disc; eg. Utility discs, BB discs, IQ Remix game etc. ode).<br /> <br /> 80028F19 - PS2 Disc Error , fsck; the internal PS2 disk got corrupted and I guess that you can use HDD utility disc to fix it<br /> <br /> 80028F1A - Ps2 Disc Error , invalbnnetcfg; network config error<br /> <br /> 80029023 - Exchanging Key Information exchange has timed out<br /> <br /> 80029024 - "The attempt to obtain an IP address has timed out".<br /> <br /> 80029301 - An error occurred during the delete operation (attempting to delete some ps2 homebrew from virtual mem card)<br /> <br /> 80029501 - connection<br /> <br /> 80029509 - When the PSN network is down for maintenance.<br /> <br /> 80029513 - This content cannot be accessed on your account (80029513)<br /> <br /> 80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3 processes - have to sign in to use them)<br /> <br /> 80029564 - Downloaded game will not install<br /> <br /> 80029751 - warhawk wont start but eveything else seems ok<br /> <br /> 80029945 - Can't playback burn BD movie<br /> <br /> 80029946 - Attempting to play burnt Dual layer NTSC disc on a PAL ps3 ( workarounds is to transfer files to ps3 via TVersity )<br /> <br /> 80029C68 - Corrupt data usually on external device<br /> <br /> 8002A10B. It shows up when I try to view my friends trophies, profile etc.<br /> <br /> 8002A10D - Unable to Add friend in XMB<br /> <br /> 8002A4A6 - Cannot load game to play online<br /> <br /> 8002A515 - Error Signing in<br /> <br /> 8002A524 - connection<br /> <br /> 8002A548 - Unable to remain logged in - either to game or server<br /> <br /> 8002A705 - Unable to connect to server/host. Check router port configuration.<br /> <br /> 8002AD23 - Unknown<br /> <br /> 8002AD3D - Cannot Log into PSN - Is the PSN down? Try manually configuring your PS3 IP info. Try disabling medai server connection in the PS3.<br /> <br /> 8002B241 - DVI has no audio.<br /> <br /> 8002B71A - Possible NAT Error , Can log onto Game Server but can't join game and can't host game<br /> <br /> 8002F994 - Too many people downloading the update (download it later on)<br /> <br /> 8002F997 - Can not update XMB firmware<br /> <br /> 80030001 - Deleting messages from inbox<br /> <br /> 8003041F - An error occurred during the copy operation (using media server)<br /> <br /> 80030517 - It seems to happen when you copy large media files.<br /> <br /> 8003051E - Game will not save<br /> <br /> 80030920 - An error occurred during the copy operation, the file may be corrupt or there isn't enough memory (Try copying data from original source)<br /> <br /> 80031150 - "Setting information is corrupted.Press the x button to repair and restore default"<br /> <br /> 80031601 - Error Creating Account<br /> <br /> 8013013D - "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the connection drops Putting the PS3 into DMZ may help - otherwise check WPA key Ps3 can't handle WPA2 only WPA or none<br /> <br /> 8013013D - connection<br /> <br /> 8013013E - WEP Key error, change WEP key to all numbers (on router homepage) and try agian, or which to WPA. - Otherwise disable security<br /> <br /> 80130203 - PS3 connects to internet but not to network - Typically means that the required ports are not open to connect to store but PS3 can connect to internet.<br /> <br /> 8013030F - Access Point not detected<br /> <br /> 8041040F - Communication with the server failed. A dsn error has occured.<br /> <br /> 80410418 - DNS Error<br /> <br /> 80410A0B - Internal PSP error, hardware fault. Send back to be replaced/fixed.<br /> <br /> 80710016 - Playstation Network is down.<br /> <br /> 80710092 - "An error has occurred. you've been signed out from the ps network" , "Media Server Error: A network error has occurred (80710092)"<br /> <br /> 80710101 - Connection error<br /> <br /> 80710102 - IP conflict , PS3 Cannot connect to the router with current IP information - Try rebooting your router<br /> <br /> 807101FF - An error occurred during communication with the server. This is a DNS error - This is a DNS error<br /> <br /> 8071053D - Hard boot the PS3, turn off the PS3 to stand-by, flip off the back switch and completely remove the power cord. Shut off your modem/router, for approx. 5 minutes, then turn the modem back up first and let it sync. Then turn the router back on (if you're using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection<br /> <br /> 80710541 - The connection to the server timed out.<br /> <br /> 80710723 - Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ<br /> <br /> 80710A06 - An error occurred during the install operation (error when downloading game from PSN - network error occured<br /> <br /> 80710B23 - PS3 Network is Down or PS3 Network is too busy to respond<br /> <br /> 80710D23 - Turn the PS3 off for approx. 30 minutes with the power toggle, not standby mode<br /> <br /> 81019002 - Error copying saves from location A to location B not open to connect to store but PS3 can connect to internet.
2helpful
Sony PS3 ERROR CODE 80710092?
here are some of the ps3 error code that might help you in the future..
80023101 - Unknown
8002AD23 - Unknown
1helpful
Can not log onto the PSN. error message 8002AD3D. I have relocated my PS3 to a different state and I'm using a NET40 wireless signal. The strength of the signal is stating 100% in the network settings....
Hi kdfrance
Error code 8002d3
Hi mhslq
If your meaning the error code 8002AD3D..This refers to not being able to Log into PSN .Check that your sign in information is correct or the sony network could be having issues.. Try configuring your PS3 internet connection again.And disable media server connection in the PS3.Hope this helps cheers nikki
Please rate the answer. Thanks for using FixYa.
2answers
I can't sign in online I dnt no y but says DNS error
Following on from the PS3 3.50 firmware update today, we have started to hear of owners having problems logging on to their accounts.
We have heard of PS3 owners who have updated their system complaining that they cannot sign in, and every time they enter their password are getting the wrong password message. We have had customers who have two PSN accounts and cannot log into either of them. They are met with wrong password message, and even when they use "Forgot your Password" all that comes up is an error.
Conrad Zimmerman of Destructtoid is reporting that PSN is going to have some scheduled maintenance today. This could be why users are complaining of problems logging on to their accounts.
The maintenance is expected to take place during 8 am until 5pm Pacific time. There will be a lot of users who are at work during this time so it will not be a problem for them, but for everyone else it will be somewhat of an annoyance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^$@#$
Error 8002AD3D unable to sign into PSN
If this is the first time you are having this issue it is possible that the playstation network may be down. If not try manually configuring your PS3 IP info. You can also try disabling medai server connection in the PS3. The link below will bring you to a form with a more detailed resolution. Scroll down the the bottom of the form for the info needed.
http://www.neoseeker.com/forums/30444/t1205912-8002ad3d-error/
I hope the info listed above has helped in some way.
If possible please rate this solution.
Cant sing in to playstation net work keeps showing an error has occured you have been signed out of playstaion net work (8002AD3D)
Error code 8002ad3d on playstation 3
Hi sir =)
1helpful
2answers
My ps3 cant find my wireless network anymore
get your router name and go through manual setup, your brother may have accedentally made your wireless network hidden, to change that go to http://192.168.1.1 or .0.1 and log in and chang the settings to default
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
